BLE failures with EIO
I'm developing a BLE application using several connections, and of course I'm advertising and scanning to establish those connections. I have up to 5 connections at a time and running both peripheral and central roles.
Occasionally I get an error when trying to do a BLE operation and it's not clear to me what the error means for how I should respond. In particular I sometimes get -EIO when calling bt_le_ext_adv_start() or bt_conn_disconnect(). A cursory look through the code in these functions doesn't show an obvious reason why EIO occurs, except that it may be caused by an error when sending an HCI command to the controller in bt_hci_cmd_send_sync(). Looking at the logs, I do sometimes see a warning like "bt_hci_core: opcode 0x200e status 0x0c" which is indeed generated in bt_hci_cmd_send_sync(). Since the EIO error only occurs occasionally I suspect it may be occurring due to a timing window where the host and controller are out of sync, or some other transient condition. In some cases retrying the operation later works eventually, sometimes not (advertising seems to often fail many times in a row and then succeed; disconnecting failures seem to never succeed with retries).
At the end of the day I just want my application to robustly handle error conditions like this. But, with the error code EIO I'm not sure how to respond. If it's dependent on the specific opcode/status code, the application doesn't have access to this information (only EIO). Can you give me any insight into what I should do in situations like this? Is there any way for the application to know more specific error codes so it can respond appropriately?
Details: I am using NCS 2.4.1 on the nRF5340 with the net core running the soft device controller. I think these are the relevant parts of my project configuration.
App core:
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_MAX_CONN=5
CONFIG_BT_EXT_ADV=y
CONFIG_BT_EXT_ADV_MAX_ADV_SET=2
CONFIG_BT_GATT_DM=y
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_TX_COUNT=20
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_FILTER_ACCEPT_LIST=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_SMP=y
CONFIG_BT_DEVICE_NAME="ABC"
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
Net core:
CONFIG_BT_CTLR=y
CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=255
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_CTLR_ADV_SET=2
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_CTLR_RX_BUFFERS=10
CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y
CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
  • Hi MMater,
    Could you please get a full log with these configurations enabled?
    CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG
    CONFIG_USBD_BT_HCI_LOG_LEVEL_DBG
  • Here is a snippet of the error log. Email me for the full file.
    [00:01:03.733,306] .[0m<dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 33.[0m
    [00:01:03.733,367] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001e4c8).[0m
    [00:01:03.733,367] .[0m<dbg> bt_hci_core: bt_recv: buf 0x2001e4c8 len 35.[0m
    [00:01:03.733,428] .[0m<dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue.[0m
    [00:01:03.733,428] .[0m<dbg> bt_hci_core: rx_work_handler: buf 0x2001e4c8 type 1 len 35.[0m
    [00:01:03.733,459] .[0m<dbg> bt_hci_core: hci_event: event 0x3e.[0m
    [00:01:03.733,489] .[0m<dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d.[0m
    [00:01:03.733,489] .[0m<dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1.[0m
    [00:01:03.733,612] .[0m<dbg> bt_scan: le_adv_recv: E9:D5:00:82:00:07 (public) event 0, len 7, rssi -91 dBm.[0m
    [00:01:03.733,703] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:.[0m
    .[1;31m--- 60 messages dropped ---
    .[0m[00:01:03.898,803] .[0m<dbg> bt_scan: le_adv_recv: E1:81:EB:FD:FF:33 (random) event 3, len 8, rssi -96 dBm.[0m
    .[1;31m--- 26 messages dropped ---
    .[0m[00:01:03.905,517] .[0m<dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue.[0m
    .[1;31m--- 42 messages dropped ---
    .[0m[00:01:03.934,997] .[0m<dbg> bt_hci_core: bt_recv: buf 0x2001e4c8 len 47.[0m
    .[1;31m--- 67 messages dropped ---
    .[0m[00:01:03.935,699] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:.[0m
    [00:01:03.936,309] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RPMsg data:
    04 3e 39 0d 01 10 00 01 c8 ca de d8 ae 27 01 00 |.>9..... .....'..
    ff 7f a4 00 00 ff 00 00 00 00 00 00 1f 1e ff 06 |........ ........
