SNTP originate timestamp mismatch when RRC state change
I am currently using NCS version 1.6.1 with my modem's firmware version being 1.3.0.
I have encountered an issue while utilizing Zephyr's SNTP library to retrieve time from time.google.com.
Periodically, I am experiencing the following error:
net_sntp: Mismatch originate timestamp: -2085978480, expect: -2085978479
This error appears to originate from the parse_response(...) function in sntp.c.
Upon further investigation, I have observed that this error consistently occurs whenever there is a change in the
RRC state during the SNTP request. In over 20 instances of the error, the RRC state has indeed changed.
[00:01:44.449,462] <inf> app: SNTP request on time.google.com
[00:01:46.197,601] <inf> app: RRC mode: Idle
[00:01:46.333,679] <inf> app: RRC mode: Connected
[00:01:46.452,087] <err>app: Request failed with error -22 (the timestamp mismatch error)
I am reaching out to seek clarification on this phenomenon.
Could you provide insights into why the RRC state change might be causing a timestamp mismatch in the SNTP response?
Is this behavior normal? How could I avoid this error?
It seems to be related to timing, and I suspect that an RRC state change in the midst of the query might be disrupting the timing.
Your assistance in resolving this matter would be greatly appreciated.
Best regards.
  • Hello Didrik,
    Happy new year!
    Thanks for your analysis.
    Were you able to get any new information from your colleagues?
    Best regards.
  • Hello, and happy new year to you to.
    Unfortunately, the analysis has been delayed due to Christmas vacations, so they are still working their way through the various protocol layers.
    However, they haven't found anything suspicious yet.
    I think the analysis will complete soon, and I'll update you once I have the conclusions.
    Didrik
  • Hi Didrik,
    I wanted to follow up regarding the analysis that your team was scheduled to conduct based on the modem traces I previously shared. Could you please provide any updates or information on the progress?
    This matter is currently posing a significant challenge for us, and any assistance from your end would be greatly appreciated.
    Upon reviewing the release notes for modem firmware versions higher than ours (1.3.0), specifically version 1.3.4, I came across the following entry:
    -- Fixed an issue with AS-RAI where the modem reported BSR 0 too early, causing the network to release RRC connection before responding to the last data UL packet.
    This description closely resembles the problem we encountered. I would appreciate it if your team could delve into this further and tell me if it's the same issue or not.
    Thank you for your attention to this matter.
  • The team has looked into the modem trace, and it looks like you are just unlucky with the timing.
    While the packet has been queued to be sent, it hasn't actually been sent on air, so the network releases the RRC connection after 5 seconds of inactivity.
    I've asked if they have any suggestions on how to improve the situation, and if the line from the mfw 1.3.4 release notes are related to this issue.
  • Hi, and sorry for the long wait.
    According to the trace, you are not using Release Assistance Indication (RAI), so that fix is not relevant.
    The RRC release timer is network dependent, and there isn't really anything the device can do to affect it, other than sending more frequently (so that the timer is restarted).
    Didrik
