nRF52833 MAC Address ramdonly changing while advertising
I am experiencing instances when my device (peripheral) MAC address changes randomly while the device is running and advertising.
MAC address changed during runtime from C7:2A:7D:C9:44:39 to 17:8B:E9:C7:E4:A1
MAC address reverted back from 17:8B:E9:C7:E4:A1 to C7:2A:7D:C9:44:39  after a reset/restart.
When this happens my other BLE PC application (central) cannot connect to it. However, if I reset/restart my peripheral device the original address is restored and my central can connect again. According to the Bluetooth documentation a static address does not change until a power cycle.
Below are the boot-up logs showing the 'static' address I usually see.
[00:01:16.123,107] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:01:16.123,107] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:01:16.123,138] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 2.6 Build 99
[00:01:16.123,931] <inf> bt_hci_core: Identity: C7:2A:7D:C9:44:39 (random)
[00:01:16.123,931] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1
[00:01:16.123,931] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff
According to the above log from bt_hci_core,
The MAC address is supposed to be random, yet every time I reset my device after I notice a change in its MAC address, it reverts back to the old address. This does not look like a random address. So, what is meant by 'random' in this context?
Note, I have had a look at other similar cases e.g. Case ID: 313249 but no explanation or solution has been provided yet.
I would appreciate it if you could respond as soon as possible. Thank you.
Kind regards
Mohamed
  • Hi Mohamed,
    I got it.
    Please don't hesitate to contact me if you need further help. Slight smile
    Amanda H.
  • Hi Amanda,
    Thank you. Clap
    But you still have not commented on why, before I added the option BT_LE_ADV_OPT_USE_IDENTITYmy device was sometimes changing its MAC address without going through a reset.                              According to Nordic's documentation this is not the expected behaviour.
    Kind regards
    Mohamed
    Could you explain the frequency and in what situation it changes the MAC address, in advertising or in connection? Which type of address do you use? Do you use CONFIG_BT_PRIVACY?
    Do you use a sample as a base to develop your application? If so, what is that?
    Could you provide the sniffer log and device log when you observe the MAC address change?
    -Amanda H.
  • Hi Amanda,
    As I stated in a previous message, the MAC address is very infrequent. The device can go for months without changing its address. I believe the change is occurring during advertising. The reason I noticed the change is because our proprietary application running under Windows 10 could not connect to the device anymore over BLE. So, I checked the list of BLE devices that the application can see and noticed the MAC address of the device has changed.
    The default Static Random.
    No, I am using our own application.
    Note, this is not an isolated case; other users on Devzone have experienced the same problem, see Case ID: 313249.
    It is going to be difficult because it may take months before the MAC address change can occur.
    Kind regards
    Mohamed
    That sounds so strange. With the information you provided, it's hard to say what could cause the issue. If there are device logs, sniffer logs, or reproduction instructions, they might help investigate the issue.
    Amanda H.
