downgrade from SDK 2.4.2 to SDK 1.9.1
We are working to updated the SDK to version 2.4.2 running on nRF5340 SoC. Current the firmware is working fine except when we tested to downgrade the firmware back with the firmware using SDK 1.9.1. After we OTA the firmware back, the netcore is not been downgrade to the firmware from SKD 1.9.1. The side effect is the BLE is not longer working.
The test steps are:
1 - Flask SDK 1.9.1 firmware using Jlink.
2 - OTA SDK 2.4.2 firmware.
3 - OTA SDK 1.9.1 firmware.
4 - OTA SDK 2.4.2 firmware.
The step 4 failed because the device is no longer sending BLE advertisement.
One of my colleges read the image and he saw that between the step 2 and 3 the netcore was not updated. Meaning, the netcode firmware on step 3 is the one built using SDK 2.4.2.
I tried to enable the MCU boot netcore logs, few times I saw the following message: E: Network core update failed.
The problem I'm facing to debug the problem is the logging via RTT almost never works. After 4 days working in this issue I saw the MCU boot messages only twice.
  • As far I know for the net core (child image) the file does need to be named as pm_static.yml. The pm_static.yml must the name for the app core.
    The pm.yml I got from the build using SDK1.9.1. I took the file generated for the child image by the partition manager. I copied the file from my SDK1.9.1 build, folder <SDK1.9.1 project root folder >\build\hci_rpmsg\partitions_CPUNET.yml, renamed it to pm.yml, copied to my SDK2.4.2 files on <SDK2.4.2 project root folder >child_image\pm.yml.
    I changed the VS Code build file to include om the Extra CMake arguments the following:
    -Dhci_rpmsg_PM_STATIC_YML_FILE:STRING="C:/nRF5340-samples/nrf5340/app_core/test/peripheral_hr_sdk2.4.2/child_image/pm.yml"
    This is working because after I added it I saw the partitions_CPUNET.yml from the SDK 2.4.2 build is exactly the same the one generated by the SDK 1.9.1 build.
    I will try what you wrote. I will let you know.
    Yea, that should be enough to check this then.
    In this case, I do not think that static partitioning is the issue anymore.
    I will look more into this tomorrow, to see if I can see any other things that may cause the issue.
    I do not think this is necessary, as you were able to verify that the partitioning did not change.
  • I just try and now the child image partition from SDK 2.4.2 is not matching the child partition from SDK 1.9.2,
    The b0n end address from SDK 1.9.1 build is 0x1008600 and build using SDK 2.4.2 the b0n and address is 0x1008580. This cause because the size is different 0x8600 and 0x8580 respectively.
    The pm_static.yml, you described, will do the same for the nRF5340 app core. But right now, this is not my issue because the partition generated automatically by the partition manager match in both builds.
    Aha, try to force the same size for both, and see if that fixes this
