LOG_DBG causes system to stop working properly
I am learning about Zephyr and currently I am experimenting with the accelerometer on the Nordic Thingy91 device. For programming, I use VSCode and NCS v2.5.0
My full source code:
#include <stdio.h>
#include <stdlib.h>
#include <zephyr/kernel.h>
#include <zephyr/drivers/spi.h>
#include <zephyr/device.h>
#include <zephyr/drivers/sensor.h>
#define LOG_LEVEL 4
LOG_MODULE_REGISTER(main);
struct sensor_value data[3];
/* Convert to s/m2 depending on the maximum measured range used for adxl362. */
#if IS_ENABLED(CONFIG_ADXL362_ACCEL_RANGE_2G)
#define ADXL362_RANGE_MAX_M_S2 19.6133
#elif IS_ENABLED(CONFIG_ADXL362_ACCEL_RANGE_4G)
#define ADXL362_RANGE_MAX_M_S2 39.2266
#elif IS_ENABLED(CONFIG_ADXL362_ACCEL_RANGE_8G)
#define ADXL362_RANGE_MAX_M_S2 78.4532
/* This is derived from the sensitivity values in the datasheet. */
#define ADXL362_THRESHOLD_RESOLUTION_DECIMAL_MAX 2000
#if IS_ENABLED(CONFIG_ADXL362_ACCEL_ODR_12_5)
#define ADXL362_TIMEOUT_MAX_S 5242.88
#elif IS_ENABLED(CONFIG_ADXL362_ACCEL_ODR_25)
#define ADXL362_TIMEOUT_MAX_S 2621.44
#elif IS_ENABLED(CONFIG_ADXL362_ACCEL_ODR_50)
#define ADXL362_TIMEOUT_MAX_S 1310.72
#elif IS_ENABLED(CONFIG_ADXL362_ACCEL_ODR_100)
#define ADXL362_TIMEOUT_MAX_S 655.36
#elif IS_ENABLED(CONFIG_ADXL362_ACCEL_ODR_200)
#define ADXL362_TIMEOUT_MAX_S 327.68
#elif IS_ENABLED(CONFIG_ADXL362_ACCEL_ODR_400)
#define ADXL362_TIMEOUT_MAX_S 163.84
#define ADXL362_TIMEOUT_RESOLUTION_MAX 65536
#define DEFAULT_ADXL362_NODE DT_ALIAS(adxl362)
BUILD_ASSERT(DT_NODE_HAS_STATUS(DEFAULT_ADXL362_NODE, okay),
"ADXL362 not specified in DT");
// DEVICE TREE STRUCTURE
const struct device *adxl1362_sens = DEVICE_DT_GET(DEFAULT_ADXL362_NODE);
static int ext_sensors_accelerometer_threshold_set(double threshold, bool upper);
static void trigger_handler(const struct device *dev, const struct sensor_trigger *trig)
int err = 0;
switch (trig->type)
case SENSOR_TRIG_MOTION:
case SENSOR_TRIG_STATIONARY:
if (sensor_sample_fetch(dev) < 0)
LOG_ERR("Sample fetch error");
return;
err = sensor_channel_get(dev, SENSOR_CHAN_ACCEL_XYZ, &data[0]);
if (err)
LOG_ERR("sensor_channel_get, error: %d", err);
return;
printk("x: %.1f, y: %.1f, z: %.1f (m/s^2)\n",
sensor_value_to_double(&data[0]),
sensor_value_to_double(&data[1]),
sensor_value_to_double(&data[2]));
if (trig->type == SENSOR_TRIG_MOTION)
printk("Activity detected \n");
printk("Inactivity detected \n");
LOG_ERR("Unknown trigger: %d", trig->type);
void main(void)
if (!device_is_ready(adxl1362_sens))
LOG_ERR("sensor: device %s not ready", adxl1362_sens->name);
return 0;
if (IS_ENABLED(CONFIG_ADXL362_TRIGGER))
printk("Configuring triggers \n");
struct sensor_trigger trig_motion = {
.chan = SENSOR_CHAN_ACCEL_XYZ,
.type = SENSOR_TRIG_MOTION,
if (sensor_trigger_set(adxl1362_sens, &trig_motion, trigger_handler))
