Lis3dh interrupt pins configuration
Hello everyone! I'm trying to implement the usage of accelerometer LIS3DH on a custom board. My board has nRF52832 microcontroller as the brain and a few ICs for different parts of the device like a lithium-ion solar battery charger, a LDO voltage regulator with output of 3.3v, the LIS3DH sensor, an Ultrasonic sensor connected trhough UART, and a few LEDs.
The LIS3DH MEMs sensor has a few implemented functions like free fall deection, tap and doubl tap, among others. This functions, according to datasheet, can be use to generate interrupts calls in pins INT1 and INT2.
This is the current .dts I'm working with:
// Copyright (c) 2022 Nordic Semiconductor ASA
// SPDX-License-Identifier: Apache-2.0
/dts-v1/;
#include <nordic/nrf52832_qfaa.dtsi>
	model = "HBL6232";
	compatible = "horatech,horatech-hbl6232-nrf52832";
	chosen {
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	aliases {
		lora0 = &lora;
		acel0 = &acel;
		hbluart = &uart0;
		watchdog0 = &wdt0;
	cpus {
		cpu@0 {
						device_type = "cpu";
						cpu-power-states = <&state2>;
	power-states {
		// state0: state0 {
		// 				compatible = "zephyr,power-state";
		// 				power-state-name = "active";
		// 				min-residency-us = <10000>;
		// 				exit-latency-us = <100>;
		// state1: state1 {
		// 				power-state-name = "runtime-idle";
		state2: state2 {
						power-state-name = "suspend-to-idle";
&gpio0 {
	status = "okay";
	gpio-controller;
  #gpio-cells = <2>;
&adc {
	status = "okay";
&uart0 {
	status = "okay";
&spi0 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	sck-pin = <11>;
	mosi-pin = <13>;
	miso-pin = <12>;
	cs-gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
	lora: sx1262@0 {
		compatible = "semtech,sx1262";
		reg = <0>;
		label = "sx1262";
		reset-gpios = <&gpio0 9 GPIO_ACTIVE_HIGH>;
		busy-gpios = <&gpio0 8 GPIO_OPEN_SOURCE>;
		// antenna-enable-gpios = <&gpio0 10 0>;
		rx-enable-gpios = < &gpio0 26 GPIO_ACTIVE_HIGH >;
		// radio-enable-gpios = <&gpio0 26 0>;
		tx-enable-gpios = < &gpio0 10 GPIO_ACTIVE_HIGH >;
		dio1-gpios = <&gpio0 7 GPIO_OPEN_SOURCE>;
		spi-max-frequency = <4000000>;
		dio2-tx-enable;
		dio3-tcxo-voltage = < 0x07 >;
		tcxo-power-startup-delay-ms = < 100 >;
&i2c1 {
	compatible = "nordic,nrf-twi";
	status = "okay";
	sda-pin = < 17 >;
	scl-pin = < 18 >;
	acel: lis3dh@19 {
		compatible = "st,lis3dh", "st,lis2dh";
		reg = <0x19>;
		label = "lis3dh";
		disconnect-sdo-sa0-pull-up;
		irq-gpios = < &gpio0 20 GPIO_OPEN_SOURCE >, < &gpio0 19	GPIO_OPEN_SOURCE >;
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x32000>;
		slot1_partition: partition@3e000 {
			label = "image-1";
			reg = <0x0003E000 0x32000>;
		scratch_partition: partition@70000 {
			label = "image-scratch";
			reg = <0x00070000 0xa000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007a000 0x00006000>;
And this is the .overlay:
  aliases {
    pine50 = &pine5;
		pinpg0 = &pinpg;
    pinlse0 = &pinlse;
    ledrojo = &led0;
    ledazul = &led1;
    uartus = &uart0;
  pines {
		compatible = "gpio-keys";
		pine5: pin_e_5 {
			gpios = < &gpio0 30 GPIO_ACTIVE_HIGH >;
			label = "PIN ENABLE 5V";
		pinpg: pin_power_good {
			gpios = < &gpio0 28 GPIO_OPEN_SOURCE >;
			label = "PIN POWER GOOD";
		pinlse: pin_lvl_shifter {
			gpios = < &gpio0 4 GPIO_ACTIVE_HIGH >;
			label = "PIN LVL SHIFTER ENABLE";
  leds {
    compatible = "gpio-leds";
    led0: led_rojo {
      gpios = < &gpio0 27 GPIO_ACTIVE_HIGH >;
      label = "LED ROJO";
    led1: led_azul {
      gpios = < &gpio0 29 GPIO_ACTIVE_HIGH >;
      label = "LED AZUL";
  vbatt {
		status = "okay";
		compatible = "voltage-divider";
		io-channels = <&adc 3>;
		output-ohms = <10000>;
		full-ohms = <(10000 + 10000)>;
&uart0 {
  compatible = "nordic,nrf-uart";
  current-speed = <9600>;
  tx-pin = <2>;
  rx-pin = <3>;
  label = "uart_ultrasonido";
I'm trying to findout how to set INT2 to trigger on free fall detection, and INT1 to trigger on excesive movement.
