Add DFU support to custom HCI_RPMSG netcore image
I have separate app core enabled with DFU and secure boot. I added all that support with help from this ticket  nRF5340 Firmware Update from external NOR QSPI flash
DFU for net core works fine.But it only works with an hci_rpmsg included automatically. How can I include the netcore DFU support in modified hci_rpmsg project. We compile this project but no "net_core_app_update.bin" is generated. How can I generate this DFU binary?
On app core image I have following configs enabled?
prj.conf
CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=y
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
/child_image/mcuboot/prj.conf
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16
CONFIG_PCD_APP=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
CONFIG_BOOT_UPGRADE_ONLY=y
# Enable flash operations.
# CONFIG_SPI=y
CONFIG_FLASH=y
# This must be increased to accommodate the bigger images.
CONFIG_BOOT_MAX_IMG_SECTORS=256
# Disable netcore image OTA udpate
CONFIG_BOOT_IMAGE_ACCESS_HOOKS=n
  • Dilawar Ali said:
    sorry, the content in hrdfu.zip should be extracted in a folder "hrdfu". The app core project name is "hrdfu"
    Yes, I was able to figure that out yesterday, after adding a comment asking about it. That is why I deleted the comment. Sorry if that was confusing.
    Anyhow. We are moving from Multi-image builds to sysbuild.
    The prior is part of the nRF repos, and automatically generates DFU files for you.
    The latte is part of the Zephyr repos, which has no such functionality. So you will have to generate your own DFU files with "imagetool sign".
    To get an idea on how to use this command, you can build an non-sysbuild project with DFU files with "west -vvv build ..." to see the commands our build system uses to generate the update files.
  • Things getting bit confusing. Here is what I understand, Please correct me if I am wrong.
    One option is I can compile app core and modified hci_rpmsg separately and then use imagetool to generate the images.
    Other way is to do multicore compilation using sysbuild, as described in the sampe "/multicore/Hello_World".
    The project "hrdfu" I shared I tried to use sysbuild for multicore compilation. But it failed to compile app core image.
    My aim is to keep both app and netcore in a same project. If the build system can generate dfu packages for me, that will be awesome.
    Yep
    Also correct.
    But you can build and flash it using nrfjprog no? Or do you miss the hex file as well?
    I asked our developers, and as far as I heard, we do not support automatic generating of DFU images for sysbuild yet. I would imagine that this is on a todo list somewhere.
  • Using the method "Other way is to do multicore compilation using sysbuild, as described in the sampe "/multicore/Hello_World"
    Only two images are generated "merged.hex" and "merged_CPUNET.hex". Putting them in programmer it looks like images are not correct.
    In file "build/hrdfu/zephyr/.config" the MCUBOOT bootloader config is not set. Whereas it is defined in prj.conf. Also the partition table generated in build folder donot contain mcuboot_primary or mcuboot_primary_1.
    How so?
    To enable mcuboot for a sysbuild project, you must set SB_CONFIG_BOOTLOADER_MCUBOOT in sysbuild.conf.
    You should not set mcuboot for the other images, I don't think.
