Adverting is started, stopped and started ... over and over
My advertising initial is as follow.
  manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
  manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
  // Build and set advertising data.
  memset(&advdata, 0, sizeof(advdata));
  advdata.name_type     = BLE_ADVDATA_NO_NAME;
  advdata.flags   = flags;
  advdata.p_manuf_specific_data = &manuf_specific_data;
  // Initialize advertising parameters (used when starting advertising).
  memset(&m_adv_params, 0, sizeof(m_adv_params));
  m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
  m_adv_params.p_peer_addr   = NULL;  // Undirected advertisement.
  m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
  m_adv_params.interval  = NON_CONNECTABLE_ADV_INTERVAL;
  m_adv_params.duration  = 0;     // Never time out.
  err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
  err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
But, 10~11 packet are sent and stop.
After 7~8 sec. resent advertisement packet again.... and 10~10 packet send, 7~8 sec stop...
What is the problem?
BR
Paul
     * Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
     *  list of conditions and the following disclaimer.
     *  Semiconductor ASA integrated circuit in a product or a software update for
     *  such product, must reproduce the above copyright notice, this list of
     *  conditions and the following disclaimer in the documentation and/or other
     *  materials provided with the distribution.
     *  contributors may be used to endorse or promote products derived from this
     *  software without specific prior written permission.
     *  Nordic Semiconductor ASA integrated circuit.
     *  engineered, decompiled, modified and/or disassembled.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include <stdarg.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_delay.h"
    #include "nrf_log_ctrl.h"
    #include "def.h"
    #define APP_BLE_CONN_CFG_TAG  1                     /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                     /**< BLE observer priority of the application. There is no need to modify this value. */
    #define UART_TX_BUF_SIZE    1024                  /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE    256                   /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN        /**< UUID type for the Nordic UART Service (vendor specific). */
    #define ECHOBACK_BLE_UART_DATA  1                     /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
    #define SCAN_INTERVAL               0x0320                              /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW                 0x0320                              /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION           	0x0000                              /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
    NRF_BLE_GATT_DEF(m_gatt);                         /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                    /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                         /**< Scanning Module instance. */
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                    /**< BLE GATT Queue instance. */
             NRF_SDH_BLE_CENTRAL_LINK_COUNT,
             NRF_BLE_GQ_QUEUE_SIZE);
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static uint8_t tag_prefix [6] =
      0x4b, 0x22, 0x4d, 0xbf, 0x54, 0x13
    #if 0
    static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
        .active        = 0x00,
        .interval      = SCAN_INTERVAL,
        .window        = SCAN_WINDOW,
        .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
        .timeout       = SCAN_DURATION,
    //    .scan_phys     = BLE_GAP_PHY_CODED,                                 // Choose only one of the following scan_phys
        .scan_phys     = BLE_GAP_PHY_1MBPS,
    //    .scan_phys     = BLE_GAP_PHY_2MBPS,
        .extended      = 1,
    /**@brief NUS UUID. */
    static ble_uuid_t const m_nus_uuid =
      .uuid = BLE_UUID_NUS_SERVICE,
      .type = NUS_SERVICE_UUID_TYPE
    APP_TIMER_DEF(m_app_timer_id);
    int uart_event_handle_enable = 0;
    int hostConnected = 0;
    int moduleId = GW_MODULE;
    void
    DBG (const char *fmt, ...)
      va_list argptr;
      char buff [100];
      int i, len;
      va_start(argptr, fmt);
      vsprintf(&buff[0], fmt, argptr);
      va_end(argptr);
      len = strlen(&buff[0]);
      app_uart_put ('$');
      app_uart_put (0x13);
      app_uart_put (len);
      for (i = 0; i < len; i ++)
        app_uart_put (buff[i]);
        if (buff[i] == '\n')
          //app_uart_put ('\r');
    /**@brief Function for handling asserts in the SoftDevice.
     * @details This function is called in case of an assert in the SoftDevice.
     * @warning This handler is only an example and is not meant for the final product. You need to analyze
     *      how your product is supposed to react in case of assert.
     * @param[in] line_num   Line number of the failing assert call.
     * @param[in] p_file_name  File name of the failing assert call.
      app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function to start scanning. */
    static void scan_start(void)
      ret_code_t ret;
      ret = nrf_ble_scan_start(&m_scan);
      APP_ERROR_CHECK(ret);
      ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
      ret_code_t err_code;
      switch(p_scan_evt->scan_evt_id)
         case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
         } break;
         case NRF_BLE_SCAN_EVT_CONNECTED:
          ble_gap_evt_connected_t const * p_connected =
                     p_scan_evt->params.connected.p_connected;
          // Scan is automatically stopped by the connection.
          NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                p_connected->peer_addr.addr[0],
                p_connected->peer_addr.addr[1],
                p_connected->peer_addr.addr[2],
                p_connected->peer_addr.addr[3],
                p_connected->peer_addr.addr[4],
                p_connected->peer_addr.addr[5]
         } break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
           NRF_LOG_INFO("Scan timed out.");
           DBG ("Scan timed out. And restart");
           scan_start();
         } break;
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
      nrf_ble_scan_init_t init_scan;
      memset(&init_scan, 0, sizeof(init_scan));
      init_scan.connect_if_match = false;
      init_scan.conn_cfg_tag   = APP_BLE_CONN_CFG_TAG;
      //init_scan.p_scan_param   = &m_scan_param;
      err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
      err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
      err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
     * @details This function receives a single character from the app_uart module and appends it to
     *      a string. The string is sent over BLE when the last character received is a
     *      'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint8_t uart_data_ring_buf[UART_MAX_DATA_LEN];
    static uint16_t wr_ptr = 0, rd_ptr = 0;
      switch (p_event->evt_type)
          /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
          uint8_t ch;
          UNUSED_VARIABLE(app_uart_get(&ch));
          //app_uart_put (ch);
          uart_data_ring_buf[wr_ptr ++] = ch;
          if (wr_ptr == UART_MAX_DATA_LEN)
            wr_ptr = 0;
          NRF_LOG_ERROR("Communication error occurred while handling UART.");
          //APP_ERROR_HANDLER(p_event->data.error_communication);
        case APP_UART_FIFO_ERROR:
          NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
          //APP_ERROR_HANDLER(p_event->data.error_code);
    uint8_t
    uart_rx_handler (void)
      uint8_t ch;
      if (wr_ptr != rd_ptr)
        ch = uart_data_ring_buf [rd_ptr ++];
        //DBG ("%c", ch);
        if (rd_ptr == UART_MAX_DATA_LEN)
           rd_ptr = 0;
        return ch;
      return 0;
     * @brief Function for handling shutdown events.
     * @param[in]   event     Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
      switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
          // Prepare wakeup buttons.
      return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
      ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_ADV_REPORT:
          // pass all beacon
    #ifndef DK_BOARD
          int i;
    #if 0
          if (tag_prefix[0] == 0xff && tag_prefix[1] == 0xff && tag_prefix[2] == 0xff &&
              tag_prefix[3] == 0xff && tag_prefix[4] == 0xff && tag_prefix[5] == 0xff)
            app_uart_put ('$');
            app_uart_put (0x12);  // tag_info msg_id
            app_uart_put (17);    // len
            app_uart_put (p_gap_evt->params.adv_report.rssi);
            for (i = 0; i < 16; i ++)
              app_uart_put (m_scan.scan_buffer.p_data[i + 9]);
            // compare prefix, if not match, then drop
            if (memcmp (&m_scan.scan_buffer.p_data[9], tag_prefix, 6) != 0)
              // not my tag
            app_uart_put ('$');
            app_uart_put (11);    // len
            for (i = 0; i < 10; i ++)
              app_uart_put (m_scan.scan_buffer.p_data[i + 15]);
          nrf_gpio_pin_toggle (OP_LED_1_PIN);
        case BLE_GAP_EVT_CONNECTED:
          NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                 p_gap_evt->conn_handle,
                 p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
          if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
            NRF_LOG_INFO("Connection Request timed out.");
          // Pairing not supported.
          err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
          // Accepting parameters requested by peer.
          err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                              &p_gap_evt->params.conn_param_update_request.conn_params);
          ble_gap_phys_t const phys =
            .rx_phys = BLE_GAP_PHY_AUTO,
            .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
      uint32_t ram_start = 0;
      // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
      if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
      err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
      err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in] event  Event generated by button press.
