We have updated our code to the last sdk version (nRF51_SDK_9.0.0_2e23562) and we cannot upload the application code anymore with the nRF Toolbox on our iPad. However, we can get it to work with the MCP. If a 0x0104 comand is written on the DFU Control Point the device goes into 'DFUTarg' mode and then it can be updated using the DFU Tab and selecting the application code on the MCP. These are the code and tools we are using:
SDK: nRF51_SDK_9.0.0_2e23562 Softdevice: s110_nrf51_8.0.0_softdevice.hex nRF Toolbox under iOS 9.1 and iPad 3 Master Control Panel 3.9.0.6 Keil uVision: v 5.10.0.0 with the following merge instructions:
mergehex.exe -m .......\components\softdevice\s110\hex\s110_nrf51_8.0.0_softdevice.hex ._build\ble_app_piano.hex -o ._build\ble_app_piano_plus_stack.hex
mergehex.exe -m ._build\ble_app_piano_plus_stack.hex .....\dfu\bootloader\pegleg_3_1\dual_bank_ble_s110\arm4_build\bootloader_pegleg_3_1.hex -o ._build\ble_app_piano_plus_stack_plus_bootloader.hex
The main code implements the standard DFU service and (ble_dfu.c) and the handler files (bootloader_util.c and dfu_app_handler.c). Also we are using the standard bootloader and we have only modified the GPIOs for the LEDs to match with our board.
On the nRF Toolbox I select the fiole and the file type. Then select the device and it does connect to the iPad. Once the device is selected, I can't tap the 'Upload' button (it appears grey rather than blue). I have attached a capture image with this issue. IMG_0111.PNG
Any suggestion or follow-up question is welome.
Thanks Nacho
