The WiFi throughput is worse than the expect result on nRF7002
I want to run the throughput test under coex condition with Separate antennaThese tests were run with WLAN connected to an AP in 2.4 GHz band.
I follow the test steps as sr_coex sample. ( developer.nordicsemi.com/.../README.html)
But the test result is worse than the result list at developer.nordicsemi.com/.../README.html
I use the code of v2.4.2 version, and I modify My sr_coex/prj.conf is as follows.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_NET_PKT_RX_COUNT=32
CONFIG_NET_PKT_TX_COUNT=32
CONFIG_NET_BUF_RX_COUNT=32
CONFIG_NET_BUF_TX_COUNT=64
CONFIG_STA_SAMPLE_SSID=xxxx
CONFIG_STA_SAMPLE_PASSWORD=xxxxxx
CONFIG_NET_CONFIG_PEER_IPV4_ADDR=xxxx
The result lists (Separate antenna, WiFi run @2.4G):
Wi-Fi throughput only:
$ iperf -s -i 1 -u
Server listening on UDP port 5001
Receiving 1470 byte datagrams
UDP buffer size: 208 KByte (default)
[ 3] local 192.168.50.135 port 5001 connected with 192.168.50.254 port 51461
[ ID] Interval Transfer Bandwidth Jitter Lost/Total Datagrams
[ 3] 0.0- 1.0 sec 1006 KBytes 8.24 Mbits/sec 472842.967 ms 0/ 1006 (0%)
[ 3] 1.0- 2.0 sec 972 KBytes 7.96 Mbits/sec 376650.747 ms 0/ 972 (0%)
[ 3] 2.0- 3.0 sec 980 KBytes 8.03 Mbits/sec 290953.846 ms 0/ 980 (0%)
[ 3] 3.0- 4.0 sec 951 KBytes 7.79 Mbits/sec 310350.777 ms 15/ 966 (1.6%)
[ 3] 4.0- 5.0 sec 967 KBytes 7.92 Mbits/sec 282155.134 ms 0/ 967 (0%)
[ 3] 5.0- 6.0 sec 979 KBytes 8.02 Mbits/sec 321029.346 ms 1/ 980 (0.1%)
[ 3] 6.0- 7.0 sec 967 KBytes 7.92 Mbits/sec 401760.932 ms 0/ 967 (0%)
[ 3] 7.0- 8.0 sec 981 KBytes 8.04 Mbits/sec 290953.856 ms 0/ 981 (0%)
[ 3] 8.0- 9.0 sec 992 KBytes 8.13 Mbits/sec 290953.799 ms 0/ 992 (0%)
[ 3] 9.0-10.0 sec 974 KBytes 7.98 Mbits/sec 365260.330 ms 0/ 974 (0%)
[ 3] 10.0-11.0 sec 975 KBytes 7.99 Mbits/sec 310350.921 ms 0/ 975 (0%)
[ 3] 11.0-12.0 sec 950 KBytes 7.78 Mbits/sec 401760.891 ms 0/ 950 (0%)
[ 3] 12.0-13.0 sec 958 KBytes 7.85 Mbits/sec 331040.962 ms 0/ 958 (0%)
[ 3] 13.0-14.0 sec 965 KBytes 7.91 Mbits/sec 1.206 ms 0/ 965 (0%)
[ 3] 14.0-15.0 sec 965 KBytes 7.91 Mbits/sec 0.969 ms 0/ 965 (0%)
[ 3] 15.0-16.0 sec 966 KBytes 7.91 Mbits/sec 0.670 ms 0/ 966 (0%)
[ 3] 16.0-17.0 sec 967 KBytes 7.92 Mbits/sec 310350.798 ms 0/ 967 (0%)
[ 3] 17.0-18.0 sec 976 KBytes 8.00 Mbits/sec 376650.629 ms 1/ 977 (0.1%)
[ 3] 18.0-19.0 sec 960 KBytes 7.86 Mbits/sec 310350.905 ms 0/ 960 (0%)
[ 3] 0.0-20.0 sec 19.0 MBytes 7.97 Mbits/sec 443290.770 ms 17/19463 (0.087%)
Coex of BLE and Wi-Fi throughput both present:
BLE:
Connected as peripheral
Conn. interval is 80 units
LE PHY updated: TX PHY LE 2M, RX PHY LE 2M
[local] received 916245 bytes (894 KB) in 1851 GATT writes at 365964 bps
Disconnected (reason 0x13)
iperf:
[ 4] local 192.168.50.135 port 5001 connected with 192.168.50.254 port 58935
[ 4] 0.0- 1.0 sec 137 KBytes 1.12 Mbits/sec 20.528 ms 812/ 949 (86%)
[ 4] 1.0- 2.0 sec 766 KBytes 6.28 Mbits/sec 7.157 ms 659/ 1425 (46%)
[ 4] 2.0- 3.0 sec 701 KBytes 5.74 Mbits/sec 4.998 ms 512/ 1213 (42%)
[ 4] 3.0- 4.0 sec 777 KBytes 6.37 Mbits/sec 2.504 ms 430/ 1207 (36%)
[ 4] 4.0- 5.0 sec 538 KBytes 4.41 Mbits/sec 1.287 ms 675/ 1213 (56%)
[ 4] 5.0- 6.0 sec 614 KBytes 5.03 Mbits/sec 2.160 ms 588/ 1202 (49%)
[ 4] 6.0- 7.0 sec 575 KBytes 4.71 Mbits/sec 1.378 ms 645/ 1220 (53%)
[ 4] 7.0- 8.0 sec 472 KBytes 3.87 Mbits/sec 3.358 ms 711/ 1183 (60%)