      switch (event)
        case BSP_EVENT_SLEEP:
          nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
        .rx_pin_no  = HOST_UART_RX_PIN,
        .tx_pin_no  = HOST_UART_TX_PIN,
        .rts_pin_no   = 0,
        .cts_pin_no   = 0,
        .use_parity   = false,
        .baud_rate  = UART_BAUDRATE_BAUDRATE_Baud115200
                 UART_RX_BUF_SIZE,
                 UART_TX_BUF_SIZE,
                 uart_event_handle,
                 APP_IRQ_PRIORITY_LOWEST,
                 err_code);
    /**@brief Function for initializing buttons and leds. */
    static void port_init(void)
      nrf_gpio_cfg_input(MODULE_ID_PIN, NRF_GPIO_PIN_NOPULL );
      moduleId = nrf_gpio_pin_read (MODULE_ID_PIN);
      nrf_gpio_cfg_output(OP_LED_1_PIN);
      nrf_gpio_pin_clear (OP_LED_1_PIN);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    static void log_init(void)
     * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
    static void
    get_prefix_info (void)
      static int st = 0;
      uint8_t ch, len = 0, msg_id, cnt = 0, timeout = 0;
      uint8_t rx_data [64];
      int exit_flag = 1;
      while (exit_flag)
        timeout ++;
        if (timeout == 10)
          timeout = 0;
          st = 0;
        if ((ch = uart_rx_handler ()) != 0)
          timeout = 0;
          switch (st)
            case 0:
              if (ch == '$')
                st = 1;
            case 1:
              if (ch == 0x92) // ble_cfg_req
                msg_id = ch;
                cnt = 0;
                st = 2;
            case 2:
              len = ch;
              st = 3;
            case 3:
              rx_data [cnt ++] = ch;
              if (cnt == len)
                if (msg_id == 0x92)
                  for (int i = 0; i < 6; i ++)
                    tag_prefix [i] = rx_data [i];
                exit_flag = 0;  // exit from while
                st = 0;
                cnt = 0;
          nrf_delay_ms (100);
    static void
    app_timer_event_handler (void * p_context)
      app_timer_start(m_app_timer_id, APP_TIMER_TICKS(APP_TIMER_INTERVAL), NULL);
      // Initialize.
      port_init ();
      log_init();
      timer_init();
      uart_init();
    #ifndef DK_BOARD
      get_prefix_info ();
      hostConnected = 1;
      power_management_init();
      ble_stack_init();
      gatt_init();
      scan_init();
      app_timer_create(&m_app_timer_id, APP_TIMER_MODE_SINGLE_SHOT, app_timer_event_handler);
      app_timer_start(m_app_timer_id, APP_TIMER_TICKS(1), NULL);
      // Start execution.
      DBG ("BLE scanner started.\r\n");
      scan_start();
      // Enter main loop.
      for (;;)
        idle_state_handle();
    https://www.nordicsemi.com/Products/Development-tools/nRF-Sniffer-for-Bluetooth-LE/Download?lang=en#infotabs
    sniffer source is not released?
    I cannot understand specific adv packet is not received while other adv packets are received, but wireshark can detect all specific adv packet well.
    If collision is, wireshark can not receive that packet....
  • Hi Paul,
    There is one thing that comes to mind, but I am not sure if that is the case. Originally you shows a snippet where you set the scan windows equal to the scan interval, which is what you want to do to scan with a 100% duty cycle. (You also want to make sure that both have a quite high number, as scanning will be stopped and restarted on the next advertising channel every time the interval elapses.)
    However, in your code from the last post, that part is commented out. Is that what you are testing with? If commented out so that you don't provide scan params,  the NRF_BLE_SCAN_SCAN_INTERVAL and NRF_BLE_SCAN_SCAN_WINDOW (and other parameters) form sdk_config.h is used. So then the question is if this is still commented out, and if so, what you have set these to in your sdk_config.h?
    Regarding the sniffer, you are right. The sniffer firmware is only available in binary form.
    Einar
    my sdk_config.h was as follow
    // <o> NRF_BLE_SCAN_SCAN_INTERVAL - Scanning interval. Determines the scan interval in units of 0.625 millisecond.
    #ifndef NRF_BLE_SCAN_SCAN_INTERVAL
    #define NRF_BLE_SCAN_SCAN_INTERVAL 160
    // <o> NRF_BLE_SCAN_SCAN_DURATION - Duration of a scanning session in units of 10 ms. Range: 0x0001 - 0xFFFF (10 ms to 10.9225 ms). If set to 0x0000, the scanning continues until it is explicitly disabled.
    #ifndef NRF_BLE_SCAN_SCAN_DURATION
    #define NRF_BLE_SCAN_SCAN_DURATION 0
    // <o> NRF_BLE_SCAN_SCAN_WINDOW - Scanning window. Determines the scanning window in units of 0.625 millisecond.
    #ifndef NRF_BLE_SCAN_SCAN_WINDOW
    #define NRF_BLE_SCAN_SCAN_WINDOW 80
    I fixed this problem setting equal to interval and window
    BR
    Paul