But I don't seem able to figure out how to do that.
Previously I was working in this exact same configuration with SAMR34 module from Microchip, and I had to make a library to achieve free fall detection wired to INT2 pin and excesive movement wired to INT1 pin. So I'm a bit familiar with LIS3DH sensor.
However, nRF Connect SDK poses a bigger challenge than expected sometimes.
To clarify, I'm working with Visual Studio Code with nRF Connect
- NCS version 2.1.0
- Zephyr version 3.1.0
Here is and extract of the code:
#include "acel.h"
#include <zephyr.h>
#include <device.h>
#include <logging/log.h>
#include <drivers/sensor.h>
#include <pm/device_runtime.h>
#include <pm/device.h>
#include "config.h"
#include "mbox_gpe.h"
LOG_MODULE_REGISTER(acel_gpe, LOG_LEVEL_INF);
K_MSGQ_DEFINE(trigg_event, 1, 2, 1);
typedef enum {
  ACEL_STATUS_OK,
  ACEL_STATUS_ERROR
} acel_status_t;
const struct device *dev_acel = DEVICE_DT_GET(DT_ALIAS(acel0));
acel_t *acel_data = NULL;
int64_t acel_uptime_notif = 0;
int64_t acel_uptime_gps = 0;
acel_status_t acel_init(void);
static void acel_trigg_ff(const struct device *dev, struct sensor_trigger *trig);
void acel_trigg_event(void);
int32_t acel_trigg_level(uint8_t level);
void acel_task(void *arg, void *unused1, void *unused2) {
  acel_data = (acel_t *)arg;
  acel_status_t status = acel_init();
  if (status != ACEL_STATUS_OK) {
    LOG_ERR("Error al inicializar acelerometro!%s", "");
    return;
  while(1) {
		acel_trigg_event();
    k_sleep(K_SECONDS(5));
acel_status_t acel_init(void) {
  if (!device_is_ready(dev_acel)) {
    LOG_ERR("Acel device not found!%s\n","");
    return ACEL_STATUS_ERROR;
	if (acel_data->trigger_enable == 0) {
		LOG_INF("Acel trigger disabled%s", "");
		return ACEL_STATUS_OK;
	struct sensor_value attr;
	attr.val1 = acel_trigg_level(acel_data->trigger_level_ths);
	attr.val2 = 0;
	int rc = sensor_attr_set(dev_acel, SENSOR_CHAN_ACCEL_XYZ, SENSOR_ATTR_SLOPE_TH, &attr);
	if (rc != 0) {
		LOG_ERR("sensor_attr_set SLOPE TH failed: %d", rc);
	attr.val1 = acel_trigg_level(acel_data->trigger_level_dur);
	attr.val2 = 0;
	rc = sensor_attr_set(dev_acel, SENSOR_CHAN_ACCEL_XYZ, SENSOR_ATTR_SLOPE_DUR, &attr);
	if (rc != 0) {
		LOG_ERR("sensor_attr_set SLOPE DUR failed: %d", rc);
	acel_uptime_notif = k_uptime_get();
	acel_uptime_gps = k_uptime_get();
	struct sensor_trigger trig;
	trig.type = SENSOR_TRIG_FREEFALL;
	trig.chan = SENSOR_CHAN_ACCEL_XYZ;
	rc = sensor_trigger_set(dev_acel, &trig, (sensor_trigger_handler_t)acel_trigg_ff);
	if (rc != 0) {
		LOG_ERR("sensor_trigger_set DELTA failed: %d", rc);
static void acel_trigg_ff(const struct device *dev, struct sensor_trigger *trig) {
	uint8_t event = 1;
	k_msgq_put(&trigg_event, &event, K_NO_WAIT);
void acel_trigg_event(void) {
	int64_t trigg_uptime = k_uptime_get();
	if (trigg_uptime - acel_uptime_notif <= acel_data->trigger_timeout) {
		return;
