Bluetooth LE Device Name not being found when using find name function
I am currently developing a BLE central device to find devices based on their name to extract data from their advertising packet without connecting. I was able to do this using the UUID, but since all of these devices will be transmitting the same UUID, I need to do it based on name. I was able to find the top device in my picture using ble_advdata_name_find, but I am unable to find the device below. I am setting the device name as such for now static char const target_device_name[] = "92094"; I have attached my ble event handler as well where this data processing is done. Any help is appreciated why one device is found but the other is not!
    ret_code_t err_code;
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral is connected, initiate DB
        // discovery, update LEDs status, and resume scanning, if necessary.
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
                         p_gap_evt->conn_handle);
            APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
            err_code = ble_lbs_c_handles_assign(&m_lbs_c[p_gap_evt->conn_handle],
                                                p_gap_evt->conn_handle,
                                                NULL);
            err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
            // Update LEDs status and check whether it is needed to look for more
            // peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                bsp_board_led_on(CENTRAL_SCANNING_LED);
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected, update
        // the LEDs status and start scanning again.
            NRF_LOG_INFO("LBS central link 0x%x disconnected (reason: 0x%x)",
                         p_gap_evt->params.disconnected.reason);
            if (ble_conn_state_central_conn_count() == 0)
                err_code = app_button_disable();
                // Turn off the LED that indicates the connection.
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
            // Start scanning.
            scan_start();
            // Turn on the LED for indicating scanning.
        } break;
        case BLE_GAP_EVT_TIMEOUT:
            // Timeout for scanning is not specified, so only the connection requests can time out.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("Connection request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            // Disconnect on GATT client timeout event.
            NRF_LOG_DEBUG("GATT client timeout.");
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
            // Disconnect on GATT server timeout event.
            NRF_LOG_DEBUG("GATT server timeout.");
        } break;
/* NOTE This is where we read in scanned BLE packet. We use uuid_find to filter based on UUIDs. */
/* The ble_uuid is currently set to 0x18FF which is the LE of the Pressure Sensors Watchlist data packet */
        case BLE_GAP_EVT_ADV_REPORT:
            // Initialize advertisement report for parsing.
            bleData = p_ble_evt->evt.gap_evt.params.adv_report.data;
            bool found = false;
            uint8_t * p_encoded_data = bleData.p_data;
            uint16_t data_len = bleData.len;
            found = ble_advdata_name_find(p_encoded_data,
                                  data_len,
                                  target_device_name);
            //found = ble_advdata_uuid_find(p_encoded_data,
            //                      data_len,
            //                      &ble_uuid);
            if(found)
                // Copy the entire advertising data
                memcpy(pressure_data, m_scan.scan_buffer_data, BLE_PRESSURE_ADV_DATA_BUFFER_SIZE);
                process_ble_data();
            // No implementation needed.
