After bonding, I receive write events from the central, but after reconnecting, the write events no longer come through.
Nice to meet you.
I'm looking to embark on BLE development using nrf52840.
The requirements include one-to-one communication with one central and one peripheral, and pairing using LE Secure Connection is necessary (just works).
I will be developing the peripheral side of this. The BLE requirements are based on the specifications of the central side.
Now, initially, I tried implementing it myself based on various online information and samples.
I have successfully paired, and I can receive write events from the central side.
However, when I turn off the power on the central side, then turn it back on and perform a reconnection, I no longer receive write events from the central side.
Specifically, I am manipulating the central device to perform a write operation on the peripheral.
However, I only receive BLE_GAP_EVT_CONN_PARAM_UPDATE, and no other events.
First, let me share the logs!
If there's anything suspicious, please let me know. I can also provide the code.
Thank you.
SEGGER J-Link V7.88j - Real time terminal output
SEGGER J-Link (unknown) V1.0, SN=1050228242
Process: JLinkGDBServerCLExe
<info> app_timer: RTC: initialized.
<info> app: ble_stack__init
<info> app: Service UUID:0000, UUID Type: 2
<info> app: Erase bonds.
<info> peer_manager_handler: All peers deleted.
<info> app: PM_EVT_PEERS_DELETE_SUCCEEDED
<info> app: PM_EVT_CONN_CONFIG_REQ
<info> app: BLE_GAP_EVT_CONNECTED
<info> app: PM_EVT_CONN_SEC_START
<info> app: PM_EVT_CONN_SEC_PARAMS_REQ
<info> app: BLE_GAP_EVT_SEC_PARAMS_REQUEST
<info> app: BLE_GAP_EVT_LESC_DHKEY_REQUEST
<info> nrf_ble_lesc: Calling sd_ble_gap_lesc_dhkey_reply on conn_handle: 0
<info> app: BLE_GAP_EVT_CONN_SEC_UPDATE
<info> app: Security mode: 1. Security level: 2
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
<warning> app: PM_EVT_CONN_SEC_SUCCEEDED
<info> app: BLE_GAP_EVT_AUTH_STATUS: status=0x0, bond=0x1, kdist_own:0x3 kdist_peer:0x2
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
<info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
<info> app: Writing or overwriting the data.
<info> app: Flash changed.
<info> app: New Bond, add the peer to the whitelist if possible
<info> app: whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
<info> app: Bonded to a new peer, add it to the whitelist.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
<info> app: PM_PEER_DATA_ID_PEER_RANK
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
<info> app: PM_PEER_DATA_ID_GATT_LOCAL
<warning> app: ble_evt_handler:53
<info> app: BLE_GATTS_EVT_WRITE
<info> app: Notification enabled
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
<info> app: PM_PEER_DATA_ID_CENTRAL_ADDR_RES
<info> app: command_char_handles
<info> app:  01 00 02 00 1E 00 1A 00|........
<info> app:  01 61 C6 00 54 53 11 00|.a..TS..
<info> app:  A5 16 FF 00            |....
<info> app:  01 01 FF FF 00 00 A7 0B|........
<info> app:  AF 16 00 01 00 00 00 52|.......R
<info> app:  7C 07                  ||.
Here, intentionally turning the power of the central device OFF/ON to trigger a reconnection.
<info> app: Disconnected, reason 8.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
<info> app: Flash not changed.
<warning> app: PM_EVT_BONDED_PEER_CONNECTED
<info> app: PM_EVT_LOCAL_DB_CACHE_APPLIED
<info> app: BLE_GAP_EVT_SEC_INFO_REQUEST
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
<info> app: BLE_GAP_EVT_CONN_PARAM_UPDATE
<info> app: connection parameters updated. min_interval:160, max_interval:160, latency:0, timeout:810
<info> app: connection parameters updated. min_interval:80, max_interval:80, latency:0, timeout:810
  • Hi Keigo,
    It's strange the lower case alphabet worked for you. As you can find in my screenshot, I used uppercase and it also worked.
    I suspect that it could be something wrong with the uppercase in your setting, can be something with different alphabet keyboard setting ? I assume you have Japanese keyboard. For example if the keyboard use a similar character but not the same as in the default keyboard.
    Anyway, it's good that you have the sniffer working now :)
    Regarding your question, a common practice for securing the connection is to let the central handling it. The peripheral should instead set the security level of the characteristic/service to the level that it desired.
    For example you can find the instruction in the Apple Bluetooth design guideline here at section 49.10:
    https://developer.apple.com/accessories/Accessory-Design-Guidelines.pdf
    I think what you are implementing is fine, giving the central time to secure the connection, if it doesn't (after 4 seconds) you can start requesting. You can choose to request or not, but as long as you set the security level for the service when you declare it, then it's fine.
