hardware: DK:
nrf52833dk_nrf52833
hardware: DK:
nrf52833dk_nrf52833
brook said:for in the sample of (central and peripheral ). I did not use coax cable either.
I just tried it again myself. And yeah for the central and peripheral, it doesn't seem to make a difference there. I do not know why the connectionless samples and the ones with connection work differently in regards to this.
With the connectionless sample though, you do need the SWF cable to break the signal to the internal antenna in order for it to connect.
Elfving
thanks
Hello, I have encountered the same problems as you, and every problem is the same as you! I have been troubled by this for a long time. Have you successfully solved this problem in the end? Is it true that the problem was solved after using SWF cables? Thank you in advance!!
