MPSL not working correctly with custom ble hci_rpmsg image
We have been trying to get MPSL up and running in a BLE and ESB coexistence project but haven't had much luck.
We use an app core image that enables the BLE interface and listens for RPC events from the net core. The net core is a modified version of the BLE hci_rpmsg image with support added for RPC and ESB. We use RPC to notify the app core when data is received over ESB from other Nordic devices. BLE only needs to run for a short period of time and that period of time is user initiated. When implementing the MPSL piece, the BLE hci image is able to bind to "zephyr_bt_hci_rpmsg_ipc" but the "net_buf_get" while loop that delivers data to the app core is blocked from sending anything. We haven't been able to figure out how to allow "net_buf_get" to send BLE data to the app core once MPSL is implemented.
When we init MPSL, we schedule a request to open a session and create a time slot. This process completes without any issues and we are notified that the time slot has begun. At this time, we'll enable ESB and send some data to a nearby nrf5340dk and that process is also successful. After this happens, we would assume that we would notify MPSL that the process has completed and that the bluetooth communication channel should be allowed to continue.
We have reviewed the following MPSL sample projects but continue to run into errors with the bluetooth hci communication piece.
  1. https://github.com/too1/ncs-esb-ble-mpsl-demo/tree/master
  2. https://github.com/nrfconnect/sdk-nrf/tree/main/samples/mpsl/timeslot
Oddly enough, the bluetooth portion worked without any issues until we enabled the following kconfig values for MPSL.
CONFIG_MPSL=y
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=2
CONFIG_RING_BUFFER=y
CONFIG_DYNAMIC_INTERRUPTS=y
CONFIG_DYNAMIC_DIRECT_INTERRUPTS=y
Are there any examples where MPSL is used for BLE and ESB coexistence on a board with an app core and a net core? Unfortunately the first link above looks like it runs on an older infrastructure that doesn't apply to our use-case. Any help would be appreciated as we've spent a lot of time trying to get MPSL working correctly.
