What is the best strategy for connection between specific central and peripheral when both are powered up and then locking the connection so no more devices interfere?
Thanks. Is this also mean that one peripheral can establish a connection with two or more central simultaneously?
Yes, that is possible.
We have the BLE Multiperipheral sample in the SDK that demonstrates how one Peripheral can connect to several Centrals.
_____________
Br,
Joakim
Thanks all clear. By the way it is interesting that multi peripheral example is called experimental :)
StanislavDimitrov said:By the way it is interesting that multi peripheral example is called experimenta
As Simon wrote in this previous ticket:
The experimental libraries have undergone less testing, and have usually been out for a shorter amount of time, so the chance of discovering bugs will be larger although none of the libraries should be assumed to be completely free of bugs.
All libraries and examples in the SDK, both experimental and not, are provided "as is", so in the end, it is up to you to test your application sufficiently and confirm that it meets your requirements.
