nrf5340 audio:BIS audio bad frame
We have an nrf5340audio application and are doing BIS broadcast audio testing.
However, when there are any obstructions in the middle, a large number of bad frames will appear, and the audio listening quality will be very difficult to receive.
There is no problem in open scenes, but obviously there are many obstructions in actual scenes.
Do you have any suggestions for solving this problem, or is there a more suitable PLC algorithm? Because the transmission is streaming, I cannot write the PLC algorithm through subsequent data.
    Reskyllr said:
    If there is occlusion at a very close distance, a lot of bad frames will appear.
    If you could please elaborate on what kind of occlusion you are referring to here, and if you could quantify what you mean when you say 'very close distance' that would be very helpful for my understanding of your issue.
    Reskyllr said:
    CONFIG_BT_CTRL_TX_PWR_ANTENNA has been set, there is no difference in the result.
    Could you check that the RSSI is increased as expected following this change, either by using the nRF Connect application for Desktop to check the RSSI of the extended advertisements, or to use the nRF Sniffer to verify this?
    Reskyllr said:
    Adding PA will make our module larger, which is bad. We have tried it.
    I understand, thank you for clarifying.
    Karl
  • Occlusion is simple, such as the human body or even a display screen, and bad frames will appear.
    For RSSI, already confirmed, it works fine.
  • In general the human body is a very good blocker for RF signals due to its density, and a display screen could have a full metal frame or backing which would serve as an effective blocker as well - especially so if the devices are located right next to the display screen, or far away on either side.
    I am glad to read that you already confirmed the RSSI to increase following the TX Power adjustment.
    Could you confirm whether or not you are working on a custom board, or on a nRF5340 Audio DK? In the case of a custom board, have any review been done by us on the schematic and layout of the board?
    Karl
  • Hi Karl,
    Yes, it's a custom build, but that doesn't matter.
    Because I also own the nrf5340 audio DK, the problem still exists when using it, even if I burn the original nrf demo.
    In other words, the current official DK and demo also have the same problem. Have you done any relevant tests? The BIS is very bad when there is occlusion.
    Thank you for your attention. I hope I can pay attention to it to analyze whether it is a hardware problem or a software problem.
    Reskyllr
  • Hello again Reskyllr,
    Thank you for your patience with this - I have reported this as a BIS range issue to the LE Audio developers.
    To aid the debugging of the issue, could you possibly conduct the same test as you have done now with CIS, to see if that makes any difference in the glitching in the audio?
    For good measure we can also perform a schematic and layout review for you, to see if there could be any optimizations or improvements in the RF circuitry. If you would like this, please open another Private DevZone ticket to request the review :)
    Karl
