Improving BLE immunity on nrf52840 with dynamic frequency hopping
I am a software engineer working on a product that will need to be certified for EMC in the near future. The product uses the nrf52840 for BLE and the software is being developed using Zephyr and the NRF-SDK.
During a EMC pre-scan at the test lab that will also handle the certification the BLE connection would get interrupted when a 3V/m field was applied at 2,4GHz which which we would expect considering BLE operates between 2,4GHz and 2,48GHz. But it also occurred around 2,2GHz and 2,6GHz, which according to the test engineers working at the certifications lab is outside of the acceptable range for certification.
The hardware engineers working on this product are working on a way to improve this in hardware. But the test lab also recommended we look into potential ways this could be improved trough changes in the software. They specifically mentioned "listen before talk" and "dynamic frequency hopping" as potential fixes.
I couldn't find much information about listen before talk with BLE. As far as I can tell dynamic frequency hopping should be possible with BLE but I can't find any indication in the Zephyr/NRF-SDK documentation that there is support for this feature and the following post suggests as much:  Adaptive frequency hopping with Bluetooth LE audio broadcast
I did find a way to manually set a channel map to exclude specific channels, but if I understand how it's supposed to work correctly the BLE connections should switch between the channels all the time and and the device should figure out which channels yield the best performance automatically.
Is it correct there is currently no support for either of these features? If so, will this be added in the near future?
Or is this something we could implement ourselves fairly easily?
The certification test engineers also mentioned they had run into similar issues certifying other Nordic devices and got better results using the "Direct Test Mode". We looked at this while preparing for the EMC pre-scan and concluded it's a nice tool that lets you select specific channels to try and sweep across channels but it wouldn't necessarily represent real word usage.
Is direct test mode representative for how the device would behave in practice when maintaining a BLE connection with an application build with Zephyr and NRF-SDK and should we just use that instead for the certification tests?
Or is this just a tool that can help track down a specific issue and the certification test should be done with the actual application that will ship with the product?
Any other advice on how immunity can be improved in hardware or software would also be appreciated.
Many thanks in advance,
Thomas Gooijers
  • Hi Simon,
    We develop both the central and the peripheral for our application so we might be able to take advantage of this feature.
    If I understand you correctly, for the peripheral we would only have to enable the the QoS module to get dynamic frequency hopping to work. But for the central we would have to figure out how to determine the channels to use and set the channel map accordingly.
    I will discuss with my colleagues if this is something we would like to try to implement or if this problem is better addressed in hardware.
    Thanks a lot for all of the help,
    Thomas Gooijers
