TWI Error 33281
I have a nRF52832 DK unit which I have developed against to get a HDC1080 reporting the temperature - everything works fine in the development setup.
I have recently had some devices manufactured using a nRF52810 and the device is giving an error 33281. I have read from previous posts that this is the slave nacking - which suggests that nothing can be found attached.
I stripped it back to basics and used the twi_scanner and it also reports no devices attached. I have tried with various `TWIS_DEFAULT_CONFIG_SCL_PULL`/`TWIS_DEFAULT_CONFIG_SDA_PULL`/`NRFX_TWIS_DEFAULT_CONFIG_SCL_PULL`/`NRFX_TWIS_DEFAULT_CONFIG_SDA_PULL` settings and nothing gets it working.
Relevant config:
  • TWI_INSTANCE_ID 0
  • TWI_ENABLED 1
  • TWI0_ENABLED 1
  • TWI0_USE_EASY_DMA 1
And the main file (which is basically the example mentioned above):
 * Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup tw_scanner main.c
 * @ingroup nrf_twi_example
 * @brief TWI Sensor Example main file.
 * This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID     0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
 /* Number of possible TWI addresses. */
 #define TWI_ADDRESSES      127
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = 27,
       .sda                = 26,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
    uint8_t address;
    uint8_t sample_data;
    bool detected_device = false;
    NRF_LOG_INFO("TWI scanner started.");
    NRF_LOG_FLUSH();
    twi_init();
    for (address = 1; address <= TWI_ADDRESSES; address++)
        err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
        if (err_code == NRF_SUCCESS)
            detected_device = true;
            NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
        }        else
            NRF_LOG_INFO("error %d", err_code);
        NRF_LOG_FLUSH();
    if (!detected_device)
        NRF_LOG_INFO("No device was found.");
        NRF_LOG_FLUSH();
    while (true)
        /* Empty loop. */
I have attached an image of the schematics, in case there's anything wrong there.
Is there anything else I may be missing between the dev kit and a prototype configuration wise?
Details:
Using latest SES and latest available Nordic SDK (nRF5_SDK_17.1.0_ddde560).
