offsets.h No such file or directory
We have been using SDK version 2.1.1 and currently are in the process of migrating to SDK version 2.5.0.
Would be helpful to get some hint regarding what conditions can lead to the following error when building our application.
In file included from C:\ncs\v2.5.0\zephyr\include\zephyr\app_memory\app_memdomain.h:9,
from C:\ncs\v2.5.0\zephyr\include\zephyr\rtio\rtio.h:31,
from C:\ncs\v2.5.0\zephyr\include\zephyr\drivers\i2c.h:28,
from <our application.h>...
C:\ncs\v2.5.0\zephyr\include\zephyr\linker\linker-defs.h:26:10: fatal error: offsets.h: No such file or directory
26 | #include <offsets.h>
Mathi.
  • Right, there is not a lot of common things here. I tried some samples with similar ocnfigurations to what you describe, and I am not able to reproduce the error.
    Do you see the same for samples in the nRF Connect SDK?
    Are you able to send either a project zip I can build for a DK to reproduce the error? Barring that, looking at your prj.conf could be useful, so I can see if your projects have some similar features enabled.
  • Hi Sigurd
    I am not allowed to send you the complete project, but I have attached the autoconf.h, I hope this helps.
    Some more information:
    - The problem is also present on SDK 2.5.1.
    - As described, doing a fresh build fails with the "offsets.h" error during compilation of app core application. Most times a secondary build will be successful, but sometimes restarting vscode is needed for the build to be successful...
    Best regards Tonny
    #define CONFIG_LV_DPI_DEF 130
    #define CONFIG_SPI 1
    #define CONFIG_BT_HCI_ACL_FLOW_CONTROL 1
    #define CONFIG_BT_HCI_VS_EXT 1
    #define CONFIG_BOARD "X_cpuapp"
    #define CONFIG_SHARED_I2C_BUS 1
    #define CONFIG_BOARD_MAJOR_VERSION 0
    #define CONFIG_BOARD_MINOR_VERSION 6
    #define CONFIG_BOARD_VARIANT_VERSION 0
    #define CONFIG_FLASH_LOAD_SIZE 0x40000
    #define CONFIG_SRAM_SIZE 448
    #define CONFIG_FLASH_LOAD_OFFSET 0x10000
    #define CONFIG_NUM_IRQS 69
    #define CONFIG_SOC_SERIES "nrf53"
    #define CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC 32768
    #define CONFIG_SOC "nRF5340_CPUAPP_QKAA"
    #define CONFIG_CLOCK_CONTROL_INIT_PRIORITY 30
    #define CONFIG_FLASH_SIZE 1024
    #define CONFIG_FLASH_BASE_ADDRESS 0x0
    #define CONFIG_ICACHE_LINE_SIZE 32
    #define CONFIG_DCACHE_LINE_SIZE 32
    #define CONFIG_HEAP_MEM_POOL_SIZE 32769
    #define CONFIG_ROM_START_OFFSET 0x0
    #define CONFIG_PINCTRL 1
    #define CONFIG_CLOCK_CONTROL 1
    #define CONFIG_WATCHDOG 1
    #define CONFIG_GPIO 1
    #define CONFIG_SOC_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT 1
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET 1
    #define CONFIG_LOG_DOMAIN_NAME ""
    #define CONFIG_NRF_RTC_TIMER 1
    #define CONFIG_SYS_CLOCK_TICKS_PER_SEC 32768
    #define CONFIG_BUILD_OUTPUT_HEX 1
    #define CONFIG_FPU 1
    #define CONFIG_MBEDTLS 1
    #define CONFIG_TINYCRYPT 1
    #define CONFIG_MAIN_STACK_SIZE 32769
    #define CONFIG_USE_DT_CODE_PARTITION 1
    #define CONFIG_PLATFORM_SPECIFIC_INIT 1
    #define CONFIG_IDLE_STACK_SIZE 320
    #define CONFIG_TASK_WDT_HW_FALLBACK_DELAY 1000
    #define CONFIG_BT_USER_PHY_UPDATE 1
    #define CONFIG_BUILD_OUTPUT_BIN 1
    #define CONFIG_MP_MAX_NUM_CPUS 1
    #define CONFIG_HAS_DTS 1
    #define CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED 1
    #define CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED 1
    #define CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED 1
    #define CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED 1
    #define CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED 1
    #define CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_KEYS_ENABLED 1
    #define CONFIG_DT_HAS_GPIO_LEDS_ENABLED 1
    #define CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED 1
    #define CONFIG_DT_HAS_MMIO_SRAM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CC312_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED 1
    #define CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED 1
    #define CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED 1
    #define CONFIG_DT_HAS_ST_LIS2DW12_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED 1
    #define CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED 1
    #define CONFIG_NEWLIB_LIBC_NANO 1
    #define CONFIG_NUM_METAIRQ_PRIORITIES 0
    #define CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE 4096
    #define CONFIG_LOG_BUFFER_SIZE 1024
    #define CONFIG_INIT_STACKS 1
    #define CONFIG_MBEDTLS_CIPHER_MODE_CBC 1
    #define CONFIG_MBEDTLS_CIPHER_MODE_CTR 1
    #define CONFIG_MBEDTLS_CHACHA20_C 1
    #define CONFIG_MBEDTLS_POLY1305_C 1
    #define CONFIG_MBEDTLS_CHACHAPOLY_C 1
    #define CONFIG_MBEDTLS_DHM_C 1
    #define CONFIG_MBEDTLS_RSA_C 1
    #define CONFIG_MBEDTLS_SHA512_C 1
    #define CONFIG_MBEDTLS_GCM_C 1
    #define CONFIG_MBEDTLS_SSL_SRV_C 1
    #define CONFIG_MBEDTLS_SSL_COOKIE_C 1
    #define CONFIG_MBEDTLS_HEAP_SIZE 16384
    #define CONFIG_MBEDTLS_SHA1_C 1
    #define CONFIG_MBEDTLS_MAC_SHA256_ENABLED 1
    #define CONFIG_MBEDTLS_MD_C 1
    #define CONFIG_MBEDTLS_TLS_LIBRARY 1
    #define CONFIG_MBEDTLS_X509_LIBRARY 1
    #define CONFIG_MBEDTLS_ENABLE_HEAP 1
    #define CONFIG_MBEDTLS_ECP_C 1
    #define CONFIG_MBEDTLS_CMAC_C 1
    #define CONFIG_MBEDTLS_CCM_C 1
    #define CONFIG_MBEDTLS_LEGACY_CRYPTO_C 1
    #define CONFIG_BOOT_BANNER_STRING "Booting nRF Connect SDK"
    #define CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY 1
    #define CONFIG_WARN_EXPERIMENTAL 1
    #define CONFIG_PRIVILEGED_STACK_SIZE 1024
    #define CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE 384
    #define CONFIG_BT_BUF_CMD_TX_COUNT 10
    #define CONFIG_ENTROPY_GENERATOR 1
    #define CONFIG_INIT_ARCH_HW_AT_BOOT 1
    #define CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE 4096
    #define CONFIG_GETOPT 1
    #define CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE 1
    #define CONFIG_NCS_SAMPLE_HCI_RPMSG_CHILD_IMAGE 1
    #define CONFIG_UPDATEABLE_IMAGE_NUMBER 1
    #define CONFIG_NRF53_UPGRADE_NETWORK_CORE 1
    #define CONFIG_BT_L2CAP_TX_MTU 247
    #define CONFIG_BT_BUF_ACL_TX_SIZE 251
    #define CONFIG_BT_BUF_ACL_RX_SIZE 251
    #define CONFIG_PM_PARTITION_SIZE_PROVISION 0x280
    #define CONFIG_PM_PARTITION_SIZE_B0_IMAGE 0x8000
    #define CONFIG_SB_VALIDATION_INFO_MAGIC 0x86518483
    #define CONFIG_SB_VALIDATION_POINTER_MAGIC 0x6919b47e
    #define CONFIG_SB_VALIDATION_INFO_CRYPTO_ID 1
    #define CONFIG_SB_VALIDATION_INFO_VERSION 2
    #define CONFIG_SB_VALIDATION_METADATA_OFFSET 0
    #define CONFIG_SB_VALIDATE_FW_SIGNATURE 1
    #define CONFIG_BT_MAX_CONN 1
    #define CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE 1
    #define CONFIG_BT_HCI_TX_STACK_SIZE 1024
    #define CONFIG_BT_RX_STACK_SIZE 2200
    #define CONFIG_BT_GATT_DM 1
    #define CONFIG_BT_GATT_DM_MAX_ATTRS 35
    #define CONFIG_BT_GATT_DM_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_GATT_DM_LOG_LEVEL 3
    #define CONFIG_BT_DIS 1
    #define CONFIG_BT_DIS_FW_REV 1
    #define CONFIG_BT_DIS_FW_REV_STR ""
    #define CONFIG_BT_GATT_AUTO_SEC_REQ 1
    #define CONFIG_BT_DRIVERS 1
    #define CONFIG_BT_PERIPHERAL 1
    #define CONFIG_BT_BROADCASTER 1
    #define CONFIG_BT_CONN 1
    #define CONFIG_BT_PHY_UPDATE 1
    #define CONFIG_BT_DATA_LEN_UPDATE 1
    #define CONFIG_BT_DIS_SETTINGS 1
    #define CONFIG_BT_DIS_STR_MAX 144
    #define CONFIG_BT_DIS_MODEL "Y Z"
    #define CONFIG_BT_DIS_MANUF "A B"
    #define CONFIG_BT_DIS_PNP 1
    #define CONFIG_BT_DIS_PNP_VID_SRC 1
    #define CONFIG_BT_DIS_PNP_VID 0x570C
