Problem with initial operation not working when transmitting TWI after wake-up by GPIOTE
hello,
We are implementing the function of sending/receiving via TWI after wake-up by GPIOTE.
The problem is after wake-up by GPIOTE....
The first TWI transmission/reception does not work. (No specific error is returned... only the waveform cannot be observed from the actual port.)
And in the operating state, TWI transmission/reception works normally from the second GPIOTE signal.
SW configuration is
wake-up by GPIOE -> void bsp_event_handler(bsp_event_t event) ->  app_timer_start(m_eventTWI_timer_id, EVENT_TWI_MEAS_INTERVAL, NULL);
-> static void eventTWI_timeout_handler(void * p_context) ->  read_sensor_data() -> Run nrf_drv_twi_rx
    uint32_t err_code;
    uint8_t mBLE_Send_check = 0;
    printf("> bsp_EH ");
    switch (event)
        case   BSP_EVENT_ADVERTISING_STOP :
            printf("> BSP_EVENT_ADVERTISING_STOP\r\n");
        case BSP_EVENT_KEY_0 :
            printf("eTouch\r\n");
            m_eventTWI_timer_cnt = 0;
            err_code = app_timer_start(m_eventTWI_timer_id, EVENT_TWI_MEAS_INTERVAL, NULL);
            //err_code = nrf_drv_twi_tx(&m_twi, PIC_TOUCH_ADDR, TWI_reg, sizeof(TWI_reg), false);
            //PIC_TOUCH_set_mode();
            mBLE_Send_check = 1;
    //nrf_delay_us(500);
    m_eventTWI_timer_cnt++;
    printf("> TWI_tEH %d\n\r", m_eventTWI_timer_cnt);
    UNUSED_PARAMETER(p_context);
     if( m_eventTWI_timer_cnt <= 1 )
        read_sensor_data();
        //m_eventTWI_timer_cnt = 0;
        app_timer_stop(m_eventTWI_timer_id);
static void read_sensor_data()
    m_xfer_done = false;
    uint8_t temp_key = 0;
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, PIC_TOUCH_ADDR, &m_PIC_Touch_data[0], sizeof(m_PIC_Touch_data) );
After wake-up, there was no effect even if the Timer delay was greatly increased to 500ms or more.
Please check if the first TWI does not run after wake-up.
Additionally, what was discovered during the experiment was
The role of the PCB that currently runs TWI is peripheral, but the above phenomenon is reproduced when it is not connected to central.
However, when connected to central... the problem of not being able to run TWI the first time above disappears.
It operates normally from the first TWI.
  • Hi!
    Could you show the code where you call app_button_init() ?
  • hello.
    Relevant codes are attached.
    * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    uint32_t bsp_init(uint32_t type, bsp_event_callback_t callback)
    uint32_t err_code = NRF_SUCCESS;
    #if LEDS_NUMBER > 0 && !(defined BSP_SIMPLE)
    m_indication_type = type;
    #endif // LEDS_NUMBER > 0 && !(defined BSP_SIMPLE)
    #if (BUTTONS_NUMBER > 0) && !(defined BSP_SIMPLE)
    m_registered_callback = callback;
    // *********************** BSP will support buttons and generate events ***********************
    if (type & BSP_INIT_BUTTONS)
    uint32_t num;
    /*** @brief key set ***/
    // button -> BSP_EVENT_KEY_0 matching
    for (num = 0; ((num < BUTTONS_NUMBER) && (err_code == NRF_SUCCESS)); num++)
    err_code = bsp_event_to_button_action_assign(num, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_DEFAULT);
    // 1) Pullup / Pulldown, enable / disable , event function
    // 2) call Function : nrf_drv_gpiote_is_init
    if (err_code == NRF_SUCCESS)
    err_code = app_button_init((app_button_cfg_t *)app_buttons,
    BUTTONS_NUMBER,
    APP_TIMER_TICKS(5));
    // err_code = app_button_init((app_button_cfg_t *)app_buttons,
    // BUTTONS_NUMBER,
    // APP_TIMER_TICKS(50));
    /*** @brief key enable ***/
    err_code = app_button_enable();
    /*** @brief button_timer_handler => input check ***/
    err_code = app_timer_create(&m_bsp_button_tmr, // assign Timer => APP_TIMER_DEF( m_bsp_button_tmr )
    APP_TIMER_MODE_SINGLE_SHOT, // timer => one-time operation
    button_timer_handler); // button_timer_handler -> bsp_event_handler
    /*** @brief Button source initialize ***/
    bsp_board_init(BSP_INIT_BUTTONS);
    #elif (BUTTONS_NUMBER > 0) && (defined BSP_SIMPLE)
    bsp_board_init(type);
    #endif // (BUTTONS_NUMBER > 0) && !(defined BSP_SIMPLE)
    if (type & BSP_INIT_LEDS)
    //handle LEDs only. Buttons are already handled.
