16 crystal capacitors tolerance
I'm testing a custom board I did. The board has this 16Mh crystal geyer-electronic.de/.../GEYER-KX-7_01.pdf
The CL of the crystal is 12 pF. I'm using a pair of capacitors of 22 pF. The problem is that I didn't realize that the recomended tolerance is 2%. Right now the board has two capacitors of 22 pF with 5% tolerance. Can this be a problem to get the signal of a beacon example? Thank you very much!