    #define CONFIG_BT_DIS_PNP_PID 0x01
    #define CONFIG_BT_DIS_PNP_VER 0x0600
    #define CONFIG_BT_DIS_SERIAL_NUMBER 1
    #define CONFIG_BT_DIS_SERIAL_NUMBER_STR ""
    #define CONFIG_BT_DIS_HW_REV 1
    #define CONFIG_BT_DIS_HW_REV_STR ""
    #define CONFIG_BT_DIS_SW_REV 1
    #define CONFIG_BT_DIS_SW_REV_STR ""
    #define CONFIG_BT_BUF_ACL_TX_COUNT 10
    #define CONFIG_BT_BUF_ACL_RX_COUNT 10
    #define CONFIG_BT_BUF_EVT_RX_SIZE 68
    #define CONFIG_BT_BUF_EVT_RX_COUNT 10
    #define CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE 43
    #define CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT 3
    #define CONFIG_BT_BUF_CMD_TX_SIZE 65
    #define CONFIG_BT_HAS_HCI_VS 1
    #define CONFIG_BT_HCI_VS 1
    #define CONFIG_BT_RPA 1
    #define CONFIG_BT_ASSERT 1
    #define CONFIG_BT_ASSERT_VERBOSE 1
    #define CONFIG_BT_DEBUG_NONE 1
    #define CONFIG_BT_LONG_WQ 1
    #define CONFIG_BT_LONG_WQ_STACK_SIZE 1300
    #define CONFIG_BT_LONG_WQ_PRIO 10
    #define CONFIG_BT_LONG_WQ_INIT_PRIO 50
    #define CONFIG_BT_HCI_HOST 1
    #define CONFIG_BT_HCI_TX_PRIO 7
    #define CONFIG_BT_HCI_RESERVE 1
    #define CONFIG_BT_RECV_WORKQ_BT 1
    #define CONFIG_BT_RX_PRIO 8
    #define CONFIG_BT_DRIVER_RX_HIGH_PRIO 6
    #define CONFIG_BT_HOST_CRYPTO 1
    #define CONFIG_BT_HOST_CRYPTO_PRNG 1
    #define CONFIG_BT_SETTINGS 1
    #define CONFIG_BT_SETTINGS_CCC_LAZY_LOADING 1
    #define CONFIG_BT_SETTINGS_DELAYED_STORE 1
    #define CONFIG_BT_SETTINGS_DELAYED_STORE_MS 1000
    #define CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE 1
    #define CONFIG_BT_SETTINGS_CF_STORE_ON_WRITE 1
    #define CONFIG_BT_SETTINGS_USE_PRINTK 1
    #define CONFIG_BT_FILTER_ACCEPT_LIST 1
    #define CONFIG_BT_LIM_ADV_TIMEOUT 30
    #define CONFIG_BT_CONN_TX_USER_DATA_SIZE 8
    #define CONFIG_BT_CONN_TX_MAX 10
    #define CONFIG_BT_USER_DATA_LEN_UPDATE 1
    #define CONFIG_BT_SMP 1
    #define CONFIG_BT_PRIVACY 1
    #define CONFIG_BT_RPA_TIMEOUT 900
    #define CONFIG_BT_SMP_SC_PAIR_ONLY 1
    #define CONFIG_BT_BONDABLE 1
    #define CONFIG_BT_BONDING_REQUIRED 1
    #define CONFIG_BT_SMP_ENFORCE_MITM 1
    #define CONFIG_BT_SMP_MIN_ENC_KEY_SIZE 7
    #define CONFIG_BT_L2CAP_TX_BUF_COUNT 10
    #define CONFIG_BT_L2CAP_TX_FRAG_COUNT 2
    #define CONFIG_BT_L2CAP_RESCHED_MS 1000
    #define CONFIG_BT_L2CAP_DYNAMIC_CHANNEL 1
    #define CONFIG_BT_ATT_ENFORCE_FLOW 1
    #define CONFIG_BT_ATT_PREPARE_COUNT 2
    #define CONFIG_BT_ATT_RETRY_ON_SEC_ERR 1
    #define CONFIG_BT_GATT_AUTO_RESUBSCRIBE 1
    #define CONFIG_BT_GATT_SERVICE_CHANGED 1
    #define CONFIG_BT_GATT_DYNAMIC_DB 1
    #define CONFIG_BT_GATT_CACHING 1
    #define CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION 1
    #define CONFIG_BT_GATT_CLIENT 1
    #define CONFIG_BT_GATT_READ_MULTIPLE 1
    #define CONFIG_BT_GATT_READ_MULT_VAR_LEN 1
    #define CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS 1
    #define CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS 1
    #define CONFIG_BT_PERIPHERAL_PREF_MIN_INT 24
    #define CONFIG_BT_PERIPHERAL_PREF_MAX_INT 40
    #define CONFIG_BT_PERIPHERAL_PREF_LATENCY 0
    #define CONFIG_BT_PERIPHERAL_PREF_TIMEOUT 42
    #define CONFIG_BT_DEVICE_NAME_GATT_WRITABLE 1
    #define CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT 1
    #define CONFIG_BT_MAX_PAIRED 1
    #define CONFIG_BT_CREATE_CONN_TIMEOUT 3
    #define CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT 5000
    #define CONFIG_BT_CONN_PARAM_RETRY_COUNT 3
    #define CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT 5000
    #define CONFIG_BT_DEVICE_NAME_DYNAMIC 1
    #define CONFIG_BT_DEVICE_NAME_MAX 28
    #define CONFIG_BT_DEVICE_NAME "Zephyr"
    #define CONFIG_BT_DEVICE_APPEARANCE 1344
    #define CONFIG_BT_ID_MAX 1
    #define CONFIG_BT_ECC 1
    #define CONFIG_BT_CRYPTO 1
    #define CONFIG_DFU_TARGET 1
    #define CONFIG_DFU_TARGET_MCUBOOT 1
    #define CONFIG_DFU_TARGET_STREAM 1
    #define CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT 1
    #define CONFIG_DFU_TARGET_LOG_LEVEL 3
    #define CONFIG_ESB_LOG_LEVEL_DEFAULT 1
    #define CONFIG_ESB_LOG_LEVEL 3
    #define CONFIG_PCD_VERSION_PAGE_BUF_SIZE 2046
    #define CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME 1
    #define CONFIG_NRF_CLOUD_CLIENT_ID "my-client-id"
    #define CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL 3
    #define CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL 1
    #define CONFIG_NRF_CLOUD_LOG_BUF_SIZE 256
    #define CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_LOG_LOG_LEVEL 3
    #define CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NRF_CLOUD_LOG_LEVEL 3
    #define CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPSL_FEM_LOG_LEVEL 3
    #define CONFIG_MPSL_THREAD_COOP_PRIO 8
    #define CONFIG_MPSL_WORK_STACK_SIZE 1024
    #define CONFIG_MPSL_TIMESLOT_SESSION_COUNT 0
    #define CONFIG_MPSL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPSL_LOG_LEVEL 3
    #define CONFIG_PARTITION_MANAGER_ENABLED 1
    #define CONFIG_FLASH_MAP_CUSTOM 1
    #define CONFIG_SRAM_BASE_ADDRESS 0x20000000
    #define CONFIG_RPMSG_NRF53_SRAM_SIZE 0x10000
    #define CONFIG_PM_PARTITION_SIZE_LITTLEFS 0x6000
    #define CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL 1
    #define CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE 0x2000
    #define CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL 1
    #define CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE 0x4000
    #define CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER 1
    #define CONFIG_PM_EXTERNAL_FLASH_BASE 0x0
    #define CONFIG_PM_EXTERNAL_FLASH_ENABLED 1
    #define CONFIG_PM_EXTERNAL_FLASH_PATH                                          \
      "/soc/peripheral@50000000/spi@a000/mx66u1g45g@0"
    #define CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS 1073741824
    #define CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY 1
    #define CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK 1
    #define CONFIG_PM_SRAM_BASE 0x20000000
    #define CONFIG_PM_SRAM_SIZE 0x80000
    #define CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MGMT_FMFU_LOG_LEVEL 3
    #define CONFIG_NORDIC_SECURITY_BACKEND 1
    #define CONFIG_NRF_SECURITY 1
    #define CONFIG_MBEDTLS_CFG_FILE "nrf-config.h"
    #define CONFIG_MBEDTLS_USER_CONFIG_FILE "nrf-config-user.h"
    #define CONFIG_GENERATE_MBEDTLS_CFG_FILE 1
    #define CONFIG_MBEDTLS_X509_USE_C 1
    #define CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE 1
    #define CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE 1
    #define CONFIG_MBEDTLS_X509_CRL_PARSE_C 1
    #define CONFIG_MBEDTLS_X509_CSR_PARSE_C 1
    #define CONFIG_MBEDTLS_X509_CRT_PARSE_C 1
    #define CONFIG_MBEDTLS_X509_REMOVE_INFO 1
    #define CONFIG_MBEDTLS_SSL_CLI_C 1
    #define CONFIG_MBEDTLS_SSL_TLS_C 1
    #define CONFIG_MBEDTLS_SSL_PROTO_TLS1_2 1
    #define CONFIG_MBEDTLS_SSL_ENCRYPT_THEN_MAC 1
    #define CONFIG_MBEDTLS_SSL_EXTENDED_MASTER_SECRET 1
    #define CONFIG_MBEDTLS_SSL_ALL_ALERT_MESSAGES 1
    #define CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION 1
    #define CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE 1
    #define CONFIG_MBEDTLS_SSL_EXPORT_KEYS 1
    #define CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN 16380
    #define CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN 16380
    #define CONFIG_MBEDTLS_SSL_CIPHERSUITES ""
    #define CONFIG_MBEDTLS_HAS_CBC_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_GCM_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_CCM_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_RSA_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_HAS_ECJPAKE_CIPHERSUITE_REQUIREMENTS 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED 1
