I first got the USB CDC Zephyr sample with interrupt driven UART to work just fine.
But because I want to to be able to TX outside of interrupts I tried to convert that sample to use Async UART while using USB CDC. I have looked at all tickets that seem related to this but nothing works, maybe because I'm using a newer SDK version, which is v2.4.2.
When I call uart_callback_set I get -ENOSYS. I can see all callbacks for the API are not set which is why I get this. (I print the pointers and they are 0)
from C:\ncs\v2.4.2\zephyr\include\zephyr\drivers\uart.h
static inline int uart_callback_set(const struct device *dev,
uart_callback_t callback,
void *user_data)
#ifdef CONFIG_UART_ASYNC_API
const struct uart_driver_api *api =
(const struct uart_driver_api *)dev->api;
if (api->callback_set == NULL) {
return -ENOSYS;
return api->callback_set(dev, callback, user_data);
#else
ARG_UNUSED(dev);
ARG_UNUSED(callback);
ARG_UNUSED(user_data);
return -ENOTSUP;
I have tried all kings of CONFIG options (from other tickets) and nothing seems to work. I can see the ASYNC code is enabled in the file C:\ncs\v2.4.2\zephyr\drivers\serial\uart_nrfx_uarte.c. I can not see the linkage with the calling of DEVICE_DT_GET_ONE(zephyr_cdc_acm_uart) and driver API callbacks being set correctly.
Last configs I tried are:
CONFIG_LOG=y
CONFIG_MAIN_STACK_SIZE=1536
CONFIG_STDOUT_CONSOLE=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Zephyr CDC ACM sample"
CONFIG_USB_DEVICE_SN="0123456789ABCDEG"
CONFIG_USB_DEVICE_MANUFACTURER="Zephyr USBD CDC ACM with MS"
CONFIG_USB_DEVICE_PID=0x0002
CONFIG_USB_DEVICE_VID=0x2fe3
CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_USB_CDC_ACM=y
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_UART_0_ASYNC=y
CONFIG_UART_0_INTERRUPT_DRIVEN=n
CONFIG_NRFX_UARTE0=y
CONFIG_UART_LINE_CTRL=y
&zephyr_udc0 {
cdc_acm_uart0 {
compatible = "zephyr,cdc-acm-uart";
My Code
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/usb/usb_device.h>
#include <zephyr/usb/usbd.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/sys/ring_buffer.h>
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
#define RING_BUF_SIZE 1024
uint8_t ring_buffer[RING_BUF_SIZE];
struct ring_buf ringbuf;
// static void interrupt_handler(const struct device *dev, void *user_data)
// ARG_UNUSED(user_data);
// LOG_INF("11");
// while (uart_irq_update(dev) && uart_irq_is_pending(dev)) {
// LOG_INF("222");
// if (uart_irq_rx_ready(dev)) {
// int recv_len, rb_len;
// uint8_t buffer[64];
// size_t len = MIN(ring_buf_space_get(&ringbuf), sizeof(buffer));
// recv_len = uart_fifo_read(dev, buffer, len);
// if (recv_len < 0) {
// LOG_ERR("Failed to read UART FIFO");
// recv_len = 0;
// rb_len = ring_buf_put(&ringbuf, buffer, recv_len);
// if (rb_len < recv_len) {
// LOG_ERR("Drop %u bytes", recv_len - rb_len);
// LOG_DBG("tty fifo -> ringbuf %d bytes", rb_len);
// if (rb_len) {
// uart_irq_tx_enable(dev);
// if (uart_irq_tx_ready(dev)) {
// int rb_len, send_len;
// rb_len = ring_buf_get(&ringbuf, buffer, sizeof(buffer));
// if (!rb_len) {
// LOG_DBG("Ring buffer empty, disable TX IRQ");