	acel_uptime_notif = trigg_uptime;
	uint8_t event;
	int rc = k_msgq_get(&trigg_event, &event, K_SECONDS(1));
	if (rc != 0) return;
	LOG_INF("Acelerometro detecto movimiento!%s", "");
	struct k_mbox_msg msgAcel;
	int bufferSize = 2;
	uint8_t buffer[bufferSize];
	buffer[0] = PUERTO_UL_ALERTA_ACEL;
	buffer[1] = 0;
 	msgAcel.info = MBOX_GPE_LORAWAN_TX;
 	msgAcel.size = bufferSize;
 	msgAcel.tx_data = buffer;
 	msgAcel.tx_target_thread = acel_data->lora_handle;
 	k_mbox_put(acel_data->gpe_mailbox_gps, &msgAcel, K_SECONDS(2));
	LOG_INF("Enviado evento de acelerometro%s","");
	if (trigg_uptime - acel_uptime_gps <= acel_data->trigger_gps_timeout) {
		return;
	acel_uptime_gps = trigg_uptime;
	msgAcel.info = MBOX_GPE_GPS_GET;
	msgAcel.size = 0;
	msgAcel.tx_data = NULL;
	msgAcel.tx_block.data = NULL;
	msgAcel.tx_target_thread = acel_data->gps_handle;
	LOG_INF("GPS enviado%s","");
int32_t acel_trigg_level(uint8_t level) {
	switch(level) {
		case 0:
			LOG_INF("Trigger SENSOR_G * 0.5%s","");
			return (int32_t)(SENSOR_G * 0.5);
		case 1:
			LOG_INF("Trigger SENSOR_G * 1%s","");
			return (int32_t)(SENSOR_G * 1.0);
		case 2:
			LOG_INF("Trigger SENSOR_G * 1.5%s","");
			return (int32_t)(SENSOR_G * 1.5);
		case 3:
			LOG_INF("Trigger SENSOR_G * 2%s","");
			return (int32_t)(SENSOR_G * 2.0);
		case 4:
			LOG_INF("Trigger SENSOR_G * 2.5%s","");
			return (int32_t)(SENSOR_G * 2.5);
		case 5:
			LOG_INF("Trigger SENSOR_G * 3%s","");
			return (int32_t)(SENSOR_G * 3.0);
To summarize, I'm not sure how to establish the INT1 pin function and the INT2 pin function.
I hope someone can help me understan better how to use the sensor implementation to it's full potential, or lead me in the right documentation to explore.
  • I don't know why freefall is not supported, but in terms of how to enable both INT1 and INT2 you first look at how only INT1 is used here:
    https://github.com/nrfconnect/sdk-zephyr/blob/main/boards/arm/thingy52_nrf52832/thingy52_nrf52832.dts#L184
    The only difference to support INT1 and INT2 would be to modify irq-gpios to add a second pin, e.g.:
    irq-gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>, <&gpio0 13 GPIO_ACTIVE_HIGH>; /* INT1 pin 12, INT2 pin 13 */
    Here are the devictree bindings listed:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/build/dts/api/bindings/sensor/st%2Clis2dh-i2c.html#dtbinding-st-lis2dh-i2c
  • Hi ,
    I have been working with the lis3d and the lis2dh driver for some time now and from my point of view the driver does not support free fall or any tap functions.
    To make it work, as you pointed out a bit, you need to extend the switch(attr) for the function you want to implement (for example free-fall). Add a callback function with sensor_trigger_set(). This callback will be executed when the interrupt is being set from the lis accelerometer and do what you need in the functions.
