How to connect external 3.3V I/F I2S signal to nrf5340-audio-dk
devzone.nordicsemi.com/.../set-nrf5340-audio-dk-as-i2s-slave-over-external-bus
Based on this post, I changed I2S to SLAVE setting.
The external I2S I/F level is 3.3V.
When OB/EXT is green, it is noisy when I2S of 3.3V I/F is connected to P5, but we have confirmed that the audio signal is sent to the RX side and the sound is heard.
devzone.nordicsemi.com/.../access-to-i2s-interface-on-nrf5340-audio-dk
Based on this post, I tried changing the I2S port.
If OB/EXT lights up orange, does that mean the port has been changed to P10 instead of P5?
But when OB/EXT is orange, there is no sound even if you forcefully connect the 3.3V I/F to P10.
Also, in order to change the 3.3V I/F to 1.8V I/F, I changed the I2S signal level using TI's TXS0108E.
When I connect the nrF5340 to the enabled I2S port (P5 or P10), I checked with an oscilloscope and found that there is quite a lot of noise on the I2S signal.
Since it is a bidirectional buffer, it seems that the noise component is flowing backwards, or the GND level is not stable and crosstalk noise is being buffered.
Is there a way to run nrF5340-audio-DK with 3.3V I/F?
Or is there a good way to make I2S a 1.8V I/F?
