Coordinator endpoint
Hello, I developed for my customer, a ZigBee coordinator in last 2019, using nRF5 SDK for Thread and Zigbee v3.2.0.
I has installed many sistems on field, equipped witn several battery powered sensors (door, motion, occupancy ...) and mains powered actuators (bulbs and smart plug).
I have only one endpoint # 64 configured on my coordinator, and now I need to add a second endpoint to receive the info from some end-node that sends to fixed endpoint #255
How can I add it?
Thanks for help
Abele
  • So they were there from the start? Or do you know at what point you got them?
    I am just wondering how you did the test earlier with the second endpoint earlier without these issues.
    abe said:
    the compiler errors is on ENDPOINT MACRO definition ... and it was present also without the call of new function (you can see on my previsous posts)
    I assume the issue is here that you need to declare it differently when using multiple end points (see Declaring Zigbee device context with multiple endpoints), but I do not think you need to declare EP 255.
    Elfving
  • I am just wondering how you did the test earlier with the second endpoint earlier without these issues.
    I never tried before with TWO endpoint.
    In any case, at starting of this thread, you have said
    If the end-node sends to the endpoint #255, it broadcasts to all end-points on the device. So you do not necessarily need to add another end-point for it to be picked up.
    Perhaps this means that for endpoint 255 it is not needed the macros declaration?
    Then, the only I have to do is to try the calling of function you suggested and on image here below the code I has to add to my application to have a callback for data received from endpoint #255?
    Let me know about ...
    Many many thanks for your patience and for your help
    Abele
    Exactly, I do not think that is required. When something is sent to endpoint 255, it should be recieved on endpoint 64, as well as all other end points on the device.
    I am not sure exactly what you mean here, but I do not think you need to add a handler for EP 255 either. It should be recieved at all EPs on the device.
    I just got a coworker to try this in v3.2 as well (by simply adding an enpoint handler using ZB_AF_SET_ENDPOINT_HANDLER(HA_DIMMABLE_LIGHT_ENDPOINT, light_bulb_ep_handler);). That endpoint recieved a messages addressed to both EP 10 and EP 255.
    Interestingly, that test shows that in this situation init_multi_ep_fixers() wasn't necessary, might be that is the case for you as well. Which might mean that we are back where we started, since this is the situation you had issues with to begin with, right?
    Either way, try this. And then try adding init_multi_ep_fixers() somewhere. It might be that the placement of it makes a difference, but I guess it is worth a try to check if it works without worrying too much about where it is placed.
    No problem, and thanks for your patience as well. It isn't as easy to support older SDKs, so it might take a bit longer than usual.
    Elfving
  • I just got a coworker to try this in v3.2 as well (by simply adding an enpoint handler using ZB_AF_SET_ENDPOINT_HANDLER(HA_DIMMABLE_LIGHT_ENDPOINT, light_bulb_ep_handler);). That endpoint recieved a messages addressed to both EP 10 and EP 255.
    This seems a configuration for end-node, but I'm using the Coordinator.
    On my coordinator the callback for endpoint #64 is never invoked if the end-node sends to endpoint #255
    In any case, now I try the init_multi_ep_fixers(); as you sent me, but I have some build errors:
    I am aware that this situation could be hard to solve, but please have patience to me, my customer is worried and is hoping that we could solve the issue.
    Any further suggests?
    Thanks
    Abele
  • Dear Elfving,
    to give more details ... this is the info sent to endpoint #255 by end-node to my coordinator
