nRF9160 ping event with AWS IoT
How does the device catch incoming ping events?
The device uses AWS IoT library, so it can't open a raw socket.
It looks like the ping events closed inside the modem binary.
So, this code does not run.
/opt/nordic/ncs/v2.0.2/zephyr/subsys/net/ip/icmpv4.c
Are there any ping event APIs? or sniffing raw packets?
nRF9160
mfw_nrf9160_1.3.2
nRF Connect SDK v.2.0.2
Update 2023-10-13
I use a diagram to explain what I want to achieve and what is actually difficult to achieve.
    Thank you for the detailed description.
    I was able to reproduce this scenario locally, and I'm awaiting response from R&D to look deeper into what the behavior is in this specific case.
    I will update you as soon as I have new information, usually after approx. 2 business days.
    Håkon
    Thank you so much for your patience.
    When opening a SOCK_RAW type socket, there's restrictions that apply. Mainly, you have two options:
    * Open the SOCK_RAW on a dedicated PDN
    or:
    * Keep all other sockets closed while the raw socket (SOCK_RAW type) is open.
    My apologies that these undocumented restrictions apply to this type of socket.
    Håkon
  • Thank you for your consideration.
    Having seen your post, this is my understanding:
    • Ping events from the server are typically processed within the modem firmware, and the application side cannot catch these events.
    • Ping events from the server can be captured by opening a raw socket. However, it is not possible to simultaneously capture events with AWS IoT and pings from the server.
    Application can handle ICMP only if opening a SOCK_RAW type socket.
    Yes, this is correct. A SOCK_RAW type socket cannot operate simultaneously as other sockets on one specific PDN.
    Håkon
