Using GPIOTE with S130 in the BLE UART example
I've been using the ble_app_uart example with S130 on a nRF51 DK board. I wanted to add an interrupt with some GPIO pins. So I added GPIOTE interrupt handler but the compiler returned an error:
linking... ._build\nrf51422_xxac_s120.axf: Error: L6200E: Symbol GPIOTE_IRQHandler multiply defined (by nrf_drv_gpiote.o and main.o). Not enough information to list image symbols. Not enough information to list the image map. Finished: 2 information, 0 warning and 1 error messages. "._build\nrf51422_xxac_s120.axf" - 1 Error(s), 0 Warning(s).
I only added two function: stimulus_init and the interrupt handler.
void stimulus_init(void)
  nrf_gpio_cfg_sense_input(16, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_SENSE_LOW);
  NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Msk;
  NVIC_EnableIRQ(GPIOTE_IRQn);
void GPIOTE_IRQHandler(void)
  if(NRF_GPIOTE->EVENTS_PORT)
    NRF_GPIOTE->EVENTS_PORT = 0;
I am aware of the function "app_button_init" to initialise GPIO pins. But it seems that it uses timer for polling. I need to use interrupt in order to minimise delay which needs to be within 1 ms.
Update: 02/12/2015
After I could get the gpiote event working on its own (without any softdevice), I added the code below to main.c and called it in the main function. The idea is that when button 1 (AUDIO_STIM_PIN) is pressed, "A" is sent over BLE UART.
But then the entire code stopped working. Even after commenting everything after nrf_drv_gpiote_init(), the code stopped working.
Any suggestions on what went wrong?
void stimulus_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
	uint8_t data_array[1] = "A";
	uint16_t len = 1;
	ret_code_t err_code = ble_uart_c_write_string(&m_ble_uart_c, data_array, len);
void gpiote_init(void)
	uint32_t gpiote_event_addr;
	ret_code_t err_code;
  nrf_drv_gpiote_in_config_t event_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
  err_code = nrf_drv_gpiote_in_init(AUDIO_STIM_PIN, &event_config, stimulus_handler);
	gpiote_event_addr = nrf_drv_gpiote_in_event_addr_get(AUDIO_STIM_PIN);
	nrf_drv_gpiote_in_event_enable(AUDIO_STIM_PIN, true);
  • I found 2 places that have BLE_GAP_EVT_DISCONNECTED event in the project, namely,
    1. device_manager_central.c
    2. ble_db_discovery.c
    I placed breakpoints in the switch case for this event. But when the disconnection occurred, the execution did not go to any of these breakpoints.
    Any suggestion where I can detect the event?
  • You should have gotten the event. You are sure the code is not stuck? Try stopping the execution while in debug after the disconnection.
  • After pressing the button triggering my gpiote event, I could still step through the code until it reaches line 84 (below) in ble_uart_c.c.
        err_code = sd_ble_gattc_write(m_tx_buffer[m_tx_index].conn_handle,
                                      &m_tx_buffer[m_tx_index].req.write_req.gattc_params);
    If I select Step Into, it goes to line 160 of arm_startup_nrf51.s
    HardFault_Handler\
                    PROC
                    EXPORT  HardFault_Handler         [WEAK]
                    B       .
                    ENDP
    and then it is stuck.
    I also attempted to use polling. I wrote a function that sends a character to the dongle whenever button press is detected. The function is located in the for loop in the main function (below) and works fine.
    for (;;)
        power_manage();
    	stimulus_polling();
  • I should have thought of this before: The GPIOTE handler is running at APP_PRIORITY_HIGH, which means that sd_ble_gattc_write(...) is called at this level. It is not allowed to do SoftDevice calls at APP_PRIORITY_HIGH, and if attempted to do so, the application will run into hardfault. SoftDevice calls have to be made in main context or at APP_PRIORITY_LOW. I will update my answer if this is correct. Sorry for the late answer.
  • Ole, you are a champion!!
    Following your suggestion, I found how to implement the priority in https://devzone.nordicsemi.com/question/57691/app_scheduler-and-timer1-hardfault/
    The GPIOTE works after I added
      NVIC_SetPriority(GPIOTE_IRQn, APP_IRQ_PRIORITY_LOW);
    in the initialisation step, straight after