    #define CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_C 1
    #define CONFIG_PSA_HAS_MAC_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_HMAC 1
    #define CONFIG_PSA_HAS_HASH_SUPPORT 1
    #define CONFIG_PSA_WANT_ALG_SHA_224 1
    #define CONFIG_PSA_WANT_ALG_SHA_256 1
    #define CONFIG_PSA_HAS_KEY_DERIVATION 1
    #define CONFIG_PSA_WANT_ALG_TLS12_PRF 1
    #define CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG 1
    #define CONFIG_PSA_CORE_OBERON 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS 1
    #define CONFIG_PSA_CRYPTO_ACCELERATOR_DRIVER_PRESENT 1
    #define CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT 1
    #define CONFIG_PSA_CRYPTO_DRIVER_OBERON 1
    #define CONFIG_PSA_CRYPTO_DRIVER_CC3XX 1
    #define CONFIG_PSA_USE_CC3XX_CIPHER_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_AEAD_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_HASH_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_MAC_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_ECDH_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_SIGNATURE_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_ASYMMETRIC_DRIVER 1
    #define CONFIG_PSA_USE_CC3XX_KEY_PAIR_DRIVER 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_128 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_192 1
    #define CONFIG_PSA_WANT_AES_KEY_SIZE_256 1
    #define CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 1
    #define CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 1
    #define CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 1
    #define CONFIG_PSA_MAX_RSA_KEY_BITS 3072
    #define CONFIG_PSA_ACCEL_HMAC_SHA1 1
    #define CONFIG_PSA_ACCEL_HMAC_SHA224 1
    #define CONFIG_PSA_ACCEL_HMAC_SHA256 1
    #define CONFIG_PSA_ACCEL_SHA224 1
    #define CONFIG_PSA_ACCEL_SHA256 1
    #define CONFIG_PSA_NEED_CC3XX_SHA_224 1
    #define CONFIG_PSA_NEED_CC3XX_SHA_256 1
    #define CONFIG_PSA_NEED_CC3XX_HASH_DRIVER 1
    #define CONFIG_PSA_NEED_CC3XX_RSA_KEY_SIZE_1024 1
    #define CONFIG_PSA_NEED_CC3XX_RSA_KEY_SIZE_2048 1
    #define CONFIG_PSA_NEED_CC3XX_RSA_KEY_SIZE_3072 1
    #define CONFIG_PSA_NEED_CC3XX_KEY_PAIR_RSA 1
    #define CONFIG_PSA_NEED_CC3XX_KEY_PAIR_DRIVER 1
    #define CONFIG_PSA_NEED_CC3XX_HMAC 1
    #define CONFIG_PSA_NEED_CC3XX_MAC_DRIVER 1
    #define CONFIG_PSA_NEED_OBERON_TLS12_PRF 1
    #define CONFIG_PSA_NEED_OBERON_TLS12_PSK_TO_MS 1
    #define CONFIG_PSA_NEED_OBERON_KDF_DRIVER 1
    #define CONFIG_MBEDTLS_USE_PSA_CRYPTO 1
    #define CONFIG_MBEDTLS_PLATFORM_MEMORY 1
    #define CONFIG_MBEDTLS_PLATFORM_C 1
    #define CONFIG_MBEDTLS_MEMORY_C 1
    #define CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C 1
    #define CONFIG_MBEDTLS_THREADING_C 1
    #define CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT 1
    #define CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT 1
    #define CONFIG_MBEDTLS_THREADING_ALT 1
    #define CONFIG_MBEDTLS_PLATFORM_ZEROIZE_ALT 1
    #define CONFIG_MBEDTLS_AES_ALT 1
    #define CONFIG_MBEDTLS_CMAC_ALT 1
    #define CONFIG_MBEDTLS_CCM_ALT 1
    #define CONFIG_MBEDTLS_GCM_ALT 1
    #define CONFIG_MBEDTLS_CHACHA20_ALT 1
    #define CONFIG_MBEDTLS_POLY1305_ALT 1
    #define CONFIG_MBEDTLS_CHACHAPOLY_ALT 1
    #define CONFIG_MBEDTLS_DHM_ALT 1
    #define CONFIG_MBEDTLS_ECP_ALT 1
    #define CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT 1
    #define CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_GENKEY_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_SIGN_ALT 1
    #define CONFIG_MBEDTLS_ECDSA_VERIFY_ALT 1
    #define CONFIG_MBEDTLS_RSA_ALT 1
    #define CONFIG_MBEDTLS_SHA1_ALT 1
    #define CONFIG_MBEDTLS_SHA224_ALT 1
    #define CONFIG_MBEDTLS_SHA256_ALT 1
    #define CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256 1
    #define CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES 1
    #define CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY 1
    #define CONFIG_CC312_ONLY_ENABLED 1
    #define CONFIG_MBEDTLS_MPI_WINDOW_SIZE 6
    #define CONFIG_MBEDTLS_MPI_MAX_SIZE 384
    #define CONFIG_CC312_BACKEND 1
    #define CONFIG_MBEDTLS_HMAC_DRBG_C 1
    #define CONFIG_MBEDTLS_AES_C 1
    #define CONFIG_MBEDTLS_CIPHER_PADDING_PKCS7 1
    #define CONFIG_MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS 1
    #define CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN 1
    #define CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS 1
    #define CONFIG_MBEDTLS_ECDH_C 1
    #define CONFIG_MBEDTLS_ECDSA_C 1
    #define CONFIG_MBEDTLS_ECJPAKE_C 1
    #define CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED 1
    #define CONFIG_MBEDTLS_HKDF_C 1
    #define CONFIG_MBEDTLS_GENPRIME 1
    #define CONFIG_MBEDTLS_PKCS1_V15 1
    #define CONFIG_MBEDTLS_PKCS1_V21 1
    #define CONFIG_MBEDTLS_SHA224_C 1
    #define CONFIG_MBEDTLS_SHA256_C 1
    #define CONFIG_MBEDTLS_SHA384_C 1
    #define CONFIG_MBEDTLS_CIPHER_C 1
    #define CONFIG_MBEDTLS_PK_C 1
    #define CONFIG_MBEDTLS_PKCS5_C 1
    #define CONFIG_MBEDTLS_PK_PARSE_C 1
    #define CONFIG_TFM_CONN_HANDLE_MAX_NUM 8
    #define CONFIG_POSIX_MAX_FDS 4
    #define CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BLE_HCI_VSC_LOG_LEVEL 3
    #define CONFIG_NRF_SPU_FLASH_REGION_SIZE 0x4000
    #define CONFIG_FPROTECT_BLOCK_SIZE 0x4000
    #define CONFIG_MODEM_BATTERY_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MODEM_BATTERY_LOG_LEVEL 3
    #define CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE 0x0
    #define CONFIG_ENTROPY_CC3XX 1
    #define CONFIG_HW_CC3XX 1
    #define CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS 1
    #define CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS 1
    #define CONFIG_ZEPHYR_NRF_MODULE 1
    #define CONFIG_WFA_QT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_WFA_QT_LOG_LEVEL 3
    #define CONFIG_WFA_QT_THREAD_STACK_SIZE 4096
    #define CONFIG_ZEPHYR_WFA_QT_CONTROL_APP_MODULE 1
    #define CONFIG_SIGN_IMAGES 1
    #define CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE 1
    #define CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_DT_FLASH_WRITE_BLOCK_SIZE 4
    #define CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS 1
    #define CONFIG_ZEPHYR_MCUBOOT_MODULE 1
    #define CONFIG_ZEPHYR_MBEDTLS_MODULE 1
    #define CONFIG_DISABLE_MBEDTLS_BUILTIN 1
    #define CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MBEDTLS_LOG_LEVEL 3
    #define CONFIG_MBEDTLS_INIT 1
    #define CONFIG_APP_LINK_WITH_MBEDTLS 1
    #define CONFIG_BOOTLOADER_MCUBOOT 1
    #define CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE 1
    #define CONFIG_ZEPHYR_CJSON_MODULE 1
    #define CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE 1
    #define CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE 1
    #define CONFIG_ZEPHYR_OPENTHREAD_MODULE 1
    #define CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE 1
    #define CONFIG_ZEPHYR_CANOPENNODE_MODULE 1
    #define CONFIG_ZEPHYR_CHRE_MODULE 1
    #define CONFIG_HAS_CMSIS_CORE 1
    #define CONFIG_HAS_CMSIS_CORE_M 1
    #define CONFIG_ZEPHYR_CMSIS_MODULE 1
    #define CONFIG_ZEPHYR_FATFS_MODULE 1
    #define CONFIG_ZEPHYR_HAL_NORDIC_MODULE 1
    #define CONFIG_HAS_NORDIC_DRIVERS 1
    #define CONFIG_HAS_NRFX 1
    #define CONFIG_NRFX_CLOCK 1
    #define CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED 1
    #define CONFIG_NRFX_DPPI 1
    #define CONFIG_NRFX_GPIOTE 1
    #define CONFIG_NRFX_IPC 1
    #define CONFIG_NRFX_NVMC 1
    #define CONFIG_NRFX_PWM 1
    #define CONFIG_NRFX_PWM0 1
    #define CONFIG_NRFX_SPIM 1
