nrf Connect mesh distributor gives memory overflow when build for nrf52833. I have uploaded the build configuration I am using. Also attached the build log.
I have tried the solution for memory overflow provided on devzone, increased the
* Executing task: nRF Connect: Generate config nrf52833dk_nrf52833 for /Users/admin/Desktop/Connect_SDK/distributor Building distributor /bin/sh -c west build --build-dir /Users/admin/Desktop/Connect_SDK/distributor/build /Users/admin/Desktop/Connect_SDK/distributor --pristine --board nrf52833dk_nrf52833 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /Users/admin/Desktop/Connect_SDK/distributor -- CMake version: 3.20.5 -- Found Python3: /opt/nordic/ncs/toolchains/4ef6631da0/opt/[email protected]/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/admin/Library/Caches/zephyr -- Zephyr version: 3.3.99 (/opt/nordic/ncs/v2.4.2/zephyr) -- Found west (found suitable version "1.0.0", minimum required is "0.7.1") -- Board: nrf52833dk_nrf52833 -- Found host-tools: zephyr 0.16.0 (/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.0 (/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/4ef6631da0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.4.2/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts -- Generated zephyr.dts: /Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/dts.cmake warning: Experimental symbol BT_MESH_V1d1 is enabled. Parsing /opt/nordic/ncs/v2.4.2/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.4.2/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig' Merged configuration '/Users/admin/Desktop/Connect_SDK/distributor/prj.conf' Configuration saved to '/Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/.config' Kconfig header saved to '/Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Found Python3: /opt/nordic/ncs/toolchains/4ef6631da0/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter === child image mcuboot - begin === loading initial cache file /Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr -- CMake version: 3.20.5 -- Found Python3: /opt/nordic/ncs/toolchains/4ef6631da0/opt/[email protected]/bin/python3.9 (found suitable exact version "3.9.6") found components: Interpreter -- Cache files will be written to: /Users/admin/Library/Caches/zephyr -- Zephyr version: 3.3.99 (/opt/nordic/ncs/v2.4.2/zephyr) -- Found west (found suitable version "1.0.0", minimum required is "0.7.1") -- Board: nrf52833dk_nrf52833 -- Found host-tools: zephyr 0.16.0 (/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.0 (/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/4ef6631da0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.4.2/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts -- Found devicetree overlay: /opt/nordic/ncs/v2.4.2/nrf/modules/mcuboot/usb.overlay -- Generated zephyr.dts: /Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.4.2/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig' Merged configuration '/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/zephyr/prj.conf' Merged configuration '/opt/nordic/ncs/v2.4.2/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration '/Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/.config' Kconfig header saved to '/Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /opt/nordic/ncs/v2.4.2/nrf/lib/flash_patch/CMakeLists.txt:8 (message): ---------------------------------------------------------- --- WARNING: To maintain the integrity of secure boot, --- --- enable CONFIG_DISABLE_FLASH_PATCH in production. --- ---------------------------------------------------------- CMake Warning at /opt/nordic/ncs/v2.4.2/zephyr/CMakeLists.txt:839 (message): No SOURCES given to Zephyr library: lib__libc__common Excluding target from build. MCUBoot bootloader key file: /opt/nordic/ncs/v2.4.2/bootloader/mcuboot/root-rsa-2048.pem -- Configuring done -- Generating done -- Build files have been written to: /Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot === child image mcuboot - end === CMake Warning at /opt/nordic/ncs/v2.4.2/nrf/modules/mcuboot/CMakeLists.txt:310 (message): --------------------------------------------------------- --- WARNING: Using default MCUBoot key, it should not --- --- be used for production. --- --------------------------------------------------------- CMake Warning at /opt/nordic/ncs/v2.4.2/zephyr/CMakeLists.txt:839 (message): No SOURCES given to Zephyr library: lib__libc__common Excluding target from build. -- Configuring done -- Generating done -- Build files have been written to: /Users/admin/Desktop/Connect_SDK/distributor/build -- west build: building application [1/366] Preparing syscall dependency handling [2/366] Generating misc/generated/syscalls_subdirs.trigger [3/366] Generating include/generated/version.h -- Zephyr version: 3.3.99 (/opt/nordic/ncs/v2.4.2/zephyr), build: v3.3.99-ncs1-1 [4/366] Creating directories for 'mcuboot_subimage' [5/366] No download step for 'mcuboot_subimage' [6/366] No update step for 'mcuboot_subimage' [7/366] No patch step for 'mcuboot_subimage' [8/366] No configure step for 'mcuboot_subimage' [8/366] Performing build step for 'mcuboot_subimage' [1/288] Preparing syscall dependency handling [2/288] Generating include/generated/version.h -- Zephyr version: 3.3.99 (/opt/nordic/ncs/v2.4.2/zephyr), build: v3.3.99-ncs1-1 [3/288] Generating misc/generated/syscalls_subdirs.trigger [4/288] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json [5/288] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h [6/288] Generating include/generated/driver-validation.h [7/288] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h [8/288] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj [9/288] Generating include/generated/offsets.h [10/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj [11/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj [12/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj [13/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj [14/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj [15/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj [16/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj [17/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj [18/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj [19/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj [20/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj [21/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj [22/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj [23/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj [24/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj [25/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj [26/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj [27/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj [28/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj [29/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj [30/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj [31/288] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj [32/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj [33/288] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj [34/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj [35/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj [36/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj [37/288] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj [38/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj [39/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj [40/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj [41/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj [42/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj [43/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj [44/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj [45/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj [46/288] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj [47/288] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.4.