    00 01 09 20 22 93 f1 15 1f e7 da 81 d7 95 13 72 |... "... .......r
    6d 79 70 8b 9e 26 49 76 b8 4f 7f 26 |myp..&Iv .O.& .[0m
    [00:01:03.936,340] .[0m<dbg> bt_hci_driver: bt_rpmsg_evt_recv: len 57.[0m
    [00:01:03.936,370] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: Calling bt_recv(0x2001e4c8).[0m
    [00:01:03.936,401] .[0m<dbg> bt_hci_core: bt_recv: buf 0x2001e4c8 len 59.[0m
    [00:01:03.936,431] .[0m<dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue.[0m
    .[1;31m--- 33 messages dropped ---
    .[0m[00:01:04.029,418] .[0m<dbg> bt_hci_core: bt_recv: buf 0x2001ef5c len 6.[0m
    [00:01:04.029,418] .[0m<dbg> bt_hci_core: hci_cmd_complete: opcode 0x2042.[0m
    [00:01:04.029,449] .[0m<dbg> bt_hci_core: hci_cmd_done: opcode 0x2042 status 0x0c buf 0x2001ef5c.[0m        ERROR HERE
    [00:01:04.029,510] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
    0c |. .[0m
    [00:01:04.029,541] .[1;33m<wrn> bt_hci_core: opcode 0x2042 status 0x0c.[0m
    .[1;31m--- 16 messages dropped ---
    .[0m[00:01:04.030,303] .[0m<dbg> bt_hci_core: bt_recv: buf 0x2001ef5c len 6.[0m
    .[1;31m--- 24 messages dropped ---
    .[0m[00:01:04.095,581] .[0m<dbg> bt_scan: le_adv_recv: E9:D5:00:82:00:07 (public) event 0, len 7, rssi -89 dBm.[0m
    .[1;31m--- 32 messages dropped ---
    .[0m[00:01:04.100,433] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:.[0m
    .[1;31m--- 21 messages dropped ---
    .[0m[00:01:04.125,396] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:.[0m
    .[1;31m--- 128 messages dropped ---
    .[0m[00:01:04.136,383] .[0m<dbg> bt_hci_core: hci_event: event 0x3e.[0m
    [00:01:04.136,413] .[0m<dbg> bt_hci_core: hci_le_meta_event: subevent 0x0d.[0m
    [00:01:04.136,413] .[0m<dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1.[0m
    [00:01:04.136,535] .[0m<dbg> bt_scan: le_adv_recv: 4C:2E:91:B8:A1:E3 (random) event 0, len 20, rssi -86 dBm.[0m
    [00:01:04.136,596] .[0m<dbg> bt_host_crypto: bt_encrypt_le: key affc5f8d5dd5bfe9374a42ee5b4a4c94.[0m
    .[1;31m--- 11 messages dropped ---
    .[0m[00:01:04.139,404] .[0m<dbg> bt_scan: bt_hci_le_adv_ext_report: Adv number of reports 1.[0m
    [00:01:04.139,526] .[0m<dbg> bt_scan: le_adv_recv: 35:12:DE:56:AB:35 (random) event 3, len 31, rssi -70 dBm.[0m
    [00:01:04.139,617] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:.[0m
    [00:01:04.178,497] .[0m<dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x2042 param_len 6.[0m
    [00:01:04.178,527] .[0m<dbg> bt_hci_core: bt_hci_cmd_create: buf 0x2001ef5c.[0m
    .[1;31m--- 14 messages dropped ---
    .[0m[00:01:04.179,138] .[0m<dbg> bt_hci_core: bt_recv: buf 0x2001ef5c len 6.[0m
    [00:01:04.179,168] .[0m<dbg> bt_hci_core: hci_cmd_complete: opcode 0x2042.[0m
    [00:01:04.179,199] .[0m<dbg> bt_hci_core: hci_cmd_done: opcode 0x2042 status 0x0c buf 0x2001ef5c.[0m
    [00:01:04.179,229] .[0m<dbg> bt_hci_driver: bt_rpmsg_rx: RX buf payload:
    0c |. .[0m
  • Hi MMater,
    My apology for the late follow up. We have been short-handed/overloaded for a few days due to various sicknesses and the Easter holiday.
    In your log, the issue is OpCode 0x2042 resulted in 0x0c. 0x2042 is the OpCode for LE Set Extended Scan Enable, and 0x0c stands for Command Disallowed.
    With the SoftDevice Controller, currently that happens in a few scenarios:
    1. Trying to enable scanner when it is already running
    2. Trying to disable scanner when initiator is running
    3. Trying to disable scanner when it is not running
    #1 and #3 are not forbidden as per the Bluetooth Core Specification, but is not allowed in the current SoftDevice Controller. We have noted this internally and will address it.
    Could you please check if your code is causing one of those cases? The fix would then to just avoid it.
    For info about what the OpCode and Status codes mean, refer to:  Log warning message: bt_hci_core: opcode 0x200a status 0x0d .
    Hieu
  • Hieu,
    Thanks for checking back. We believe the issue was having EXT_ADV enabled on the appcore and not on the netcore.
  • MMater,
    You will need it on both cores. I hope things work well now?
1 2 3