    #define CONFIG_NRFX_SPIM1 1
    #define CONFIG_NRFX_SPIM3 1
    #define CONFIG_NRFX_SPIM4 1
    #define CONFIG_NRFX_TWIM 1
    #define CONFIG_NRFX_TWIM2 1
    #define CONFIG_NRFX_WDT 1
    #define CONFIG_NRFX_WDT0 1
    #define CONFIG_NRFX_WDT1 1
    #define CONFIG_ZEPHYR_LIBLC3_MODULE 1
    #define CONFIG_ZEPHYR_LITTLEFS_MODULE 1
    #define CONFIG_ZEPHYR_LORAMAC_NODE_MODULE 1
    #define CONFIG_LV_COLOR_DEPTH_16 1
    #define CONFIG_LV_COLOR_DEPTH 16
    #define CONFIG_LV_COLOR_MIX_ROUND_OFS 128
    #define CONFIG_LV_COLOR_CHROMA_KEY_HEX 0x00FF00
    #define CONFIG_LV_MEM_SIZE_KILOBYTES 32
    #define CONFIG_LV_MEM_ADDR 0x0
    #define CONFIG_LV_MEM_BUF_MAX_NUM 16
    #define CONFIG_LV_DISP_DEF_REFR_PERIOD 30
    #define CONFIG_LV_INDEV_DEF_READ_PERIOD 30
    #define CONFIG_LV_DRAW_COMPLEX 1
    #define CONFIG_LV_SHADOW_CACHE_SIZE 0
    #define CONFIG_LV_CIRCLE_CACHE_SIZE 4
    #define CONFIG_LV_LAYER_SIMPLE_BUF_SIZE 24576
    #define CONFIG_LV_IMG_CACHE_DEF_SIZE 0
    #define CONFIG_LV_GRADIENT_MAX_STOPS 2
    #define CONFIG_LV_GRAD_CACHE_DEF_SIZE 0
    #define CONFIG_LV_DISP_ROT_MAX_BUF 10240
    #define CONFIG_LV_USE_ASSERT_NULL 1
    #define CONFIG_LV_USE_ASSERT_MALLOC 1
    #define CONFIG_LV_ASSERT_HANDLER_INCLUDE "assert.h"
    #define CONFIG_LV_USE_USER_DATA 1
    #define CONFIG_LV_ATTRIBUTE_MEM_ALIGN_SIZE 1
    #define CONFIG_LV_FONT_MONTSERRAT_14 1
    #define CONFIG_LV_FONT_DEFAULT_MONTSERRAT_14 1
    #define CONFIG_LV_USE_FONT_PLACEHOLDER 1
    #define CONFIG_LV_TXT_ENC_UTF8 1
    #define CONFIG_LV_TXT_BREAK_CHARS " ,.;:-_"
    #define CONFIG_LV_TXT_LINE_BREAK_LONG_LEN 0
    #define CONFIG_LV_TXT_COLOR_CMD "#"
    #define CONFIG_LV_USE_ARC 1
    #define CONFIG_LV_USE_BAR 1
    #define CONFIG_LV_USE_BTN 1
    #define CONFIG_LV_USE_BTNMATRIX 1
    #define CONFIG_LV_USE_CANVAS 1
    #define CONFIG_LV_USE_CHECKBOX 1
    #define CONFIG_LV_USE_DROPDOWN 1
    #define CONFIG_LV_USE_IMG 1
    #define CONFIG_LV_USE_LABEL 1
    #define CONFIG_LV_LABEL_TEXT_SELECTION 1
    #define CONFIG_LV_LABEL_LONG_TXT_HINT 1
    #define CONFIG_LV_USE_LINE 1
    #define CONFIG_LV_USE_ROLLER 1
    #define CONFIG_LV_ROLLER_INF_PAGES 7
    #define CONFIG_LV_USE_SLIDER 1
    #define CONFIG_LV_USE_SWITCH 1
    #define CONFIG_LV_USE_TEXTAREA 1
    #define CONFIG_LV_TEXTAREA_DEF_PWD_SHOW_TIME 1500
    #define CONFIG_LV_USE_TABLE 1
    #define CONFIG_LV_USE_ANIMIMG 1
    #define CONFIG_LV_USE_CALENDAR 1
    #define CONFIG_LV_USE_CALENDAR_HEADER_ARROW 1
    #define CONFIG_LV_USE_CALENDAR_HEADER_DROPDOWN 1
    #define CONFIG_LV_USE_CHART 1
    #define CONFIG_LV_USE_COLORWHEEL 1
    #define CONFIG_LV_USE_IMGBTN 1
    #define CONFIG_LV_USE_KEYBOARD 1
    #define CONFIG_LV_USE_LED 1
    #define CONFIG_LV_USE_LIST 1
    #define CONFIG_LV_USE_MENU 1
    #define CONFIG_LV_USE_METER 1
    #define CONFIG_LV_USE_MSGBOX 1
    #define CONFIG_LV_USE_SPAN 1
    #define CONFIG_LV_SPAN_SNIPPET_STACK_SIZE 64
    #define CONFIG_LV_USE_SPINBOX 1
    #define CONFIG_LV_USE_SPINNER 1
    #define CONFIG_LV_USE_TABVIEW 1
    #define CONFIG_LV_USE_TILEVIEW 1
    #define CONFIG_LV_USE_WIN 1
    #define CONFIG_LV_USE_THEME_DEFAULT 1
    #define CONFIG_LV_THEME_DEFAULT_GROW 1
    #define CONFIG_LV_THEME_DEFAULT_TRANSITION_TIME 80
    #define CONFIG_LV_USE_THEME_BASIC 1
    #define CONFIG_LV_USE_FLEX 1
    #define CONFIG_LV_USE_GRID 1
    #define CONFIG_LV_USE_SNAPSHOT 1
    #define CONFIG_LV_BUILD_EXAMPLES 1
    #define CONFIG_ZEPHYR_LVGL_MODULE 1
    #define CONFIG_ZEPHYR_LZ4_MODULE 1
    #define CONFIG_ZEPHYR_NANOPB_MODULE 1
    #define CONFIG_NANOPB 1
    #define CONFIG_NANOPB_MAX_REQUIRED_FIELDS 64
    #define CONFIG_ZEPHYR_PICOLIBC_MODULE 1
    #define CONFIG_ZEPHYR_SEGGER_MODULE 1
    #define CONFIG_HAS_SEGGER_RTT 1
    #define CONFIG_USE_SEGGER_RTT 1
    #define CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS 3
    #define CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS 3
    #define CONFIG_SEGGER_RTT_BUFFER_SIZE_UP 1024
    #define CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN 32
    #define CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE 64
    #define CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP 1
    #define CONFIG_SEGGER_RTT_MODE 0
    #define CONFIG_SEGGER_RTT_SECTION_NONE 1
    #define CONFIG_ZEPHYR_TRACEZ_MODULE 1
    #define CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE 1
    #define CONFIG_ZEPHYR_ZCBOR_MODULE 1
    #define CONFIG_ZCBOR 1
    #define CONFIG_ZCBOR_ASSERT 1
    #define CONFIG_ZEPHYR_ZSCILIB_MODULE 1
    #define CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE 0x4e8
    #define CONFIG_NRFXLIB_CRYPTO 1
    #define CONFIG_CRYPTOCELL_CC312_USABLE 1
    #define CONFIG_CRYPTOCELL_USABLE 1
    #define CONFIG_NRF_CC3XX_PLATFORM 1
    #define CONFIG_CC3XX_MUTEX_LOCK 1
    #define CONFIG_NRF_802154_SOURCE_NRFXLIB 1
    #define CONFIG_LC3_ENC_CHAN_MAX 1
    #define CONFIG_LC3_DEC_CHAN_MAX 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT 1
    #define CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT 1
    #define CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT 1
    #define CONFIG_ZEPHYR_NRFXLIB_MODULE 1
    #define CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE 1
    #define CONFIG_LIBMETAL 1
    #define CONFIG_LIBMETAL_SRC_PATH "libmetal"
    #define CONFIG_OPENAMP 1
    #define CONFIG_OPENAMP_SRC_PATH "open-amp"
    #define CONFIG_OPENAMP_MASTER 1
    #define CONFIG_OPENAMP_SLAVE 1
    #define CONFIG_TINYCRYPT_SHA256 1
    #define CONFIG_TINYCRYPT_SHA256_HMAC 1
    #define CONFIG_TINYCRYPT_SHA256_HMAC_PRNG 1
    #define CONFIG_TINYCRYPT_AES 1
    #define CONFIG_TINYCRYPT_AES_CMAC 1
    #define CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS "--quiet"
    #define CONFIG_MCUBOOT_SIGNATURE_KEY_FILE ""
    #define CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION "3.1.7+0"
    #define CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS ""
    #define CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH 1
    #define CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB 1
    #define CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUBOOT_UTIL_LOG_LEVEL 3
    #define CONFIG_BOOT_IMAGE_ACCESS_HOOKS 1
    #define CONFIG_BOARD_REVISION "0.6.0"
    #define CONFIG_BOARD_X_CPUAPP 1
    #define CONFIG_BOARD_ENABLE_DCDC_APP 1
    #define CONFIG_BOARD_ENABLE_DCDC_NET 1
    #define CONFIG_BOARD_ENABLE_DCDC_HV 1
    #define CONFIG_BOARD_ENABLE_CPUNET 1
    #define CONFIG_DOMAIN_CPUNET_BOARD "X_cpunet"
    #define CONFIG_SOC_SERIES_NRF53X 1
    #define CONFIG_CPU_HAS_ARM_MPU 1
    #define CONFIG_CPU_HAS_NRF_IDAU 1
    #define CONFIG_NRF_SPU_RAM_REGION_SIZE 0x2000
    #define CONFIG_HAS_SWO 1
    #define CONFIG_SOC_FAMILY "nordic_nrf"
    #define CONFIG_GPIO_INIT_PRIORITY 40
    #define CONFIG_SOC_FAMILY_NRF 1
    #define CONFIG_HAS_HW_NRF_CC312 1
    #define CONFIG_HAS_HW_NRF_CLOCK 1
    #define CONFIG_HAS_HW_NRF_CTRLAP 1
    #define CONFIG_HAS_HW_NRF_DCNF 1
    #define CONFIG_HAS_HW_NRF_DPPIC 1
    #define CONFIG_HAS_HW_NRF_EGU0 1
    #define CONFIG_HAS_HW_NRF_EGU1 1
    #define CONFIG_HAS_HW_NRF_EGU2 1
    #define CONFIG_HAS_HW_NRF_EGU3 1
    #define CONFIG_HAS_HW_NRF_EGU4 1
    #define CONFIG_HAS_HW_NRF_EGU5 1
    #define CONFIG_HAS_HW_NRF_GPIO0 1
    #define CONFIG_HAS_HW_NRF_GPIO1 1
    #define CONFIG_HAS_HW_NRF_GPIOTE 1
    #define CONFIG_HAS_HW_NRF_IPC 1
    #define CONFIG_HAS_HW_NRF_KMU 1
    #define CONFIG_HAS_HW_NRF_MUTEX 1
    #define CONFIG_HAS_HW_NRF_NFCT 1
    #define CONFIG_HAS_HW_NRF_NVMC_PE 1
    #define CONFIG_HAS_HW_NRF_OSCILLATORS 1
    #define CONFIG_HAS_HW_NRF_POWER 1
    #define CONFIG_HAS_HW_NRF_REGULATORS 1
    #define CONFIG_HAS_HW_NRF_RESET 1
