How to add a fallback Hardware watchdog to a device tree/overlay file
I am using the task watchdog sample to test the task watchdog subsystem. It is working fine.
I would like to use a hardware watchdog as a fallback; for this I need to define it in the devicetree or an overlay file.
How can I do either of the above?
I am using the following hardware/build environment,
- A proprietary board built around the nRF52833 SoC
- SEGGER Embedded Studio for ARM
  Release 5.60  Build 2021081102.47262
  Nordic Edition
  Windows x64
- Zephyr OS build v2.6.99-ncs1
- SDK 1.7.0
Thank you.
Kind regards
Mohamed
  • Hi Maria,
    Thank you for letting me know.
    Kind regards
    Mohamed
  • Thanks for waiting Mohamed, Happy New Year. I am just back from the holidays and wondering if you still have this issue or have you found the way to fix it?
    Learner said:
    Is it because I am refreshing the task watchdog timer every second?
    That could be.
    Learner said:
    I am printing the reset reason in my callback function task_wdt_callback_t task_wdt_callback() expecting it to be 2 since it was caused by a task watchdog timeout, instead I am getting reason = 0.
    printf( "Reas = %u\n", NRF_POWER->RESETREAS );
    That is strange. Can you please give me your project for me to reproduce and debug this? Maybe the reset reason is cleared somewhere else in the code?
  • Hi Susheel,
    Happy new year to you too.
    1- Actually things have moved on now and I am getting this reset reason SYSTEM_RESET_SOFTWARE (0x4). Maybe I should have added that once the task watchdog times out I am calling the function sys_reboot(SYS_REBOOT_COLD) from the task_wdt_callback() function. I think this is why I am getting the software reset reason.
    2- What is the difference between the hardware watchdog and the task watchdog?
    CONFIG_WATCHDOG=y versus CONFIG_TASK_WDT=y
    Finally, when I try to write to flash in the callback function task_wdt_callback(), nvs_write() is returning the error ECANCELED (140) meaning the write operation has been cancelled. Is it because, as stated in the task_wdt example comments, the callback has only 61.2 us to complete before the reset occurs and writing to flash is taking longer than this?
    3- Please answer the question above. I need to store in flash this watchdog reset event but I am not sure how I can do it without running out of time before the actual reset occurs. Is there a way of delaying the task_watchdog reset until I finish tidying up?
    Kind regards
    Mohamed
    You need CONFIG_WATCHDOG to use watchdog_api this inturn uses nrfx drivers.
    CONFIG_TASK_WDT is a firmware feature on top of the above watchdog which provides multiple channel usage of watchdog feature instead of the normal (only one) in most of the hardware watchdog.
    You need to save the data in RAM and not flash if you have to write more than a word in the wdt_callback. This topic is covered and discussed in this thread
  • Hi Susheel,
    I cannot find the file flash_placement.xml where the line containing .non_init is mentioned.
    Is there another equivalent file?
    Plus, according to Einar Thorsrud,
    "(Also, the degree of which RAM content persists may depend on several other factors as well, and this is using the IC out of specification, so you can never be guaranteed that RAM data is retained after a reset.)".
    Kind regards
    Mohamed