    // timers module must be already initialized!
    err_code =
    app_timer_create(&m_bsp_leds_tmr, APP_TIMER_MODE_SINGLE_SHOT, leds_timer_handler);
    err_code =
    app_timer_create(&m_bsp_alert_tmr, APP_TIMER_MODE_REPEATED, alert_timer_handler);
    // FIXME
    bsp_board_init(BSP_INIT_NOUSE_GPIO);
    return err_code;
    uint32_t bsp_btn_ble_init(bsp_btn_ble_error_handler_t error_handler, bsp_event_t * p_startup_bsp_evt)
    m_error_handler = error_handler;
    if (p_startup_bsp_evt != NULL)
    //printf("> bsp_btn_ble_init - startup_event_extract\r\n");
    startup_event_extract(p_startup_bsp_evt);
    if (m_num_connections == 0)
    //printf("> bsp_btn_ble_init - advertising_buttons_configure\r\n");
    err_code = advertising_buttons_configure();
    return err_code;
    uint32_t bsp_event_to_button_action_assign(uint32_t button, bsp_button_action_t action, bsp_event_t event)
    #if BUTTONS_NUMBER > 0
    if (button < BUTTONS_NUMBER)
    if (event == BSP_EVENT_DEFAULT)
    // Setting default action: BSP_EVENT_KEY_x for PUSH actions, BSP_EVENT_NOTHING for RELEASE and LONG_PUSH actions.
    event = (action == BSP_BUTTON_ACTION_PUSH) ? (bsp_event_t)(BSP_EVENT_KEY_0 + button) : BSP_EVENT_NOTHING;
    switch (action)
    case BSP_BUTTON_ACTION_PUSH:
    m_events_list[button].push_event = event;
    case BSP_BUTTON_ACTION_LONG_PUSH:
    m_events_list[button].long_push_event = event;
    case BSP_BUTTON_ACTION_RELEASE:
    m_events_list[button].release_event = event;
    err_code = NRF_ERROR_INVALID_PARAM;
    #else
    #endif // BUTTONS_NUMBER > 0
    return err_code;
    uint32_t app_button_init(app_button_cfg_t const * p_buttons,
    uint8_t button_count,
    uint32_t detection_delay)
    uint32_t err_code;
    if (detection_delay < 2*APP_TIMER_MIN_TIMEOUT_TICKS)
    return NRF_ERROR_INVALID_PARAM;
    // @ initialize check
    if (!nrf_drv_gpiote_is_init())
    VERIFY_SUCCESS(err_code);
    /* Save configuration. */
    mp_buttons = p_buttons;
    m_button_count = button_count;
    m_detection_delay = detection_delay;
    memset(m_pin_states, 0, sizeof(m_pin_states));
    m_pin_active = 0;
    while (button_count--) // total number of buttons
    app_button_cfg_t const * p_btn = &p_buttons[button_count];
    #if defined(BUTTON_HIGH_ACCURACY_ENABLED) && (BUTTON_HIGH_ACCURACY_ENABLED == 1)
    nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(p_btn->hi_accuracy);
    #else
    nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(false);
    config.pull = p_btn->pull_cfg;
    err_code = nrf_drv_gpiote_in_init(p_btn->pin_no, &config, gpiote_event_handler);
    /* Create polling timer. */
    return app_timer_create(&m_detection_delay_timer_id,
    detection_delay_timeout_handler);
    uint32_t app_button_enable(void)
    ASSERT(mp_buttons);
    uint32_t i;
    for (i = 0; i < m_button_count; i++) // m_button_count = nRF52832 32EA Port at app_button_init
    nrf_drv_gpiote_in_event_enable(mp_buttons[i].pin_no, true); // mp_buttons = app_button_cfg_t at app_button_init
    return NRF_SUCCESS;
    void bsp_board_init(uint32_t init_flags)
    #if defined(BOARDS_WITH_USB_DFU_TRIGGER) && defined(BOARD_PCA10059)
    (void) nrf_dfu_trigger_usb_init();
    #if LEDS_NUMBER > 0
    if (init_flags & BSP_INIT_LEDS)
    bsp_board_leds_init();
    #endif //LEDS_NUMBER > 0
    if (init_flags & BSP_INIT_BUTTONS)
    //bsp_board_buttons_init();
    // bsp_board_buttons_source_init();
    #endif //BUTTONS_NUMBER > 0
    if (init_flags & BSP_INIT_NOUSE_GPIO)
    bsp_board_GPIO_noUsed_init();
  • Hi!
    I don't see anything immediately wrong in the code snippets. Is this wake-up from System ON or System OFF sleep?
    Maybe setting BUTTON_HIGH_ACCURACY_ENABLED to 1 in sdk_config.h could help
    If that does not help, then I think we would need as mentioned, a small example that reproduces this issue on a 52832-DK to dig into this further.
  • HI
    I think this issue was a timing issue.
    When the GPIOE signal event occurs, I2C is read almost immediately with the code below...
    Currently, when a GPIOE signal event occurs, nrf_drv_twi_rx() is read after a certain time using a timer.
    It operates normally.
    I don't know if this is the exact cause...
    First of all, the operational problem was resolved.
    Ok, good to hear!