    #define CONFIG_HAS_HW_NRF_SAADC 1
    #define CONFIG_HAS_HW_NRF_SPIM1 1
    #define CONFIG_HAS_HW_NRF_SPIM3 1
    #define CONFIG_HAS_HW_NRF_SPIM4 1
    #define CONFIG_HAS_HW_NRF_SPU 1
    #define CONFIG_HAS_HW_NRF_TIMER0 1
    #define CONFIG_HAS_HW_NRF_TIMER1 1
    #define CONFIG_HAS_HW_NRF_TIMER2 1
    #define CONFIG_HAS_HW_NRF_TWIM2 1
    #define CONFIG_HAS_HW_NRF_USBREG 1
    #define CONFIG_HAS_HW_NRF_VMC 1
    #define CONFIG_HAS_HW_NRF_WDT0 1
    #define CONFIG_HAS_HW_NRF_WDT1 1
    #define CONFIG_SOC_NRF5340_CPUAPP 1
    #define CONFIG_SOC_NRF5340_CPUAPP_QKAA 1
    #define CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED 1
    #define CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND 1
    #define CONFIG_SOC_NRF53_RTC_PRETICK 1
    #define CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET 10
    #define CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET 11
    #define CONFIG_SOC_DCDC_NRF53X_APP 1
    #define CONFIG_SOC_DCDC_NRF53X_NET 1
    #define CONFIG_SOC_DCDC_NRF53X_HV 1
    #define CONFIG_SOC_ENABLE_LFXO 1
    #define CONFIG_SOC_LFXO_CAP_INT_7PF 1
    #define CONFIG_SOC_HFXO_CAP_DEFAULT 1
    #define CONFIG_NRF_ENABLE_CACHE 1
    #define CONFIG_NRF53_SYNC_RTC 1
    #define CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SYNC_RTC_LOG_LEVEL 3
    #define CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY 90
    #define CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT 1
    #define CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP 1
    #define CONFIG_NRF53_SYNC_RTC_IPM_OUT 7
    #define CONFIG_NRF53_SYNC_RTC_IPM_IN 8
    #define CONFIG_IPM_MSG_CH_8_ENABLE 1
    #define CONFIG_IPM_MSG_CH_8_RX 1
    #define CONFIG_NRF_SOC_SECURE_SUPPORTED 1
    #define CONFIG_NRF_APPROTECT_USE_UICR 1
    #define CONFIG_NRF_SECURE_APPROTECT_USE_UICR 1
    #define CONFIG_SOC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SOC_LOG_LEVEL 3
    #define CONFIG_SOC_COMPATIBLE_NRF 1
    #define CONFIG_SOC_COMPATIBLE_NRF53X 1
    #define CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP 1
    #define CONFIG_ARCH "arm"
    #define CONFIG_CPU_CORTEX 1
    #define CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK 1
    #define CONFIG_CPU_CORTEX_M 1
    #define CONFIG_ISA_THUMB2 1
    #define CONFIG_ASSEMBLER_ISA_THUMB2 1
    #define CONFIG_COMPILER_ISA_THUMB2 1
    #define CONFIG_STACK_ALIGN_DOUBLE_WORD 1
    #define CONFIG_FAULT_DUMP 2
    #define CONFIG_BUILTIN_STACK_GUARD 1
    #define CONFIG_ARM_STACK_PROTECTION 1
    #define CONFIG_ARM_STORE_EXC_RETURN 1
    #define CONFIG_FP_HARDABI 1
    #define CONFIG_FP16 1
    #define CONFIG_FP16_IEEE 1
    #define CONFIG_CPU_CORTEX_M33 1
    #define CONFIG_CPU_CORTEX_M_HAS_SYSTICK 1
    #define CONFIG_CPU_CORTEX_M_HAS_DWT 1
    #define CONFIG_CPU_CORTEX_M_HAS_BASEPRI 1
    #define CONFIG_CPU_CORTEX_M_HAS_VTOR 1
    #define CONFIG_CPU_CORTEX_M_HAS_SPLIM 1
    #define CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS 1
    #define CONFIG_CPU_CORTEX_M_HAS_CMSE 1
    #define CONFIG_ARMV7_M_ARMV8_M_MAINLINE 1
    #define CONFIG_ARMV8_M_MAINLINE 1
    #define CONFIG_ARMV8_M_SE 1
    #define CONFIG_ARMV7_M_ARMV8_M_FP 1
    #define CONFIG_ARMV8_M_DSP 1
    #define CONFIG_GEN_ISR_TABLES 1
    #define CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE 1
    #define CONFIG_ARM_TRUSTZONE_M 1
    #define CONFIG_GEN_IRQ_VECTOR_TABLE 1
    #define CONFIG_ARM_MPU 1
    #define CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE 32
    #define CONFIG_MPU_ALLOW_FLASH_WRITE 1
    #define CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE 32
    #define CONFIG_ARM 1
    #define CONFIG_ARCH_IS_SET 1
    #define CONFIG_ARCH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_ARCH_LOG_LEVEL 3
    #define CONFIG_LITTLE_ENDIAN 1
    #define CONFIG_HW_STACK_PROTECTION 1
    #define CONFIG_KOBJECT_TEXT_AREA 256
    #define CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT 100
    #define CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES 16
    #define CONFIG_GEN_PRIV_STACKS 1
    #define CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN 4
    #define CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS 1
    #define CONFIG_GEN_SW_ISR_TABLE 1
    #define CONFIG_ARCH_SW_ISR_TABLE_ALIGN 4
    #define CONFIG_GEN_IRQ_START_VECTOR 0
    #define CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT 1
    #define CONFIG_ARCH_HAS_TIMING_FUNCTIONS 1
    #define CONFIG_ARCH_HAS_TRUSTED_EXECUTION 1
    #define CONFIG_ARCH_HAS_STACK_PROTECTION 1
    #define CONFIG_ARCH_HAS_USERSPACE 1
    #define CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT 1
    #define CONFIG_ARCH_HAS_RAMFUNC_SUPPORT 1
    #define CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION 1
    #define CONFIG_ARCH_SUPPORTS_COREDUMP 1
    #define CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT 1
    #define CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO 1
    #define CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_ARCH_HAS_SUSPEND_TO_RAM 1
    #define CONFIG_ARCH_HAS_THREAD_ABORT 1
    #define CONFIG_ARCH_HAS_CODE_DATA_RELOCATION 1
    #define CONFIG_CPU_HAS_TEE 1
    #define CONFIG_CPU_HAS_FPU 1
    #define CONFIG_CPU_HAS_MPU 1
    #define CONFIG_MPU 1
    #define CONFIG_MPU_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MPU_LOG_LEVEL 3
    #define CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS 1
    #define CONFIG_MPU_GAP_FILLING 1
    #define CONFIG_SRAM_REGION_PERMISSIONS 1
    #define CONFIG_FPU_SHARING 1
    #define CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS 1
    #define CONFIG_KERNEL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_KERNEL_LOG_LEVEL 3
    #define CONFIG_MULTITHREADING 1
    #define CONFIG_NUM_COOP_PRIORITIES 16
    #define CONFIG_NUM_PREEMPT_PRIORITIES 15
    #define CONFIG_MAIN_THREAD_PRIORITY 0
    #define CONFIG_COOP_ENABLED 1
    #define CONFIG_PREEMPT_ENABLED 1
    #define CONFIG_PRIORITY_CEILING -127
    #define CONFIG_ISR_STACK_SIZE 2048
    #define CONFIG_THREAD_STACK_INFO 1
    #define CONFIG_ERRNO 1
    #define CONFIG_SCHED_DUMB 1
    #define CONFIG_WAITQ_DUMB 1
    #define CONFIG_BOOT_BANNER 1
    #define CONFIG_BOOT_DELAY 0
    #define CONFIG_THREAD_MONITOR 1
    #define CONFIG_THREAD_NAME 1
    #define CONFIG_THREAD_MAX_NAME_LEN 32
    #define CONFIG_SYSTEM_WORKQUEUE_PRIORITY -1
    #define CONFIG_BARRIER_OPERATIONS_ARCH 1
    #define CONFIG_ATOMIC_OPERATIONS_BUILTIN 1
    #define CONFIG_TIMESLICING 1
    #define CONFIG_TIMESLICE_SIZE 0
    #define CONFIG_TIMESLICE_PRIORITY 0
    #define CONFIG_POLL 1
    #define CONFIG_NUM_MBOX_ASYNC_MSGS 10
    #define CONFIG_KERNEL_MEM_POOL 1
    #define CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN 1
    #define CONFIG_SWAP_NONATOMIC 1
    #define CONFIG_SYS_CLOCK_EXISTS 1
    #define CONFIG_TIMEOUT_64BIT 1
    #define CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS 365
    #define CONFIG_XIP 1
    #define CONFIG_KERNEL_INIT_PRIORITY_OBJECTS 30
    #define CONFIG_KERNEL_INIT_PRIORITY_DEFAULT 40
    #define CONFIG_KERNEL_INIT_PRIORITY_DEVICE 50
    #define CONFIG_APPLICATION_INIT_PRIORITY 90
    #define CONFIG_STACK_POINTER_RANDOM 0
    #define CONFIG_MP_NUM_CPUS 1
    #define CONFIG_TICKLESS_KERNEL 1
    #define CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_BT_RPMSG 1
    #define CONFIG_BT_DRV_TX_STACK_SIZE 256
    #define CONFIG_BT_DRV_RX_STACK_SIZE 256
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CLOCK_CONTROL_LOG_LEVEL 3
    #define CONFIG_CLOCK_CONTROL_NRF 1
    #define CONFIG_CLOCK_CONTROL_NRF_SHELL 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL 1
    #define CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM 1