    An online example can be found here, where the interrupt threshold is defined and the interrupt is waited for (no polling) : https://github.com/circuitdojo/nrf9160-feather-examples-and-drivers/blob/v2.4.x/samples/tracker/src/motion/app_motion.c
    Here is the video from Circuit Dojo, he explain it is in his video: https://www.youtube.com/watch?v=EhSgynt1lj8&list=PLJKv3qSDEE-lYuq5hMpJ_sSHQcuhO1S-P&index=10
    Here is the example, but simplified. If you update your main.c like this and update your prj.conf accordingly, then it should work. Now you have a good starting point for development.
    main:
    #include <stdio.h>
    #include <zephyr/kernel.h>
    #include <zephyr/device.h>
    #include <zephyr/drivers/sensor.h>
    static void fetch_and_display(const struct device *sensor)
    	static unsigned int count;
    	struct sensor_value accel[3];
    	struct sensor_value temperature;
    	const char *overrun = "";
    	int rc = sensor_sample_fetch(sensor);
    	++count;
    	if (rc == -EBADMSG) {
    		/* Sample overrun.  Ignore in polled mode. */
    		if (IS_ENABLED(CONFIG_LIS2DH_TRIGGER)) {
    			overrun = "[OVERRUN] ";
    		rc = 0;
    	if (rc == 0) {
    		rc = sensor_channel_get(sensor,
    					accel);
    	if (rc < 0) {
    		printf("ERROR: Update failed: %d\n", rc);
    	} else {
    		printf("#%u @ %u ms: %sx %f , y %f , z %f",
    		       count, k_uptime_get_32(), overrun,
    		       sensor_value_to_double(&accel[0]),
    		       sensor_value_to_double(&accel[1]),
    		       sensor_value_to_double(&accel[2]));
    	if (IS_ENABLED(CONFIG_LIS2DH_MEASURE_TEMPERATURE)) {
    		if (rc == 0) {
    			rc = sensor_channel_get(sensor, SENSOR_CHAN_DIE_TEMP, &temperature);
    			if (rc < 0) {
    				printf("\nERROR: Unable to read temperature:%d\n", rc);
    			} else {
    				printf(", t %f\n", sensor_value_to_double(&temperature));
    	} else {
    		printf("\n");
    #ifdef CONFIG_LIS2DH_TRIGGER
    static void trigger_handler(const struct device *dev,
    			    const struct sensor_trigger *trig)
    	fetch_and_display(dev);
    	const struct device *const sensor = DEVICE_DT_GET_ANY(st_lis2dh);
    	printf("Let's start.\n");
    	if (sensor == NULL) {
    		printf("No device found\n");
    		return 0;
    	if (!device_is_ready(sensor)) {
    		printf("Device %s is not ready\n", sensor->name);
    		return 0;
    #if CONFIG_LIS2DH_TRIGGER
    		int rc;
    		//trig.type = SENSOR_TRIG_DATA_READY; // data ready triggere every time the data is ready we got data.
    		//trig.chan = SENSOR_CHAN_ACCEL_XYZ;
    		/* Set to 1.5G in m/s^2 */
        	attr.val1 = 0;
        	attr.val2 = (int32_t)(SENSOR_G * 1.3);
    		rc = sensor_attr_set(sensor, SENSOR_CHAN_ACCEL_XYZ,
        	if (rc < 0)
            	printf("Cannot set slope threshold.");
    		// Set trigger values
        	trig.type = SENSOR_TRIG_DELTA;
    		rc = sensor_trigger_set(sensor, &trig, trigger_handler);
    		if (rc != 0) {
    			printf("Failed to set trigger: %d\n", rc);
    			return 0;
    		printf("Waiting for triggers\n");
    		while (true) {
    			//fetch_and_display(sensor);
    			k_sleep(K_MSEC(2000));
    #else /* CONFIG_LIS2DH_TRIGGER */
    	printf("Polling at 0.5 Hz\n");
    	while (true) {
    #endif /* CONFIG_LIS2DH_TRIGGER */
    prj.conf:
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_I2C=y
    CONFIG_SENSOR=y
    CONFIG_CBPRINTF_FP_SUPPORT=y
    CONFIG_LIS2DH=y
    CONFIG_LIS2DH_TRIGGER_GLOBAL_THREAD=y
    Peace out.
