[nRF52832] how to fix k_sys_fatal_error_handler()
I made my custom board using nrf52832.
Since this will be used for peripheral, I created a new project using custom board wizard in VSCode (nRF Connect SDK) and peripheral_uart sample code.
One issue I am struggling is that my firmware keeps throwing fatal exception after bt_le_adv_start() called. (Not right after but inside for loop).
>> err code = 0 (very interesting)
k_sys_fatal_error_handler executed with reason=3
I can't find the device in the connect app. (It's things are right, it should be found)
Here's the current main.c and myboard_defconfig file.
main.c
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Bridge Service (NUS) sample
#include "uart_async_adapter.h"
#include <zephyr/types.h>
#include <zephyr/kernel.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/usb/usb_device.h>
#include <zephyr/device.h>
#include <soc.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <zephyr/settings/settings.h>
#include <stdio.h>
#define LOG_MODULE_NAME peripheral_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
static struct k_work_delayable uart_work;
struct uart_data_t
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
#if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
#else
static const struct device *const async_adapter;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static size_t aborted_len;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	static bool disable_req;
	switch (evt->type)
	case UART_TX_DONE:
		LOG_DBG("UART_TX_DONE");
		if ((evt->data.tx.len == 0) ||
			(!evt->data.tx.buf))
			return;
		if (aborted_buf)
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
							   data);
			aborted_buf = NULL;
			aborted_len = 0;
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
							   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf)
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS))
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		if (disable_req)
			return;
		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
			(evt->data.rx.buf[buf->len - 1] == '\r'))
			disable_req = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		disable_req = false;
		buf = k_malloc(sizeof(*buf));
		if (buf)
			buf->len = 0;
			LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
					   UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		LOG_DBG("UART_RX_BUF_REQUEST");
		if (buf)
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
						   data);
		if (buf->len > 0)
			k_fifo_put(&fifo_uart_rx_data, buf);
			k_free(buf);
	case UART_TX_ABORTED:
		LOG_DBG("UART_TX_ABORTED");
		if (!aborted_buf)
			aborted_buf = (uint8_t *)evt->data.tx.buf;
		aborted_len += evt->data.tx.len;
						   data);
		uart_tx(uart, &buf->data[aborted_len],
				buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf)
		buf->len = 0;
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static bool uart_test_async_api(const struct device *dev)
	const struct uart_driver_api *api =
		(const struct uart_driver_api *)dev->api;
	return (api->callback_set != NULL);
static int uart_init(void)
	int err;
	int pos;
	struct uart_data_t *rx;
	struct uart_data_t *tx;
	if (!device_is_ready(uart))
		return -ENODEV;
	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK))
		err = usb_enable(NULL);
		if (err && (err != -EALREADY))
			LOG_ERR("Failed to enable USB");
			return err;
	rx = k_malloc(sizeof(*rx));
	if (rx)
		rx->len = 0;
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart))
		/* Implement API adapter */
		uart_async_adapter_init(async_adapter, uart);
		uart = async_adapter;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err)
		k_free(rx);
		LOG_ERR("Cannot initialize UART callback");
		return err;
	if (IS_ENABLED(CONFIG_UART_LINE_CTRL))
		LOG_INF("Wait for DTR");
		while (true)
			uint32_t dtr = 0;
			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
			if (dtr)
			/* Give CPU resources to low priority threads. */
			k_sleep(K_MSEC(100));
		LOG_INF("DTR set");
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
		if (err)
			LOG_WRN("Failed to set DCD, ret code %d", err);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
		if (err)
			LOG_WRN("Failed to set DSR, ret code %d", err);
	tx = k_malloc(sizeof(*tx));
	if (tx)
		pos = snprintf(tx->data, sizeof(tx->data),
					   "Starting Nordic UART service example\r\n");
		if ((pos < 0) || (pos >= sizeof(tx->data)))
			k_free(rx);
			k_free(tx);
			LOG_ERR("snprintf returned %d", pos);
			return -ENOMEM;
		tx->len = pos;
		k_free(rx);
		return -ENOMEM;
	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
	if (err)
		k_free(rx);
		k_free(tx);
		LOG_ERR("Cannot display welcome message (err: %d)", err);
		return err;
	err = uart_rx_enable(uart, rx->data, sizeof(rx->data), 50);
	if (err)
		LOG_ERR("Cannot enable uart reception (err: %d)", err);
		/* Free the rx buffer only because the tx buffer will be handled in the callback */
		k_free(rx);
	return err;
static void connected(struct bt_conn *conn, uint8_t err)