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj [48/288] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj [49/288] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj [50/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj [51/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj [52/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj [53/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj [54/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj [55/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj [56/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj [57/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj [58/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj [59/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj [60/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj [61/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj [62/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj [63/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj [64/288] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj [65/288] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj [66/288] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj [67/288] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj [68/288] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj [69/288] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj [70/288] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj [71/288] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj [72/288] Generating linker_zephyr_pre0.cmd [73/288] Linking C static library zephyr/arch/common/libisr_tables.a [74/288] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a [75/288] Linking C static library zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a [76/288] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a [77/288] Linking C static library zephyr/drivers/console/libdrivers__console.a [78/288] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a [79/288] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj [80/288] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a [81/288] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj [82/288] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj [83/288] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj [84/288] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj [85/288] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj [86/288] Linking C static library zephyr/drivers/flash/libdrivers__flash.a [87/288] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj [88/288] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj [89/288] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj [90/288] Generating linker_zephyr_pre1.cmd [91/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj [92/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/aes.c.obj [93/288] Linking C static library zephyr/arch/common/libarch__common.a [94/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/aesni.c.obj [95/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/aria.c.obj [96/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/asn1parse.c.obj [97/288] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a [98/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/asn1write.c.obj [99/288] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a [100/288] Linking C static library zephyr/drivers/serial/libdrivers__serial.a [101/288] Linking C static library zephyr/drivers/timer/libdrivers__timer.a [102/288] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a [103/288] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a [104/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/base64.c.obj [105/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/bignum.c.obj [106/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/bignum_core.c.obj [107/288] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a [108/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/bignum_mod.c.obj [109/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/bignum_mod_raw.c.obj [110/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/camellia.c.obj [111/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ccm.c.obj [112/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/chacha20.c.obj [113/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/chachapoly.c.obj [114/288] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a [115/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/cipher.c.obj [116/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/cipher_wrap.c.obj [117/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/cmac.c.obj [118/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/code_share.c.obj [119/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/constant_time.c.obj [120/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ctr_drbg.c.obj [121/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/debug.c.obj [122/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/des.c.obj [123/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/dhm.c.obj [124/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ecdh.c.obj [125/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ecdsa.c.obj [126/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ecjpake.c.obj [127/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ecp.c.obj [128/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ecp_curves.c.obj [129/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/entropy.c.obj [130/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/entropy_poll.c.obj [131/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/error.c.obj [132/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/gcm.c.obj [133/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/hash_info.c.obj [134/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/hkdf.c.obj [135/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/hmac_drbg.c.obj [136/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/lmots.c.obj [137/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/lms.c.obj [138/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/md.c.obj [139/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/md5.c.obj [140/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj [141/288] Generating ../../../include/generated/libc/minimal/strerror_table.h [142/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/mps_reader.c.obj [143/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/mps_trace.c.obj [144/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/net_sockets.c.obj [145/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/nist_kw.c.obj [146/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/oid.c.obj [147/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/padlock.c.obj [148/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pem.c.obj [149/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pk.c.obj [150/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pk_wrap.c.obj [151/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pkcs12.c.obj [152/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pkcs5.c.obj [153/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj [154/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj [155/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj [156/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj [157/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj [158/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj [159/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj [160/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj [161/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj [162/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj [163/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj [164/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj [165/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj [166/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj [167/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj [168/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj [169/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj [170/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj [171/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj [172/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj [173/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pkcs7.c.obj [174/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj [175/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pkparse.c.obj [176/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/pkwrite.c.obj [177/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/platform.c.obj [178/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/platform_util.c.obj [179/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/poly1305.c.obj [180/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto.c.obj [181/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj [182/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj [183/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_client.c.obj [184/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj [185/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj [186/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj [187/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj [188/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_pake.c.obj [189/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj [190/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_se.c.obj [191/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj [192/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj [193/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/psa_its_file.c.obj [194/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ripemd160.c.obj [195/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/rsa.c.obj [196/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj [197/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/sha1.c.obj [198/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/sha256.c.obj [199/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/sha512.c.obj [200/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_cache.c.obj [201/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj [202/288] Linking C static library zephyr/libzephyr.a [203/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_client.c.obj [204/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_cookie.c.obj [205/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj [206/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_msg.c.obj [207/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_ticket.c.obj [208/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_tls.c.obj [209/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_tls12_client.c.obj [210/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_tls12_server.c.obj [211/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj [212/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj [213/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj [214/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj [215/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/threading.c.obj [216/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/timing.c.obj [217/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/version.c.obj [218/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/version_features.c.obj [219/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/x509.c.obj [220/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/x509_create.c.obj [221/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/x509_crl.c.obj [222/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/x509_crt.c.obj [223/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/x509_csr.c.obj [224/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/x509write_crt.c.obj [225/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/opt/nordic/ncs/v2.4.2/modules/crypto/mbedtls/library/x509write_csr.c.obj [226/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.4.2/modules/hal/nordic/nrfx/mdk/system_nrf52833.c.obj [227/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj [228/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.4.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj [229/288] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a [230/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj [231/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj [232/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj [233/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj [234/288] Building C object modules/segger/CMakeFiles/modules__segger.dir/opt/nordic/ncs/v2.4.2/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj [235/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v2.4.2/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj [236/288] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj [237/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj [238/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj [239/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj [240/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj [241/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj [242/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj [243/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj [244/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj [245/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj [246/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj [247/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj [248/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj [249/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj [250/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj [251/288] Linking C static library modules/segger/libmodules__segger.a [252/288] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a [253/288] Linking C static library zephyr/kernel/libkernel.a [254/288] Generating zephyr/autogen-pubkey.c [255/288] Building C object CMakeFiles/app.dir/keys.c.obj [256/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj [257/288] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj [258/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj [259/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj [260/288] Building C object CMakeFiles/app.dir/main.c.obj [261/288] Building C object CMakeFiles/app.dir/os.c.obj [262/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj [263/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj [264/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj [265/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj [266/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/loader.c.obj [267/288] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj [268/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj [269/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/caps.c.obj [270/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj [271/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj [272/288] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj [273/288] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj [274/288] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj [275/288] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj [276/288] Linking C static library app/libapp.a [277/288] Linking C static library modules/mbedtls/libmodules__mbedtls.a [278/288] Linking C executable zephyr/zephyr_pre0.elf [279/288] Generating dev_handles.c [280/288] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj [281/288] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj [282/288] Linking C executable zephyr/zephyr_pre1.elf [283/288] Generating linker.cmd [284/288] Generating