I see the Matter CHIP integration uses BLE for commissioning, so to advertise a ble service the documentation advises to use NUS.
What about scanning for ble devices and connecting to them?
What applications are those devices running?
Please be aware that
To test the Matter bridge application with the Bluetooth LE bridged device, you also need the following:
An additional development kit compatible with one of the following Bluetooth LE samples:
See the Requirements section.
Do you build the sample with the following commands?
west build -b nrf7002dk_nrf5340_cpuapp -- -DCONFIG_BRIDGED_DEVICE_BT=y -DOVERLAY_CONFIG="overlay-bt_max_connections_app.conf" -Dhci_rpmsg_OVERLAY_CONFIG="absoule_path/overlay-bt_max_connections_net.conf"
Replace absolute_path with the absolute path to the Matter bridge application on your local disk.
See Configuring the number of Bluetooth LE bridged devices for the details.
-Amanda H.
So if I want to add support for different peripheral ble devices with other UUIDs I have to add a class and modify some code inside the ble_providers?
You could add into https://github.com/nrfconnect/sdk-nrf/blob/v2.5.0/applications/matter_bridge/src/app_task.cpp#L67-L72
-Amanda H.
The bridge sample uses WIFI for Matter, what about using Thread?
I've been having issues enabling it, as it causes the build to require multiprotocol_rpmsg child image so after adding the multiprotocol's .conf and CmakeLists line from the weather station sample it builds and I start getting the -5 error again. I tried to add CONFIG_BT_CENTRAL=y to the conf of multiprotocol but then it overflows the flash by 23488 bytes.
From what I can see there is no example of CHIP + Thread + BLE scan right?
sfemat said:The bridge sample uses WIFI for Matter, what about using Thread?
The Matter Bridge features only support matter applications.
sfemat said:I've been having issues enabling it, as it causes the build to require multiprotocol_rpmsg child image so after adding the multiprotocol's .conf and CmakeLists line from the weather station sample it builds and I start getting the -5 error again. I tried to add CONFIG_BT_CENTRAL=y to the conf of multiprotocol but then it overflows the flash by 23488 bytes.
What sample are you using? What do you enable?
Are you testing the Matter bridge application? If so, it doesn't require extra configs unless you want to modify the connection numbers.
sfemat said:From what I can see there is no example of CHIP + Thread + BLE scan right?
Unfortunately, there is no such example as your requirement.
Amanda H.
