Sending advertising packets using NRF_RADIO
I have the following set up:
1) an NRF timer which triggers the timer-handler
2) an NRF radio peripheral which is triggered by the timer-handler
3) an NRF radio transmission which is fired in radio-handler
Timer-handler (interrupt routine):
void timer1_interrupt_handler(nrfx_timer_event_handler_t evt, void * p_context)
LOG_INF("========= Timer1 HANDLER =========");
    radio_interup_counter = 0;
    NRF_TIMER1 -> EVENTS_COMPARE[0] = 0;
    // Loging radio state before its activation
    state0 = nrf_radio_state_get(NRF_RADIO);
    // Reseting interupt setting and configuration
    nrf_radio_int_disable(NRF_RADIO, 0xFFFFFFFF);
	nrf_radio_int_enable(NRF_RADIO, NRF_RADIO_INT_END_MASK | NRF_RADIO_INT_READY_MASK);
    // Dummy packets to be sent by the radio interupt to follow
    // (Packets are already declared globally)
    packet.x = 23;
    packet.z = 67;
    packet.z = 15;
    // Packet pointer assignment
    NRF_RADIO->PACKETPTR = (uint32_t) &packet;
    // Firing the radio!
    NRF_RADIO->TASKS_TXEN = 1;
Radio handler (interrupt routine):
ISR_DIRECT_DECLARE(RADIO_ISR) {
    radio_interup_counter ++;
    if (radio_interup_counter == 1){
        LOG_INF("======= First RADIO HANDLER =======");
    // TASK-Start when READY is received
    if (NRF_RADIO->EVENTS_READY == 1) {
        NRF_RADIO->EVENTS_READY = 0;
        NRF_RADIO->TASKS_START = 1U;
        // Loging NRF_RADIO State
        state1 = nrf_radio_state_get(NRF_RADIO);
    // Disabling Radio when END is received
    if (NRF_RADIO->EVENTS_END == 1) {
        NRF_RADIO->EVENTS_END = 0;
        NRF_RADIO->TASKS_DISABLE = 1U;
        state2 = nrf_radio_state_get(NRF_RADIO);
    // Creating some extra logging information (ADDRESS and Payload signals)
    if (NRF_RADIO->EVENTS_ADDRESS == 1U){
        state3 = 20;
    } else {state3 = 0;}
    state4 = 0;
    if (NRF_RADIO->EVENTS_PAYLOAD == 1U){
        state4 = 30;
    if (radio_interup_counter == 2){
    // Loging Radio State Transitions
    LOG_INF("  Step_a: %d, Step_b: %d, Step_c: %d, Address: %d, Payload: %d",
            state0, state1, state2, state3, state4);
    LOG_INF("======= Last RADIO HANDLER  =======");
    ISR_DIRECT_PM();
    return 1;
This is the Log information
[00:08:01.192,962] <inf> Logging_Name:========= Timer1 HANDLER =========
[00:08:01.215,393] <inf> Logging_Name:======= First RADIO HANDLER =======
[00:08:01.237,915] <inf> Logging_Name:  Step_a: 0, Step_b: 11, Step_c: 12, Address: 20, Payload: 30
[00:08:01.262,817] <inf> Logging_Name:======= Last RADIO HANDLER  =======
which means:
We do a full cycle of "Radio off (0)", "Transmission (11)", and "disabling (12)" where we received "Address" and "Payload" transmission signals.
Although this log shows that the radio is sending something, I do not get any message on my wireshark which is hooked up to the NRF_SINFFER.
MOREOVER: I tried to verify transmission by checking the power consumption of the DK.
This is the power-profile of this process that I get using NRF PPK2:
which clearly shows that NRF_RADIO is triggered every 2 seconds which is the timer timeout that I set;
if we look deeper:
Comparing to the NRF power online profiler for nrf52840, this does not show that the radio is actually sending anything.
For the radio configuration, I do the following:
static void radio_configure(void)
	const nrf_radio_packet_conf_t pkt_conf = {
		.lflen = 0,
		.s0len = 0,
		.s1len = 0,
		.maxlen = sizeof(struct packet_structure),
		.statlen = 0,
		.balen = 4,
		.big_endian = true,
		.whiteen = true,
	nrf_radio_power_set(NRF_RADIO, true);
	nrf_radio_txpower_set(NRF_RADIO, NRF_RADIO_TXPOWER_0DBM);
	nrf_radio_mode_set(NRF_RADIO, RADIO_MODE_MODE_Ble_1Mbit);
	nrf_radio_modecnf0_set(NRF_RADIO, true, RADIO_MODECNF0_DTX_Center);
	nrf_radio_crc_configure(NRF_RADIO, 3, NRF_RADIO_CRC_ADDR_INCLUDE, 0x11021UL);
	nrf_radio_crcinit_set(NRF_RADIO, 0xFFFFFFUL);
	nrf_radio_packet_configure(NRF_RADIO, &pkt_conf);
    // Creating the access address
    uint32_t ACCESS_ADDRESS[5] = {0x8E, 0x89, 0xBE, 0xD6};
	nrf_radio_base0_set(NRF_RADIO,
		ACCESS_ADDRESS[2] << 24 | ACCESS_ADDRESS[1] << 16 |
		ACCESS_ADDRESS[0] << 8);
	nrf_radio_prefix0_set(NRF_RADIO, ACCESS_ADDRESS[0]);
	nrf_radio_txaddress_set(NRF_RADIO, 0);
	nrf_radio_rxaddresses_set(NRF_RADIO, BIT(0));
	uint32_t Channel_Frequency = 80;
    NRF_RADIO->FREQUENCY = Channel_Frequency;
	nrf_radio_event_clear(NRF_RADIO, NRF_RADIO_EVENT_END);
I will be really thankful if you could help me understand why this code does not work.
I have checked almost everything, but still I am not able to figure out why this code does not work (does not send packets).
Any help or suggestion is very much appreciated.