isr_tables.c, isrList.bin [285/288] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj [286/288] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj [287/288] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj [288/288] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 29758 B 48 KB 60.54% RAM: 23808 B 128 KB 18.16% IDT_LIST: 0 GB 2 KB 0.00% [345/366] Linking C executable zephyr/zephyr_pre0.elf FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map : && ccache /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/subsys/mgmt/mcumgr/mgmt/libsubsys__mgmt__mcumgr__mgmt.a zephyr/subsys/mgmt/mcumgr/smp/libsubsys__mgmt__mcumgr__smp.a zephyr/subsys/mgmt/mcumgr/util/libsubsys__mgmt__mcumgr__util.a zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/libsubsys__mgmt__mcumgr__grp__img_mgmt.a zephyr/subsys/mgmt/mcumgr/grp/os_mgmt/libsubsys__mgmt__mcumgr__grp__os_mgmt.a zephyr/subsys/mgmt/mcumgr/grp/zephyr_basic/libsubsys__mgmt__mcumgr__grp__zephyr_basic.a zephyr/subsys/mgmt/mcumgr/transport/libsubsys__mgmt__mcumgr__transport.a zephyr/subsys/random/libsubsys__random.a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a zephyr/subsys/bluetooth/mesh/libsubsys__bluetooth__mesh.a zephyr/subsys/dfu/boot/libsubsys__dfu__boot.a zephyr/subsys/net/libsubsys__net.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/hwinfo/libdrivers__hwinfo.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a modules/nrf/subsys/bluetooth/mesh/lib..__nrf__subsys__bluetooth__mesh.a modules/nrf/subsys/bluetooth/mesh/shell/lib..__nrf__subsys__bluetooth__mesh__shell.a modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a modules/zcbor/libmodules__zcbor.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -L/Users/admin/Desktop/Connect_SDK/distributor/build/zephyr -lgcc zephyr/arch/common/libisr_tables.a /opt/nordic/ncs/v2.4.2/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_3.0.13.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie /opt/nordic/ncs/v2.4.2/nrfxlib/softdevice_controller/lib/cortex-m4/soft-float/libsoftdevice_controller_multirole.a /opt/nordic/ncs/v2.4.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a && cd /Users/admin/Desktop/Connect_SDK/distributor/build/zephyr && /opt/nordic/ncs/toolchains/4ef6631da0/Cellar/cmake/3.20.5/bin/cmake -E echo /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH' /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 180628 bytes collect2: error: ld returned 1 exit status ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/4ef6631da0/bin/cmake --build /Users/admin/Desktop/Connect_SDK/distributor/build * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
Log for build with CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x80000
* Executing task: nRF Connect: Build: distributor/build (active)
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
Loaded configuration '/Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/.config'
No change to configuration in '/Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/.config'
No change to Kconfig header in '/Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/include/generated/autoconf.h'
Loaded configuration '/Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/.config'
No change to configuration in '/Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/.config'
No change to Kconfig header in '/Users/admin/Desktop/Connect_SDK/distributor/build/mcuboot/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Configuring done
-- Generating done
[0/50] Performing build step for 'mcuboot_subimage'
[1/32] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/32] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[3/32] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[4/32] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[5/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[6/32] Generating linker_zephyr_pre1.cmd
[7/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[8/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[9/32] Generating linker_zephyr_pre0.cmd
[10/32] Building C object zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v2.4.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[11/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[12/32] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[13/32] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
[14/32] Linking C static library zephyr/libzephyr.a
[15/32] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[16/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[17/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[18/32] Building C object CMakeFiles/app.dir/main.c.obj
[19/32] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[20/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[21/32] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
[22/32] Building C object CMakeFiles/app.dir/opt/nordic/ncs/v2.4.2/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[23/32] Linking C static library app/libapp.a
[24/32] Linking C executable zephyr/zephyr_pre0.elf
[25/32] Generating dev_handles.c
[26/32] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[27/32] Linking C executable zephyr/zephyr_pre1.elf
[28/32] Generating linker.cmd
[29/32] Generating isr_tables.c, isrList.bin
[30/32] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[31/32] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[32/32] Linking C executable zephyr/zephyr.elf
FLASH: 29758 B 512 KB 5.68%
[29/50] Linking C executable zephyr/zephyr_pre0.elf
[33/50] Linking C executable zephyr/zephyr_pre1.elf
[38/50] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[40/50] No install step for 'mcuboot_subimage'
[41/50] Completed 'mcuboot_subimage'
[42/50] Linking C executable zephyr/zephyr.elf
FLASH: 413540 B 18446744073709547008 B 0.00%
RAM: 111574 B 128 KB 85.12%
[43/50] Generating zephyr/mcuboot_primary_app.hex
[44/50] Generating zephyr/mcuboot_primary.hex
[45/50] Generating ../../zephyr/app_update.bin
image.py: sign the payload
[46/50] Generating ../../zephyr/dfu_application.zip
[47/50] Generating ../../zephyr/app_signed.hex
[48/50] Generating ../../zephyr/app_test_update.hex
[49/50] Generating ../../zephyr/app_moved_test_update.hex
[50/50] Generating zephyr/merged.hex
Log for flash with CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x80000
* Executing task: nRF Connect: Build: distributor/build (active) Building distributor /bin/sh -c west build --build-dir /Users/admin/Desktop/Connect_SDK/distributor/build /Users/admin/Desktop/Connect_SDK/distributor [0/4] Performing build step for 'mcuboot_subimage' ninja: no work to do. * Terminal will be reused by tasks, press any key to close it. * Executing task: nRF Connect: Flash: distributor/build (active) Flashing build to 682782848 /bin/sh -c west flash -d /Users/admin/Desktop/Connect_SDK/distributor/build --skip-rebuild --dev-id 682782848 -- west flash: using runner nrfjprog -- runners.nrfjprog: Flashing file: /Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/merged.hex [error] [ Worker] - Address 0x00080000 does not map to a known memory. [error] [ Client] - Encountered error -173: Command erase_file executed for 71 milliseconds with result -173 ERROR: The file specified is not a valid hex file, has data outside valid areas ERROR: or does not have data in valid areas. NOTE: For additional output, try running again with logging enabled (--log). NOTE: Any generated log error messages will be displayed. FATAL ERROR: command exited with status 52: nrfjprog --program /Users/admin/Desktop/Connect_SDK/distributor/build/zephyr/merged.hex --sectoranduicrerase --verify -f NRF52 --snr 682782848 * The terminal process terminated with exit code: 52. * Terminal will be reused by tasks, press any key to close it.
I am new to nrf Connect SDK, kindly guide me how to resolve this issue.
IDE used;- VS Code
Development board used :- nrf52833dk
SDK used :- nrf Connect SDK v2.4.2
Thanks
