nRF52832 with SK6812 LEDs
I tried to run the example code for the ws2812 (which can be found at C:\ncs\v2.4.1\v2.4.1\zephyr\samples\drivers\led_ws2812) for the nRF52832 using nRF Connect SDK (v2.4.1).
Looking at the nrf52dk_nrf52832.overlay, it looks like MOSI would be used on P0.23.
&arduino_spi { /* MOSI on D11 / P0.23 */
I am trying to experiment using the nRF52 DK board.
I have a known working LED ring which lights up from another board.
The code builds fine but when I run it, I see the following in the terminal.
Using a Saleae Logic analyzer, I don't see anything on P0.23.
I tried adding the following from nrf52dk_nrf52832.dts but I ended up with the same message in the terminal and didn't see anything on the logic analyzer.
I tried multiple pins and couldn't see any changes on the IO lines that looked like the required signal for the WS2812 LEDs.
&spi2_default {
    group1 {
        psels = <NRF_PSEL(SPIM_SCK, 0, 25)>, <NRF_PSEL(SPIM_MISO, 0, 24)>,
        <NRF_PSEL(SPIM_MOSI, 0, 12)>;
 * Copyright (c) 2017 Linaro Limited
 * Copyright (c) 2018 Intel Corporation
#include <errno.h>
#include <string.h>
#define LOG_LEVEL 4
LOG_MODULE_REGISTER(main);
#include <zephyr/kernel.h>
#include <zephyr/drivers/led_strip.h>
#include <zephyr/device.h>
#include <zephyr/drivers/spi.h>
#include <zephyr/sys/util.h>
#define STRIP_NODE		DT_ALIAS(led_strip)
#define STRIP_NUM_PIXELS	DT_PROP(DT_ALIAS(led_strip), chain_length)
#define DELAY_TIME K_MSEC(50)
#define RGB(_r, _g, _b) { .r = (_r), .g = (_g), .b = (_b) }
static const struct led_rgb colors[] = {
	RGB(0x0f, 0x00, 0x00), /* red */
	RGB(0x00, 0x0f, 0x00), /* green */
	RGB(0x00, 0x00, 0x0f), /* blue */
struct led_rgb pixels[STRIP_NUM_PIXELS];
static const struct device *const strip = DEVICE_DT_GET(STRIP_NODE);
	size_t cursor = 0, color = 0;
	int rc;
	if (device_is_ready(strip)) {
		LOG_INF("Found LED strip device %s", strip->name);
	} else {
		LOG_ERR("LED strip device %s is not ready", strip->name);
		return 0;
	LOG_INF("Displaying pattern on strip");
	while (1) {
		memset(&pixels, 0x00, sizeof(pixels));
		memcpy(&pixels[cursor], &colors[color], sizeof(struct led_rgb));
		rc = led_strip_update_rgb(strip, pixels, STRIP_NUM_PIXELS);
		if (rc) {
			LOG_ERR("couldn't update strip: %d", rc);
		cursor++;
		if (cursor >= STRIP_NUM_PIXELS) {
			cursor = 0;
			color++;
			if (color == ARRAY_SIZE(colors)) {
				color = 0;
		k_sleep(DELAY_TIME);
	return 0;
0334.prj.conf
Has anyone had success with the WS2812 or SK6812 with the nRF52832 and nRF Connect SDK?
Thanks.