    #define CONFIG_CLOCK_CONTROL_NRF_ACCURACY 50
    #define CONFIG_CONSOLE 1
    #define CONFIG_CONSOLE_INPUT_MAX_LINE_LEN 128
    #define CONFIG_CONSOLE_HAS_DRIVER 1
    #define CONFIG_CONSOLE_INIT_PRIORITY 40
    #define CONFIG_RTT_CONSOLE 1
    #define CONFIG_RTT_TX_RETRY_CNT 2
    #define CONFIG_RTT_TX_RETRY_DELAY_MS 2
    #define CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_UART_CONSOLE_LOG_LEVEL 3
    #define CONFIG_ENTROPY_LOG_LEVEL_DEFAULT 1
    #define CONFIG_ENTROPY_LOG_LEVEL 3
    #define CONFIG_ENTROPY_INIT_PRIORITY 50
    #define CONFIG_ENTROPY_BT_HCI 1
    #define CONFIG_ENTROPY_HAS_DRIVER 1
    #define CONFIG_FLASH_HAS_DRIVER_ENABLED 1
    #define CONFIG_FLASH_HAS_PAGE_LAYOUT 1
    #define CONFIG_FLASH_JESD216 1
    #define CONFIG_FLASH 1
    #define CONFIG_FLASH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_FLASH_LOG_LEVEL 3
    #define CONFIG_FLASH_SHELL 1
    #define CONFIG_FLASH_SHELL_BUFFER_SIZE 0x1000
    #define CONFIG_FLASH_PAGE_LAYOUT 1
    #define CONFIG_FLASH_INIT_PRIORITY 50
    #define CONFIG_SOC_FLASH_NRF 1
    #define CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE 1
    #define CONFIG_SPI_NOR 1
    #define CONFIG_SPI_NOR_SFDP_MINIMAL 1
    #define CONFIG_SPI_NOR_INIT_PRIORITY 80
    #define CONFIG_SPI_NOR_CS_WAIT_DELAY 0
    #define CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE 4096
    #define CONFIG_GPIO_LOG_LEVEL_DEFAULT 1
    #define CONFIG_GPIO_LOG_LEVEL 3
    #define CONFIG_GPIO_NRFX 1
    #define CONFIG_GPIO_NRFX_INTERRUPT 1
    #define CONFIG_I2C 1
    #define CONFIG_I2C_SHELL 1
    #define CONFIG_I2C_NRFX 1
    #define CONFIG_I2C_NRFX_TWIM 1
    #define CONFIG_I2C_NRFX_TRANSFER_TIMEOUT 500
    #define CONFIG_I2C_INIT_PRIORITY 50
    #define CONFIG_I2C_LOG_LEVEL_DEFAULT 1
    #define CONFIG_I2C_LOG_LEVEL 3
    #define CONFIG_INTC_INIT_PRIORITY 40
    #define CONFIG_INTC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_INTC_LOG_LEVEL 3
    #define CONFIG_1ST_LEVEL_INTERRUPT_BITS 8
    #define CONFIG_2ND_LEVEL_INTERRUPT_BITS 8
    #define CONFIG_3RD_LEVEL_INTERRUPT_BITS 8
    #define CONFIG_MBOX 1
    #define CONFIG_MBOX_NRFX_IPC 1
    #define CONFIG_MBOX_INIT_PRIORITY 40
    #define CONFIG_MBOX_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MBOX_LOG_LEVEL 3
    #define CONFIG_PINCTRL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_PINCTRL_LOG_LEVEL 3
    #define CONFIG_PINCTRL_STORE_REG 1
    #define CONFIG_PINCTRL_NRF 1
    #define CONFIG_SPI_INIT_PRIORITY 70
    #define CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE 200
    #define CONFIG_SPI_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SPI_LOG_LEVEL 3
    #define CONFIG_SPI_NRFX 1
    #define CONFIG_SPI_NRFX_SPIM 1
    #define CONFIG_SPI_NRFX_RAM_BUFFER_SIZE 8
    #define CONFIG_SPI_NRFX_WAKE_TIMEOUT_US 200
    #define CONFIG_SYSTEM_CLOCK_INIT_PRIORITY 0
    #define CONFIG_TICKLESS_CAPABLE 1
    #define CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT 1
    #define CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY 1
    #define CONFIG_USBC_LOG_LEVEL_DEFAULT 1
    #define CONFIG_USBC_LOG_LEVEL 3
    #define CONFIG_WDT_DISABLE_AT_BOOT 1
    #define CONFIG_WDT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_WDT_LOG_LEVEL 3
    #define CONFIG_WDT_NRFX 1
    #define CONFIG_WDT_SHELL 1
    #define CONFIG_FULL_LIBC_SUPPORTED 1
    #define CONFIG_MINIMAL_LIBC_SUPPORTED 1
    #define CONFIG_NEWLIB_LIBC_SUPPORTED 1
    #define CONFIG_PICOLIBC_SUPPORTED 1
    #define CONFIG_NEWLIB_LIBC 1
    #define CONFIG_HAS_NEWLIB_LIBC_NANO 1
    #define CONFIG_COMMON_LIBC_ABORT 1
    #define CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE 2048
    #define CONFIG_STDOUT_CONSOLE 1
    #define CONFIG_CPP 1
    #define CONFIG_STD_CPP20 1
    #define CONFIG_FULL_LIBCPP_SUPPORTED 1
    #define CONFIG_GLIBCXX_LIBCPP 1
    #define CONFIG_CPP_STATIC_INIT_GNU 1
    #define CONFIG_CRC 1
    #define CONFIG_RING_BUFFER 1
    #define CONFIG_NOTIFY 1
    #define CONFIG_BASE64 1
    #define CONFIG_MPSC_PBUF 1
    #define CONFIG_ONOFF 1
    #define CONFIG_REBOOT 1
    #define CONFIG_HAS_POWEROFF 1
    #define CONFIG_POWEROFF 1
    #define CONFIG_CBPRINTF_COMPLETE 1
    #define CONFIG_CBPRINTF_FULL_INTEGRAL 1
    #define CONFIG_CBPRINTF_FP_SUPPORT 1
    #define CONFIG_CBPRINTF_N_SPECIFIER 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL 3
    #define CONFIG_SYS_HEAP_ALLOC_LOOPS 3
    #define CONFIG_SYS_HEAP_AUTO 1
    #define CONFIG_FNMATCH 1
    #define CONFIG_SEM_VALUE_MAX 32767
    #define CONFIG_MAX_TIMER_COUNT 5
    #define CONFIG_TIMER_CREATE_WAIT 100
    #define CONFIG_TIMER_DELAYTIMER_MAX 20
    #define CONFIG_ACPI_HID_LEN_MAX 12
    #define CONFIG_LIBGCC_RTLIB 1
    #define CONFIG_BT 1
    #define CONFIG_BT_HCI 1
    #define CONFIG_BT_CONN_TX 1
    #define CONFIG_BT_LOG 1
    #define CONFIG_BT_LOG_LEGACY 1
    #define CONFIG_BT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_LOG_LEVEL 3
    #define CONFIG_BT_HCI_DRIVER_LOG_LEVEL 3
    #define CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_RPA_LOG_LEVEL 3
    #define CONFIG_BT_RPA_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AICS_LOG_LEVEL 3
    #define CONFIG_BT_AICS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AICS_CLIENT_LOG_LEVEL 3
    #define CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_STREAM_LOG_LEVEL 3
    #define CONFIG_BT_BAP_STREAM_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AUDIO_CODEC_LOG_LEVEL 3
    #define CONFIG_BT_ASCS_LOG_LEVEL 3
    #define CONFIG_BT_ASCS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL 3
    #define CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL 3
    #define CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL 3
    #define CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL 3
    #define CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL 3
    #define CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL 3
    #define CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_ISO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAP_ISO_LOG_LEVEL 3
    #define CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL 3
    #define CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_INITIATOR_LOG_LEVEL 3
    #define CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_STREAM_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CAP_STREAM_LOG_LEVEL 3
    #define CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL 3
    #define CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL 3
    #define CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL 3
    #define CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HAS_LOG_LEVEL 3
    #define CONFIG_BT_HAS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HAS_CLIENT_LOG_LEVEL 3
    #define CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MCS_LOG_LEVEL 3
    #define CONFIG_BT_MCS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MCC_LOG_LEVEL 3
    #define CONFIG_BT_MCC_LOG_LEVEL_INHERIT 1
    #define CONFIG_MCTL_LOG_LEVEL 3
    #define CONFIG_MCTL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL 3
    #define CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL 3
    #define CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MPL_LOG_LEVEL 3
    #define CONFIG_BT_MPL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_PACS_LOG_LEVEL 3
    #define CONFIG_BT_PACS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_TBS_LOG_LEVEL 3
    #define CONFIG_BT_TBS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_TBS_CLIENT_LOG_LEVEL 3
    #define CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VCP_VOL_REND_LOG_LEVEL 3
    #define CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL 3