[ 4] 8.0- 9.0 sec 517 KBytes 4.24 Mbits/sec 4.145 ms 585/ 1102 (53%)
[ 4] 9.0-10.0 sec 741 KBytes 6.07 Mbits/sec 1.522 ms 604/ 1345 (45%)
[ 4] 10.0-11.0 sec 736 KBytes 6.03 Mbits/sec 2.514 ms 461/ 1197 (39%)
[ 4] 11.0-12.0 sec 644 KBytes 5.28 Mbits/sec 12.449 ms 575/ 1219 (47%)
[ 4] 12.0-13.0 sec 786 KBytes 6.44 Mbits/sec 1.212 ms 435/ 1221 (36%)
[ 4] 13.0-14.0 sec 662 KBytes 5.42 Mbits/sec 6.753 ms 508/ 1170 (43%)
[ 4] 14.0-15.0 sec 494 KBytes 4.05 Mbits/sec 3.829 ms 730/ 1224 (60%)
[ 4] 15.0-16.0 sec 430 KBytes 3.52 Mbits/sec 2.547 ms 815/ 1245 (65%)
[ 4] 16.0-17.0 sec 406 KBytes 3.33 Mbits/sec 2.107 ms 822/ 1228 (67%)
[ 4] 17.0-18.0 sec 503 KBytes 4.12 Mbits/sec 3.448 ms 587/ 1090 (54%)
[ 4] 18.0-19.0 sec 664 KBytes 5.44 Mbits/sec 52.655 ms 696/ 1360 (51%)
[ 4] 19.0-20.0 sec 559 KBytes 4.58 Mbits/sec 4.586 ms 636/ 1195 (53%)
[ 4] 0.0-20.0 sec 11.4 MBytes 4.79 Mbits/sec 4.368 ms 12486/24209 (52%)
My Question:
Is there some setting can update the performance of Separate antenna?
Besides, the html not mention the test result of shared antenna. The below is my test result of the shared antenna scene.
Is it normal?
Shared Antenna:
[local] received 1693395 bytes (1653 KB) in 3421 GATT writes at 686610 bps
$ iperf -s -i 1 -u
[ 3] local 192.168.50.135 port 5001 connected with 192.168.50.254 port 52985
[ 3] 0.0- 1.0 sec 715 KBytes 5.86 Mbits/sec 138.255 ms 175/ 890 (20%)
[ 3] 1.0- 2.0 sec 593 KBytes 4.86 Mbits/sec 4.006 ms 638/ 1231 (52%)
[ 3] 2.0- 3.0 sec 561 KBytes 4.60 Mbits/sec 7.797 ms 576/ 1137 (51%)
[ 3] 3.0- 4.0 sec 451 KBytes 3.69 Mbits/sec 12.480 ms 707/ 1158 (61%)
[ 3] 4.0- 5.0 sec 633 KBytes 5.19 Mbits/sec 6.619 ms 464/ 1097 (42%)
[ 3] 5.0- 6.0 sec 497 KBytes 4.07 Mbits/sec 3.737 ms 667/ 1164 (57%)
[ 3] 6.0- 7.0 sec 558 KBytes 4.57 Mbits/sec 7.264 ms 533/ 1091 (49%)
[ 3] 7.0- 8.0 sec 550 KBytes 4.51 Mbits/sec 1.958 ms 603/ 1153 (52%)
[ 3] 8.0- 9.0 sec 817 KBytes 6.69 Mbits/sec 0.944 ms 212/ 1029 (21%)
[ 3] 9.0-10.0 sec 617 KBytes 5.05 Mbits/sec 2.880 ms 453/ 1070 (42%)
[ 3] 10.0-11.0 sec 629 KBytes 5.15 Mbits/sec 6.983 ms 474/ 1103 (43%)
[ 3] 11.0-12.0 sec 475 KBytes 3.89 Mbits/sec 13.864 ms 676/ 1151 (59%)
[ 3] 12.0-13.0 sec 415 KBytes 3.40 Mbits/sec 5.453 ms 769/ 1184 (65%)
[ 3] 13.0-14.0 sec 705 KBytes 5.78 Mbits/sec 6.957 ms 340/ 1045 (33%)
[ 3] 14.0-15.0 sec 664 KBytes 5.44 Mbits/sec 9.268 ms 300/ 964 (31%)
[ 3] 15.0-16.0 sec 574 KBytes 4.70 Mbits/sec 3.026 ms 712/ 1286 (55%)
[ 3] 16.0-17.0 sec 431 KBytes 3.53 Mbits/sec 636.114 ms 735/ 1166 (63%)
[ 3] 17.0-18.0 sec 526 KBytes 4.31 Mbits/sec 1.221 ms 587/ 1113 (53%)
[ 3] 18.0-19.0 sec 629 KBytes 5.15 Mbits/sec 5.600 ms 483/ 1112 (43%)
[ 3] 19.0-20.0 sec 462 KBytes 3.78 Mbits/sec 11.181 ms 680/ 1142 (60%)
[ 3] 0.0-20.0 sec 11.2 MBytes 4.71 Mbits/sec 8.390 ms 10784/22291 (48%)
  • Hi again
    Digging into this some more I can't really find any obvious reason why your numbers are lower. I have spoken to people who get similar results as you, but also people who get results similar to those in the documentation without making any configuration changes. It might be related to the Wi-Fi router used in the test, how it is configured, which firmware version it is running etc.
    What happens if you try with a higher CONFIG_WIFI_ZPERF_RATE configuration, such as 20000 or 30000?
    Best regards
    Torbjørn
