undefined reference to _open when using libc with NCS 2.4.2 and above
I am developing an application for a custom nrf52840 board. This application has been building and running without problems for nrf Connect SDK v 2.3.0
However, I recently tried to upgrade to NCS v2.5.0 and I get the below link-time error:
D:/ncs2/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/lib/thumb/v7e-m/nofp\libc.a(lib_a-openr.o): in function `_open_r':
openr.c:(.text._open_r+0x14): undefined reference to `_open'
Note that
CONFIG_NEWLIB_LIBC=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
is set in my prj.conf. I also see these lines in autoconf.h:
#define CONFIG_FULL_LIBC_SUPPORTED 1
#define CONFIG_MINIMAL_LIBC_SUPPORTED 1
#define CONFIG_NEWLIB_LIBC_SUPPORTED 1
#define CONFIG_PICOLIBC_SUPPORTED 1
#define CONFIG_NEWLIB_LIBC 1
#define CONFIG_HAS_NEWLIB_LIBC_NANO 1
I tried to downgrade to NCS 2.4.2, but it seems to have the same issue. However, no problems with NCS v2.3.0
Has something changed since NCS 2.4.2? Am I supposed to enable some other config flag as well, in order to use full newlib libc?
thanks
regards
pnc
  • I checked out zephyr HEAD (commit 3d3b287b7908625dc8356ac3532d9b6943edbb50), and tried to compile this sample for board nrf52dk_nrf52832:
    hello_world_posix.zip
    It will fail with the following output:
    $ ninja
    [1/174] Preparing syscall dependency handling
    [3/174] Generating include/generated/version.h
    -- Zephyr version: 3.5.99 (/opt/repos/upstream-zephyr/zephyr), build: zephyr-v3.5.0-2646-g3d3b287b7908
    [10/174] Building C object CMakeFiles/app.dir/src/main.c.obj
    /opt/repos/upstream-zephyr/zephyr/samples/hello_world_posix/src/main.c: In function 'main':
    /opt/repos/upstream-zephyr/zephyr/samples/hello_world_posix/src/main.c:12:15: warning: unused variable 'f' [-Wunused-variable]
       12 |         FILE *f = fopen("posix.txt", "a");
    [168/174] Linking C executable zephyr/zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /opt/repos/upstream-zephyr/zephyr/samples/hello_world_posix/build/zephyr/zephyr_pre0.map
    : && ccache /opt/zephyr-sdk/zephyr-sdk-0.16.0/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/opt/repos/upstream-zephyr/zephyr/samples/hello_world_posix/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/subsys/fs/libsubsys__fs.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/littlefs/libmodules__littlefs.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/zephyr-sdk/zephyr-sdk-0.16.0/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp"  -L/opt/repos/upstream-zephyr/zephyr/samples/hello_world_posix/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -lm  -Wl,-lc  -L"/opt/zephyr-sdk/zephyr-sdk-0.16.0/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v7e-m/nofp  -Wl,-lgcc  -lc && cd /opt/repos/upstream-zephyr/zephyr/samples/hello_world_posix/build/zephyr && /usr/bin/cmake -E true
    /opt/zephyr-sdk/zephyr-sdk-0.16.0/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/zephyr-sdk/zephyr-sdk-0.16.0/arm-zephyr-eabi/arm-zephyr-eabi/lib/thumb/v7e-m/nofp/libc.a(lib_a-openr.o): in function `_open_r':
    collect2: error: ld returned 1 exit status
    If you use picolib instead of newlib, it will compile as expected.
    You can share this in the github issue if you'd like.
    Håkon
  • Thanks Hakon,
    I have posted your response back to Zephyr :-)
    What is the approximate lead time between an issue getting fixed on Zephyr and it being incorporated into NCS? I cannot hand over the app to the internal customer until it builds with an official version of NCS.
  • Happy to help out.
    We try to align with upstream zephyr as close as we can, and do this in regular intervals.
    I unfortunately cannot state when and if this issue will be resolved, as it has a upstream dependency.
    If in the future the issue is fixed in a non-released version, ie. on main: What can be done is to patch "sdk-zephyr" (ie. NCS) manually if upstream provides a workaround or fix to the issue.
    You can use picolib instead of newlib, if that is a valid option in your project.
    Håkon