	if (err)
		LOG_ERR("Connection failed (err %u)", err);
		return;
	LOG_INF("Connected %s", addr);
	current_conn = bt_conn_ref(conn);
	dk_set_led_on(CON_STATUS_LED);
	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
	if (auth_conn)
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn)
		bt_conn_unref(current_conn);
		current_conn = NULL;
		dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
							 enum bt_security_err err)
	if (!err)
		LOG_INF("Security changed: %s level %u", addr, level);
		LOG_WRN("Security failed: %s level %u err %d", addr,
				level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	LOG_INF("Passkey for %s: %06u", addr, passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_INF("Pairing failed conn: %s, reason %d", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed};
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
						  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	LOG_INF("Received data from: %s", addr);
	for (uint16_t pos = 0; pos != len;)
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx)
			LOG_WRN("Not able to allocate UART send data buffer");
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size)
			tx->len = tx_data_size;
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r'))
			tx->data[tx->len] = '\n';
			tx->len++;
		if (err)
			k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true)
		/* Spin for ever */
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept)
		bt_conn_auth_passkey_confirm(auth_conn);
		LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
		bt_conn_auth_cancel(auth_conn);
		LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state & has_changed;
	if (auth_conn)
		if (buttons & KEY_PASSKEY_ACCEPT)
			num_comp_reply(true);
		if (buttons & KEY_PASSKEY_REJECT)
			num_comp_reply(false);
#endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err)
		LOG_ERR("Cannot init buttons (err: %d)", err);
	err = dk_leds_init();
	if (err)
		LOG_ERR("Cannot init LEDs (err: %d)", err);
	int blink_status = 0;
	int err = 0;
	// configure_gpio();
	// err = uart_init();
	// if (err)
	// 	error();
	// if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED))
	// 	err = bt_conn_auth_cb_register(&conn_auth_callbacks);
	// 	if (err)
	// 		printk("Failed to register authorization callbacks.\n");
	// 		return;
	// 	err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	// 	if (err)
	// 		printk("Failed to register authorization info callbacks.\n");
	// 		return;
	err = bt_enable(NULL);
	if (err)
		error();
	LOG_INF("Bluetooth initialized");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS))
		settings_load();
	// err = bt_nus_init(&nus_cb);
	// if (err)
	// 	LOG_ERR("Failed to initialize UART service (err: %d)", err);
	// 	return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
						  ARRAY_SIZE(sd));
	// if (err)
	// 	LOG_ERR("Advertising failed to start (err %d)", err);
	// 	return;
	for (;;)
		// dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		// k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
		k_sleep(K_SECONDS(10)); // Sleep for 10 seconds
// void ble_write_thread(void)
// 	/* Don't go any further until BLE is initialized */
// 	k_sem_take(&ble_init_ok, K_FOREVER);
// 	for (;;)
// 		/* Wait indefinitely for data to be sent over bluetooth */
// 		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
// 											 K_FOREVER);
// 		if (bt_nus_send(NULL, buf->data, buf->len))
// 			LOG_WRN("Failed to send data over BLE connection");
// 		k_free(buf);
// K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
// 				NULL, PRIORITY, 0, 0);
custom_board_defconfig
# Copyright (c) 2023 Nordic Semiconductor ASA
CONFIG_SOC_SERIES_NRF52X=y
CONFIG_SOC_NRF52832_QFAA=y
CONFIG_BOARD_PIE_MOCAP=y
# Enable MPU
CONFIG_ARM_MPU=y
# Enable hardware stack protection
CONFIG_HW_STACK_PROTECTION=y
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_HCI=y
CONFIG_BT_CTLR=y
CONFIG_BT_LL_SW_SPLIT=y
CONFIG_BT_DEVICE_NAME="test"
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
CONFIG_ASSERT=y
# CONFIG_BT_LL_SOFTDEVICE=y
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_MAIN_STACK_SIZE=4096
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=n
CONFIG_ASSERT=y
# External 32kHz Crystal
# not enter into main.c
CONFIG_CLOCK_CONTROL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n
# solution
# https://devzone.nordicsemi.com/f/nordic-q-a/96300/programs-never-make-it-to-main/408081
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
# DCDC not LDO
CONFIG_BOARD_ENABLE_DCDC=y
# For custom board, it's essential
CONFIG_PINCTRL=y
# Special Note
# those two configuration should be custom_board_name_defconfig
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_DEBUG_THREAD_INFO=y
# https://devzone.nordicsemi.com/f/nordic-q-a/99097/zephyr-ble-samples-assert-in-bt_enable-with-zephyr-ble-controller-on-nrf52833-nrf52840-dev-kits
# CONFIG_BT_LL_SW_SPLIT=y
External 32MHz crystal soldered correctly.
How to overcome this issue? any suggestions?
