Matter Temperature Sensor Output
I created a new Matter project based on the light bulb example.
I want to add several more endpoints with different commands and values.
As a way to learn how things work, I followed the example tutorial to add the temperature sensor with an on_off command to start it going and stop it.
When I commission my device to my SmartThings hub, it shows up with 2 switched as expected.
I figured out how to get the endpoint id during in the MatterPostAttributeChangeCallback.
If the endpoint is 1, then I turn the light bulb on and off. if the endpoint is 2, then i send the app event to turn the temperature sensor on and off.
My question is where am I supposed to see the random temperature reading in the UI on my Android phone that is connected to the SmartThings hub?
When I turn the light bulb on and off that on/off switch turns on and off and the LED on the dev kit turns on and off.
When I hit the switch for the temperature sensor that is simply called "switch 2", nothing happens in the UI on my phone.
When the temperature sensor is enabled, I do get a call to MatterPostAttributeChangeCallback every second, but nothing else happens.
Shouldn't the phone UI have some place for the sensor value to show up? What controls that?
