Incomplete installation on MacOS, file permission issue ?
Hi All,
After hours of reading this forum, I could not find a solution to an annoying issue I have with nRF Connect SDK installation on macOS Sonoma.
Please kindly note that I don't want to go through manual installation ;-)
Whenever I try to install the SDK (both via the nRF Connect for desktop App or from with Visual Studio Code):
- in my development account, the SDK directory is not populated at first and further, any attempt to "Update SDK" does not populate it neither
- in my "root" account, the SDK directory is properly populated and the visual studio environment is ready for development.
    - but when back in my account, the visual studio nRF panel, "WELCOME" zone, only allows to create a blank application: the "copy from sample" is missing.
I have redone the automatic process many times, rebooted in between, deleted the installed directories, ...
No way to succeed
Any help would be much appreciated !
  • Hello JRSN,
    Charlie is currently out of office. I will have a look at your case and follow up with our nRF Connect for Desktop team.
    Øyvind
  • Hi Øyvind,
    Welcome on this annoying issue. I hope it can be explained and solved.
    However I am to give up on trying to develop on this Mac. I need to go forward.
    I'll help as much as I can
    JRSN
  • Hi, sorry to hear that this is causing problems on your end. This does seems to be an issue between the MacOS environment and our toolchain bundles.
    Just to understand the issue correctly. You are using the Toolchain Manager in the nRF Connect for Desktop application? Are you also using the VS Code extension? Could you please provide the output from the nRF Connect: Generate support information, from the VS Code - Command Palette?
    JRSN said:
    git version 2.39.3 (Apple Git-145)
    This is a good indication that there could be an issue between OS and toochain bundle. Are you running this command in the nRF Connect terminal, as Charlie referred to in his last comment? The nRF Connect SDK should run in a sandbox environment when installing through the Toolchain Manager and opening Terminal through the same GUI.
    You can also open this environment in the VS Code terminal (I'm currently on Windows).
    I will have access to my Macbook Air M2 later today to provide more guidance on this.
  • Hi ,
    Thanks for reminding me that the "git version" command should be issued from nRF Connect for Desktop's terminal.
    However, once the installation process has failed, only the "Install" button remains visible (no "First steps" and no "Open VS Code" buttons) and the drop down menu is not active (cannot be dropped down).
    Ill keep on help as long as I can
    Best rgds
    JRSN
    One workaround that I have used before when I encountered a similar issue, was to open VS Code and from the command palette run nRF Connect: Uninstall SDK.
    Then from the drop down list, hopefully, NCS v2.5.1 will be visible and you can choose this one.
    What does git --version return from this terminal? Here is my normal terminal vs nRF Connect for Desktop
