Analog input jumps above VDD
Hey all :)
My project includes an analogue measure, and in some channels, the input goes over 57000mV in certain, probably random cases.
Of course, it's not a real input because it would fry the MCU. But how can I shield my signal from these spikes, and how do I prevent them totally?
My prj.cfg:
CONFIG_LOG=y
CONFIG_I2C=y
CONFIG_ADC=y #I know this is only the relevant one, but in case this content is worth something.
CONFIG_SFLOAT=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_DK_LIBRARY=y
My devicetree overlay:
	zephyr,user {
		io-channels = <&adc 0>, <&adc 1>, <&adc 2>, <&adc 3>;
&adc {
	#address-cells = <1>;
	#size-cells = <0>;
	channel@0 {
		reg = <0>;
		zephyr,gain = "ADC_GAIN_1_6";
		zephyr,reference = "ADC_REF_INTERNAL";
		zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
		zephyr,input-positive = <NRF_SAADC_AIN0>; /* P0.03 */
		zephyr,resolution = <12>;
	channel@1 {
		reg = <1>;
		zephyr,input-positive = <NRF_SAADC_AIN1>;
		zephyr,oversampling = <8>;
	channel@2 {
		reg = <2>;
		zephyr,input-positive = <NRF_SAADC_AIN2>; /* P0.04 */
	channel@3 {
		reg = <3>;
		zephyr,vref-mv = <750>;
		zephyr,input-positive = <NRF_SAADC_AIN3>; /* P0.30 */
My main code:
#include <zephyr/device.h>
#include <zephyr/drivers/adc.h>
#include <zephyr/kernel.h>
#include <zephyr/sys/util.h>
LOG_MODULE_REGISTER(ADC_Custom_Driver);
#if !DT_NODE_EXISTS(DT_PATH(zephyr_user)) || \
	!DT_NODE_HAS_PROP(DT_PATH(zephyr_user), io_channels)
#error "No suitable devicetree overlay specified"
#define DT_SPEC_AND_COMMA(node_id, prop, idx) \
	ADC_DT_SPEC_GET_BY_IDX(node_id, idx),
/* Data of ADC io-channels specified in devicetree. */
static const struct adc_dt_spec adc_channels[] = {
	DT_FOREACH_PROP_ELEM(DT_PATH(zephyr_user), io_channels,
			     DT_SPEC_AND_COMMA)
uint16_t buf;
struct adc_sequence sequence = {
	.buffer = &buf,
	/* buffer size in bytes, not number of samples */
	.buffer_size = sizeof(buf),
void adc_custom_channels_setup(void)
{   int err;
	/* Configure channels individually prior to sampling. */
	for (int i = 0U; i < ARRAY_SIZE(adc_channels); i++) {
		if (!device_is_ready(adc_channels[i].dev)) {
			LOG_WRN("ADC controller device not ready\n");
			return;
		err = adc_channel_setup_dt(&adc_channels[i]);
		if (err < 0) {
			LOG_ERR("Could not setup channel #%d (%d)\n", i, err);
			return;
int adc_custom_measure_channel(uint8_t idx)
	int err;
	uint16_t value;
			(void)adc_sequence_init_dt(&adc_channels[idx], &sequence);
			err = adc_read(adc_channels[idx].dev, &sequence);
			if (err < 0) {
				LOG_ERR("Could not read (%d)\n", err);
			} else {
				//LOG_INF("%"PRId16, buf);
				value = (uint16_t)buf;
				LOG_DBG("Values.channels[%d] = %d\n", idx, value);
				return value;
int adc_custom_measure_channel_mv(uint8_t idx)
	int err;
	int32_t val_mv;
				/* conversion to mV may not be supported, skip if not */
			val_mv = buf;
			err = adc_raw_to_millivolts_dt(&adc_channels[idx],
						       &val_mv);
			if (err < 0 || val_mv > 5000) {
				LOG_ERR(" (value in mV not available)\n");
			} else {
				LOG_DBG("Values_mv[%d] = %d mV\n",idx, val_mv);
				return val_mv;
I call the setup once and in a loop for the measure / measure_print methods.
Is this bug possible because I configured the functions as int and not uint16?
I'm using nRF52840 / Thingy52 (with proper overlays, of course) and NCS v2.2.0