    #define CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VOCS_LOG_LEVEL 3
    #define CONFIG_BT_VOCS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_VOCS_CLIENT_LOG_LEVEL 3
    #define CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CRYPTO_LOG_LEVEL 3
    #define CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_ATT_LOG_LEVEL 3
    #define CONFIG_BT_ATT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_GATT_LOG_LEVEL 3
    #define CONFIG_BT_GATT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_L2CAP_LOG_LEVEL 3
    #define CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_EAD_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_EAD_LOG_LEVEL 3
    #define CONFIG_BT_DF_LOG_LEVEL 3
    #define CONFIG_BT_DF_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SETTINGS_LOG_LEVEL 3
    #define CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HCI_CORE_LOG_LEVEL 3
    #define CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CONN_LOG_LEVEL 3
    #define CONFIG_BT_CONN_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_ISO_LOG_LEVEL 3
    #define CONFIG_BT_ISO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_KEYS_LOG_LEVEL 3
    #define CONFIG_BT_KEYS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SMP_LOG_LEVEL 3
    #define CONFIG_BT_SMP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SERVICE_LOG_LEVEL 3
    #define CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_CTLR_ISOAL_LOG_LEVEL 3
    #define CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_RFCOMM_LOG_LEVEL 3
    #define CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_HFP_HF_LOG_LEVEL 3
    #define CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_AVDTP_LOG_LEVEL 3
    #define CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_A2DP_LOG_LEVEL 3
    #define CONFIG_BT_A2DP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_SDP_LOG_LEVEL 3
    #define CONFIG_BT_SDP_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_LOG_LEVEL 3
    #define CONFIG_BT_MESH_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_NET_LOG_LEVEL 3
    #define CONFIG_BT_MESH_NET_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_RPL_LOG_LEVEL 3
    #define CONFIG_BT_MESH_RPL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_TRANS_LOG_LEVEL 3
    #define CONFIG_BT_MESH_TRANS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_BEACON_LOG_LEVEL 3
    #define CONFIG_BT_MESH_BEACON_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_CRYPTO_LOG_LEVEL 3
    #define CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_KEYS_LOG_LEVEL 3
    #define CONFIG_BT_MESH_KEYS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROV_LOG_LEVEL 3
    #define CONFIG_BT_MESH_PROV_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL 3
    #define CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL 3
    #define CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_ACCESS_LOG_LEVEL 3
    #define CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_MODEL_LOG_LEVEL 3
    #define CONFIG_BT_MESH_MODEL_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_DFU_LOG_LEVEL 3
    #define CONFIG_BT_MESH_DFU_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_ADV_LOG_LEVEL 3
    #define CONFIG_BT_MESH_ADV_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL 3
    #define CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_FRIEND_LOG_LEVEL 3
    #define CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_PROXY_LOG_LEVEL 3
    #define CONFIG_BT_MESH_PROXY_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_SETTINGS_LOG_LEVEL 3
    #define CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_CDB_LOG_LEVEL 3
    #define CONFIG_BT_MESH_CDB_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_MESH_CFG_LOG_LEVEL 3
    #define CONFIG_BT_MESH_CFG_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_BAS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_BAS_LOG_LEVEL 3
    #define CONFIG_BT_HRS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_HRS_LOG_LEVEL 3
    #define CONFIG_BT_TPS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_TPS_LOG_LEVEL 3
    #define CONFIG_BT_IAS_CLIENT_LOG_LEVEL 3
    #define CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_IAS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_IAS_LOG_LEVEL 3
    #define CONFIG_BT_OTS_CLIENT_LOG_LEVEL 3
    #define CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INHERIT 1
    #define CONFIG_BT_OTS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_BT_OTS_LOG_LEVEL 3
    #define CONFIG_BT_COMPANY_ID 0x05F1
    #define CONFIG_PRINTK 1
    #define CONFIG_EARLY_CONSOLE 1
    #define CONFIG_ASSERT 1
    #define CONFIG_ASSERT_LEVEL 2
    #define CONFIG_SPIN_VALIDATE 1
    #define CONFIG_ASSERT_VERBOSE 1
    #define CONFIG_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_IMG_MANAGER 1
    #define CONFIG_MCUBOOT_SHELL 1
    #define CONFIG_MCUBOOT_TRAILER_SWAP_TYPE 1
    #define CONFIG_IMG_BLOCK_BUF_SIZE 512
    #define CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT 1
    #define CONFIG_IMG_MANAGER_LOG_LEVEL 3
    #define CONFIG_FILE_SYSTEM 1
    #define CONFIG_FS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_FS_LOG_LEVEL 3
    #define CONFIG_APP_LINK_WITH_FS 1
    #define CONFIG_FILE_SYSTEM_MAX_TYPES 2
    #define CONFIG_FILE_SYSTEM_MAX_FILE_NAME 32
    #define CONFIG_FILE_SYSTEM_SHELL 1
    #define CONFIG_FILE_SYSTEM_LITTLEFS 1
    #define CONFIG_FS_LITTLEFS_NUM_FILES 6
    #define CONFIG_FS_LITTLEFS_NUM_DIRS 4
    #define CONFIG_FS_LITTLEFS_READ_SIZE 512
    #define CONFIG_FS_LITTLEFS_PROG_SIZE 512
    #define CONFIG_FS_LITTLEFS_CACHE_SIZE 1024
    #define CONFIG_FS_LITTLEFS_LOOKAHEAD_SIZE 8192
    #define CONFIG_FS_LITTLEFS_BLOCK_CYCLES 512
    #define CONFIG_FS_LITTLEFS_FC_HEAP_SIZE 0
    #define CONFIG_FS_LITTLEFS_HEAP_PER_ALLOC_OVERHEAD_SIZE 32
    #define CONFIG_FS_LITTLEFS_FMP_DEV 1
    #define CONFIG_EXT2_LOG_LEVEL_DEFAULT 1
    #define CONFIG_EXT2_LOG_LEVEL 3
    #define CONFIG_NVS 1
    #define CONFIG_NVS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NVS_LOG_LEVEL 3
    #define CONFIG_IPC_SERVICE 1
    #define CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY 46
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG 1
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE 1024
    #define CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE 2
    #define CONFIG_IPC_SERVICE_RPMSG 1
    #define CONFIG_IPC_SERVICE_STATIC_VRINGS 1
    #define CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT 4
    #define CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT 1
    #define CONFIG_IPC_SERVICE_LOG_LEVEL 3
    #define CONFIG_LOG 1
    #define CONFIG_LOG_CORE_INIT_PRIORITY 0
    #define CONFIG_LOG_MODE_DEFERRED 1
    #define CONFIG_LOG_RUNTIME_FILTERING 1
    #define CONFIG_LOG_DEFAULT_LEVEL 3
    #define CONFIG_LOG_OVERRIDE_LEVEL 0
    #define CONFIG_LOG_MAX_LEVEL 4
    #define CONFIG_LOG_PRINTK 1
    #define CONFIG_LOG_MODE_OVERFLOW 1
    #define CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD 10
    #define CONFIG_LOG_PROCESS_THREAD 1
    #define CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS 0
    #define CONFIG_LOG_PROCESS_THREAD_SLEEP_MS 1000
    #define CONFIG_LOG_PROCESS_THREAD_STACK_SIZE 4096
    #define CONFIG_LOG_TRACE_SHORT_TIMESTAMP 1
    #define CONFIG_LOG_FUNC_NAME_PREFIX_DBG 1
    #define CONFIG_LOG_TAG_MAX_LEN 64
    #define CONFIG_LOG_TAG_DEFAULT ""
    #define CONFIG_LOG_BACKEND_FS 1
    #define CONFIG_LOG_BACKEND_FS_OUTPUT_TEXT 1
    #define CONFIG_LOG_BACKEND_FS_OUTPUT_DEFAULT 0
    #define CONFIG_LOG_BACKEND_FS_AUTOSTART 1
    #define CONFIG_LOG_BACKEND_FS_OVERWRITE 1
    #define CONFIG_LOG_BACKEND_FS_FILE_PREFIX "log."
