NRF9160 - LTE-M takes a long time for first connection
Hi! We are currently testing our custom device using the nrf9160 modem. Our use case is for an ultralow power IoT device that connects to the Internet each 30 minutes to send some data and then goes back to sleep. We don’t use PSM, when the device goes back to sleep, we disconnect from the cloud and set the modem to flight mode. The device will be in a place with no coverage (a maritime container) for days or weeks, in which the device will be in “hibernation mode”, trying to connect to LTE-M each 4 hours.
We have seen that after the first connection, the device connects to the LTE-M network in less than 5 seconds but before that, the first connection takes a long time, around two minutes.
We are using the command AT+CGDCONT before every connection to set the APN hoping that it will decrease the time it takes for that first connection, but it doesn’t make a lot of difference. The device travels around the world, so we cannot lock the LTE-M bands nor the country.
Why does the first connection take a long time and the rest doesn’t? What are the best practices to reduce the time of that first connection? Are there any other AT commands that we can use to reduce that time?
Thank you and best regards
  • Thanks.
    I have forwarded the trace to our modem team, so they can take a look at it.
    They typically answer quite quickly, so I should have an answer within a day or two.
  • Hi Didrik, any feedback from the modem team?
    Best regards.
  • Yes, and sorry for this taking a bit longer than expected. There were some additional details I had to check.
    First of all, the modem team pointed out that, in general, swapping the SIM cards does not simulate scenario where a new SIM card is used for the first time. Typically SIM card contains the last registered PLMN in EF_EPSLOCI file, so when such card is inserted to whatever device, the last registered PLMN will be searched first. In addition, factory reset would be needed for clearing the cell history modem has stored earlier.
    As for why the 1nce SIM card takes longer to connect to a network, this is what the modem team said:
    1nce log show that the SIM card does not contain EF_EPSLOCI file, thus the home network (HPLMN) must be searched first. The HPLMN was not found and the only preferred PLMN configured to the SIM card was not either found (262 01). The only option left for modem is to try to Attach to some random network with high quality signal (3 of them were found). At first modem tries to Attach to 214 01 and luckily the Attach succeeds immediately.
    They also commented on the use of %XCOUNTRYDATA:
    In general, for devices that travel a lot we recommend to use the %XCOUNTRYDATA which can be used for prioritizing certain bands and channels in certain countries. This is very useful if preferred networks for many different countries have been configured to the SIM card. So for example, 1nce SIM card had 262 01 configured as preferred network. If certain band had been configured with %XCOUNTRYDATA for MCC 262, that band would have been scanned first when in country with MCC 262 resulting typically much faster Attach. Unfortunately, 1nce card didn’t have more than one preferred network configured, so benefit of using %XCOUNTRYDATA would limited to country with MCC 262 only.
    Eneko said:
    I updated the modem firmware to v1.3.5 as the modem won't search for PLMN started with 901.
    Unfortunately, the fix introduced in mfw 1.3.5 doesn't impact the initial network search. However, it does mean that the modem will not search for the home network unless it is connected to a different global PLMN.
  • Hi Didrik,
    Thank you so much for the explanation. Now I understand better what is going on.
    As you said, it seems the %XCOUNTRYDATA won't help.
    Although the SIM does not have EF_EPSLOCI file, is there any data about the last PLMN saved in the modem? It seems so, since after initial registration the modem takes less than 10s to connect.
    What does initial network search means in this case? Using a new, unused SIM card?
    I can reduce the time (locking bands) the modem takes to register with a new SIM card (then unlock bands). This way the modem have data about a PLMN -correct me if I'm wrong-.
    What happens if the modem can't register to the last PLMN? eg: different country (MCC change) or area (same MCC but MNC/operator not available in that area).
    As far as I understood, it will start searching the HPLMN (global) and then the Prefered PLMN (26201). After that try to register in nearby networks. Same procedure as the initial network search. Am I right?
    Thank you for your help.
    Best regards.
