Coordinator endpoint
Hello, I developed for my customer, a ZigBee coordinator in last 2019, using nRF5 SDK for Thread and Zigbee v3.2.0.
I has installed many sistems on field, equipped witn several battery powered sensors (door, motion, occupancy ...) and mains powered actuators (bulbs and smart plug).
I have only one endpoint # 64 configured on my coordinator, and now I need to add a second endpoint to receive the info from some end-node that sends to fixed endpoint #255
How can I add it?
Thanks for help
Abele
  • For more on this you can for instance see here and here. One of the documentation links is for NCS, but is mainly talking about Zigbee in general.
    Are you saying that coordinators can't have clusters? My current understanding is that they can.
    Elfving
  • Elfving,
    I'm bit confused and also disappointed ...
    But I try to best explain
    I have developed a Coordinator starting from CLI agent example on SDK for Thread and Zigbee v3.2.0.
    I used the the cli_agent_ep_handler to receive some info from end node that had joined the network.
    The coordinator bind some end-node cluster, and then teh end-node start to send this infos to Coordinator
    These infos are normally sent to same endpoint use for bind process, but we have a battery-powered sensor that when awakes sends part of this info to the Coordinator endpoint 255.
    The infos are not reported to the cli_agent_ep_handler callback
    What we need is to receive also these infos on the callback
    What we can do to have this?
    Abele
  • I am sorry to hear that.
    Just to summarize what we've found out this far: Receiving a message on EP 255 on a coordinator shouldn't be a problem. I used to think that there could be an issue receiving messages on multiple end points on SDK 3.2, but now I've gotten that tested as well so that should be fine. So the message should be received using EP 255, but only for clusters and attributes implemented on the device itself.
    This is from the documentation I've linked to:
    Every endpoint implements a set of clusters. Clusters implement the device functionality, such as attributes to store the state and the commands for various operations.
    Zigbee devices are characterized by a set of clusters that have mandatory and optional attributes. Application can either use predefined device declaration (for example, IAS Zone device) or define its own set of clusters and endpoints.
    Clusters appropriate for a single device type such as a sensor or a light bulb are organized into an addressable container that is called an endpoint.
    We can also have a look at the spec
    "deliver a copy of the message to the endpoints supporting the cluster indicated in the APS"
    It seems that you would have to have the appropriate cluster on one of the endpoints in the coordinator. Find what sort of message this sensor is sending, what clusters and attributes this sensor needs and add it to the coordinator (see "declaring cluster" here). I guess it is annoying that this is multiple systems already in the field and not something in development. Could consider doing this update with a DFU?
    abe said:
    Yes, I started from CLI Agent (the only coordinator example available on the SDK 3.2), and my endpoint handler is  based on cli_agent_ep_handler
    The light control sample also has a light coordinator sample, which I think is the recommended starting point.
    Elfving
  • Hello Elfving,
    I'm sorry, but where in the SDK3.2 light coordinator I can find "cluster" settings?
    I don't see the clusters definitions on main.c of light_coordinator, I'm not able to find these declarations
    Instead, in light_bulb main.c I find clusters declarations:
    I try to further explain and summarize my case.
    I also see that on CLI Agent Example there are no cluster declaration, only endpoint.
    If you use CLI agent example on SDK 3.2, it works it with a light bulb or (as in my use case ) with IAS zone devices (end-node)
    You only need:
    - write IAS CIE security
    - bind to coordinator endpoint the end node clusters from which the coordinator shall receive info
    That's all.
    Then, on my coordinator developed starting from CLI Agent example, this method are working well: all the end-nodes binded sends ALL info's to the Coordinator Endpoint (in my case #64)
    I'm speaking of IAS zone end-nodes manufactured by:
    - Heiman
    - Aqara
    - Neo
    - Tuya
    - Sonoff (not all type)
    From some of SONOFF IAS sensor, the alarm status (also if correctly binded to the endpoint of my coordinator), sends these info to ENDPOINT 255
    But this history is already known by you
    What I need is, using CLI Agent example on SDK 3.2: how on cli_agent_endpoint_handler callback could receive data sent from END-NODES at TWO Endpoint #64 and # 255?
    That's all, if I could have this source code then I should integrate on my cooridnator and try it with the Sonoff end-node described before
    My customer asks me if it's best to leave NRF52840 ... but I'd rather avoid this
    Thanks folr help
    Abele