    #define CONFIG_LOG_BACKEND_FS_DIR "/lfs"
    #define CONFIG_LOG_BACKEND_FS_FILE_SIZE 8192
    #define CONFIG_LOG_BACKEND_FS_FILES_LIMIT 20
    #define CONFIG_LOG_DOMAIN_ID 0
    #define CONFIG_LOG_CMDS 1
    #define CONFIG_LOG_USE_VLA 1
    #define CONFIG_LOG_MEM_UTILIZATION 1
    #define CONFIG_LOG_FAILURE_REPORT_PERIOD 1000
    #define CONFIG_LOG_OUTPUT 1
    #define CONFIG_MCUMGR 1
    #define CONFIG_MCUMGR_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUMGR_LOG_LEVEL 3
    #define CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES 15
    #define CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS 2
    #define CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2 1
    #define CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS 2
    #define CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS 0
    #define CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS 0
    #define CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL 1
    #define CONFIG_MCUMGR_GRP_IMG 1
    #define CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER 1
    #define CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY 1
    #define CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUMGR_GRP_IMG_LOG_LEVEL 3
    #define CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE 2048
    #define CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO 3
    #define CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT 4
    #define CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE 4
    #define CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_MCUMGR_TRANSPORT_LOG_LEVEL 3
    #define CONFIG_NET_BUF 1
    #define CONFIG_NET_BUF_LOG_LEVEL_DEFAULT 1
    #define CONFIG_NET_BUF_LOG_LEVEL 3
    #define CONFIG_XOSHIRO_RANDOM_GENERATOR 1
    #define CONFIG_CSPRING_ENABLED 1
    #define CONFIG_HARDWARE_DEVICE_CS_GENERATOR 1
    #define CONFIG_SETTINGS 1
    #define CONFIG_SETTINGS_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SETTINGS_LOG_LEVEL 3
    #define CONFIG_SETTINGS_RUNTIME 1
    #define CONFIG_SETTINGS_DYNAMIC_HANDLERS 1
    #define CONFIG_SETTINGS_NVS 1
    #define CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT 1
    #define CONFIG_SETTINGS_NVS_SECTOR_COUNT 8
    #define CONFIG_SETTINGS_SHELL 1
    #define CONFIG_SHELL 1
    #define CONFIG_SHELL_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SHELL_LOG_LEVEL 3
    #define CONFIG_SHELL_BACKENDS 1
    #define CONFIG_SHELL_BACKEND_RTT 1
    #define CONFIG_SHELL_PROMPT_RTT "rtt:~$ "
    #define CONFIG_SHELL_BACKEND_RTT_BUFFER 0
    #define CONFIG_SHELL_RTT_RX_POLL_PERIOD 10
    #define CONFIG_SHELL_BACKEND_RTT_LOG_MESSAGE_QUEUE_TIMEOUT 100
    #define CONFIG_SHELL_BACKEND_RTT_LOG_MESSAGE_QUEUE_SIZE 512
    #define CONFIG_SHELL_RTT_INIT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SHELL_RTT_INIT_LOG_LEVEL 5
    #define CONFIG_SHELL_RTT_LOG_LEVEL_DEFAULT 1
    #define CONFIG_SHELL_RTT_LOG_LEVEL 3
    #define CONFIG_SHELL_STACK_SIZE 16384
    #define CONFIG_SHELL_BACKSPACE_MODE_DELETE 1
    #define CONFIG_SHELL_CMD_BUFF_SIZE 256
    #define CONFIG_SHELL_PRINTF_BUFF_SIZE 30
    #define CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH 80
    #define CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT 24
    #define CONFIG_SHELL_ARGC_MAX 20
    #define CONFIG_SHELL_ASCII_FILTER 1
    #define CONFIG_SHELL_WILDCARD 1
    #define CONFIG_SHELL_ECHO_STATUS 1
    #define CONFIG_SHELL_METAKEYS 1
    #define CONFIG_SHELL_HELP 1
    #define CONFIG_SHELL_HELP_OPT_PARSE 1
    #define CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT 1
    #define CONFIG_SHELL_HISTORY 1
    #define CONFIG_SHELL_HISTORY_BUFFER 512
    #define CONFIG_SHELL_STATS 1
    #define CONFIG_SHELL_CMDS 1
    #define CONFIG_SHELL_CMD_ROOT ""
    #define CONFIG_SHELL_AUTOSTART 1
    #define CONFIG_SHELL_CMDS_RETURN_VALUE 1
    #define CONFIG_KERNEL_SHELL 1
    #define CONFIG_KERNEL_SHELL_REBOOT_DELAY 0
    #define CONFIG_DEVICE_SHELL 1
    #define CONFIG_DEVMEM_SHELL 1
    #define CONFIG_FLASH_MAP 1
    #define CONFIG_STREAM_FLASH 1
    #define CONFIG_STREAM_FLASH_ERASE 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT 1
    #define CONFIG_STREAM_FLASH_LOG_LEVEL 3
    #define CONFIG_TASK_WDT 1
    #define CONFIG_TASK_WDT_CHANNELS 5
    #define CONFIG_TASK_WDT_HW_FALLBACK 1
    #define CONFIG_TASK_WDT_MIN_TIMEOUT 5000
    #define CONFIG_COVERAGE_GCOV_HEAP_SIZE 16384
    #define CONFIG_TOOLCHAIN_ZEPHYR_0_16 1
    #define CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE 1
    #define CONFIG_LINKER_ORPHAN_SECTION_WARN 1
    #define CONFIG_HAS_FLASH_LOAD_OFFSET 1
    #define CONFIG_LD_LINKER_SCRIPT_SUPPORTED 1
    #define CONFIG_LD_LINKER_TEMPLATE 1
    #define CONFIG_KERNEL_ENTRY "__start"
    #define CONFIG_LINKER_SORT_BY_ALIGNMENT 1
    #define CONFIG_SRAM_OFFSET 0x0
    #define CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT 1
    #define CONFIG_LINKER_LAST_SECTION_ID 1
    #define CONFIG_LINKER_LAST_SECTION_ID_PATTERN 0xE015E015
    #define CONFIG_LINKER_USE_RELAX 1
    #define CONFIG_DEBUG_OPTIMIZATIONS 1
    #define CONFIG_COMPILER_TRACK_MACRO_EXPANSION 1
    #define CONFIG_COMPILER_COLOR_DIAGNOSTICS 1
    #define CONFIG_FORTIFY_SOURCE_COMPILE_TIME 1
    #define CONFIG_COMPILER_OPT ""
    #define CONFIG_RUNTIME_ERROR_CHECKS 1
    #define CONFIG_KERNEL_BIN_NAME "zephyr"
    #define CONFIG_OUTPUT_STAT 1
    #define CONFIG_OUTPUT_PRINT_MEMORY_USAGE 1
    #define CONFIG_BUILD_OUTPUT_META 1
    #define CONFIG_BUILD_OUTPUT_STRIP_PATHS 1
    #define CONFIG_CHECK_INIT_PRIORITIES 1
    #define CONFIG_WARN_DEPRECATED 1
    #define CONFIG_ENFORCE_ZEPHYR_STDINT 1
    #define CONFIG_COMPAT_INCLUDES 1
    #define CONFIG_MISSION_MODE 1
    #define CONFIG_Y_SHELL 1
    #define CONFIG_STORE_RECORDING_IN_RAW_FORMAT 1
    #define CONFIG_RAW_FORMAT_ENCRYPT 1
    #define CONFIG_REQUIRE_AUTHENTICATION 1
    #define CONFIG_A_SERVICE_MTU 162
    #define CONFIG_Y_WATCHDOG_ENABLE 1
    #define CONFIG_WATCHDOG_MAXIMUM_SLEEP 5000
    #define CONFIG_WATCHDOG_A_TASK_TIMEOUT 30000
    #define CONFIG_WATCHDOG_B_TIMEOUT 30000
    #define CONFIG_WATCHDOG_C_TIMEOUT 30000
    I missed that from earlier. Interesting! What exactly do you mean by "fresh build"?
    Does it help the problem to manually delete the build folder and build again?
  • Hi Sigurd
    With "fresh build" I meant, the situation where I create a new build configuration, using the nRF pluggin in vscode, and have the checkbox "Build after generating configuration" checked.
  • As an alternative to VS Code, it is possible to build with the command line. This can be done by creating a new Terminal in VS Code with the type nRF Connect and building the project with "west build -b <board_name>".  Are you able to test this, so we can see if the issue is related to VS Code building or the build system itself?
    And thanks for the answers so far!