// uart_irq_tx_disable(dev);
// continue;
// send_len = uart_fifo_fill(dev, buffer, rb_len);
// if (send_len < rb_len) {
// LOG_ERR("Drop %d bytes", rb_len - send_len);
// LOG_DBG("ringbuf -> tty fifo %d bytes", send_len);
static uint8_t rx_buf[64] = {0}; //A buffer to store incoming UART data
static void async_interrupt_cb(const struct device *dev, struct uart_event *evt, void *user_data)
switch (evt->type) {
case UART_TX_DONE:
// do something
case UART_TX_ABORTED:
// do something
case UART_RX_RDY:
LOG_INF("UART_RX_RDY");
case UART_RX_BUF_REQUEST:
LOG_INF("UART_RX_BUF_REQUEST");
case UART_RX_BUF_RELEASED:
LOG_INF("UART_RX_BUF_RELEASED");
case UART_RX_DISABLED:
// do something
case UART_RX_STOPPED:
// do something
int main(void) {
const struct device *dev;
uint32_t baudrate, dtr = 0U;
int ret;
// Setup USB
dev = DEVICE_DT_GET_ONE(zephyr_cdc_acm_uart);
if (!device_is_ready(dev)) {
LOG_ERR("CDC ACM device not ready");
return 0;
ret = usb_enable(NULL);
LOG_INF("Configured.......");
if (ret != 0) {
LOG_ERR("Failed to enable USB");
return 0;
ring_buf_init(&ringbuf, sizeof(ring_buffer), ring_buffer);
LOG_INF("Wait for DTR");
while (true) {
uart_line_ctrl_get(dev, UART_LINE_CTRL_DTR, &dtr);
if (dtr) {
} else {
/* Give CPU resources to low priority threads. */
k_sleep(K_MSEC(100));
LOG_INF("DTR set");
/* They are optional, we use them to test the interrupt endpoint */
ret = uart_line_ctrl_set(dev, UART_LINE_CTRL_DCD, 1);
if (ret) {
LOG_WRN("Failed to set DCD, ret code %d", ret);
ret = uart_line_ctrl_set(dev, UART_LINE_CTRL_DSR, 1);
if (ret) {
LOG_WRN("Failed to set DSR, ret code %d", ret);
/* Wait 100ms for the host to do all settings */
k_msleep(100);
ret = uart_line_ctrl_get(dev, UART_LINE_CTRL_BAUD_RATE, &baudrate);
if (ret) {
LOG_WRN("Failed to get baudrate, ret code %d", ret);
} else {
LOG_INF("Baudrate detected: %d", baudrate);
//uart_irq_callback_set(dev, interrupt_handler);
ret = uart_callback_set(dev, async_interrupt_cb, NULL);
if (ret != 0) { // :TODO:
LOG_ERR("Failed to register UART UART cb: %i", ret);
return 0;
/* Enable rx interrupts */
//uart_irq_rx_enable(dev);
ret = uart_rx_enable(dev, rx_buf, sizeof(rx_buf), 100);
LOG_ERR("Failed to enable UART RX");
return 0;
LOG_INF("Starting Observer Demo\n");
LOG_ERR("Exiting %s thread", __func__);
return 0;
When I connect with pyserial I always get the error NOSYS, 88. You will note I can make some sort of connection to get the baudrate. (below)
*** Booting Zephyr OS build v3.3.99-ncs1-1 *** [00:00:00.416,503] <inf> main: Configured....... [00:00:00.416,534] <inf> main: Wait for DTR [00:00:00.420,562] <inf> usb_cdc_acm: Device suspended [00:00:00.518,188] <inf> usb_cdc_acm: Device resumed [00:00:00.869,995] <inf> usb_cdc_acm: Device configured [00:00:04.319,244] <inf> main: DTR set [00:00:04.433,929] <inf> main: Baudrate detected: 115200 [00:00:04.433,959] <err> main: Failed to register UART UART cb: -88
After spending hours on this I don't know what else to try. Any help with this would be very much appreciated.
Async UART0 (with EasyDMA) is supposed to work with USB CDC, they are compatible?
