Hi, I've found a few libraries available online for NRF24l01+ using AVR. But I haven't found on Nordic GitHub or website. is there any?
Regards, Hami.
Regards, Hami.
Hi Randy
Yes, you can use this code both on the transmitter and receiver side.
As long as they are configured with similar RF parameters, and you set them in PTX and PRX mode respectively, you can send packets from the PTX to the PRX.
(remember to set CE high on the PRX side to enable the receiver)
Best regards
Torbjørn
Hello
I tried this code but it didn't work. I have the nrf24l01+ this code is compatible with it right ?
How can I set the PTX or PRX mode ?
There is a documentation about the different header and source files ?
Best regards
Hi Randy
This code is compatible with the nRF24L01+, yes.
To set the PTX/PRX mode simply call hal_nrf_set_operation_mode(HAL_NRF_PTX) or hal_nrf_set_operation_mode(HAL_NRF_PRX)
The only documentation for the hal_nrf library can be found in the nRFgo SDK.
After installing the SDK you should find it in the following file:
C:\Nordic Semiconductor\nRFgo SDK 2.3.0.10040\Docs\nrf_sdk.chm
Just keep in mind that this is the documentation for the original nRF24L implementation. The port I sent you is designed to be compatible but is not an official release, and is not tested or documented separately.
Are you able to probe the signal lines between the nRF52 and your module to make sure that all the signals look OK?
Best regards
Torbjørn
No I can't do this... I have nothing to probe that signal... but I will try to read this documentation
The best of luck.
If you plan to do a lot of hardware engineering I would strongly suggest you try to acquire some kind of scope or logic analyzer. It will save you a lot of time when working on things like these ;)