LOG_ERR("SENSOR_TRIG_MOTION set error");
struct sensor_trigger trig_stationary = {
.type = SENSOR_TRIG_STATIONARY,
if (sensor_trigger_set(adxl1362_sens, &trig_stationary, trigger_handler))
LOG_ERR("SENSOR_TRIG_STATIONARY set error");
ext_sensors_accelerometer_threshold_set(5.0, true);
ext_sensors_accelerometer_threshold_set(0.5, false);
int err, input_value;
double range_max_m_s2 = ADXL362_RANGE_MAX_M_S2;
if ((threshold > range_max_m_s2) || (threshold <= 0.0))
LOG_ERR("Invalid %s threshold value: %f", upper ? "activity" : "inactivity", threshold);
return -ENOTSUP;
/* Convert threshold value into 11-bit decimal value relative
* to the configured measuring range of the accelerometer.
threshold = (threshold *
(ADXL362_THRESHOLD_RESOLUTION_DECIMAL_MAX / range_max_m_s2));
/* Add 0.5 to ensure proper conversion from double to int. */
threshold = threshold + 0.5;
input_value = (int)threshold;
if (input_value >= ADXL362_THRESHOLD_RESOLUTION_DECIMAL_MAX)
input_value = ADXL362_THRESHOLD_RESOLUTION_DECIMAL_MAX - 1;
else if (input_value < 0)
input_value = 0;
const struct sensor_value data = {
.val1 = input_value};
enum sensor_attribute attr = upper ? SENSOR_ATTR_UPPER_THRESH : SENSOR_ATTR_LOWER_THRESH;
printk("threshold value to be set : %d \n", data.val1);
/* SENSOR_CHAN_ACCEL_XYZ is not supported by the driver in this case. */
err = sensor_attr_set(adxl1362_sens,
SENSOR_CHAN_ACCEL_X,
attr,
&data);
if (err)
LOG_ERR("Failed to set accelerometer threshold value");
LOG_ERR("Device: %s, error: %d",
adxl1362_sens->name, err);
return err;
return 0;
And my proj.conf:
CONFIG_CBPRINTF_FP_SUPPORT=y
# SPI
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_MAIN_STACK_SIZE=4096
# LOG
CONFIG_LOG=y
# ADXL362
CONFIG_SENSOR=y
CONFIG_ADXL362=y
CONFIG_ADXL362_TRIGGER_GLOBAL_THREAD=y
CONFIG_ADXL362_INTERRUPT_MODE=1
CONFIG_ADXL362_ABS_REF_MODE=1
CONFIG_ADXL362_ACCEL_RANGE_2G=y
CONFIG_ADXL362_ACCEL_ODR_400=y
The code above works without any issues. See the serial logs below as I move the device:
As you can see from my source code above, I use printk statements to print some information to serial terminal. I have decided to replace all printk statements with LOG_DBG.
After replacing all pritnk statements with LOG_DBG, I have ended up with the source code below:
#include <stdio.h>
#include <stdlib.h>
#define LOG_LEVEL 4
int err = 0;
switch (trig->type)
return;
if (err)
return;
LOG_DBG("x: %.1f, y: %.1f, z: %.1f (m/s^2)",
LOG_DBG("Activity detected");
LOG_DBG("Inactivity detected");
void main(void)
return 0;
LOG_DBG("Configuring triggers");
return -ENOTSUP;
input_value = 0;
LOG_DBG("threshold value to be set : %d", data.val1);
attr,
&data);
if (err)
return err;
return 0;
After flashing the device, I get the following errors:
I cannot wrap my head around how can my code stop working when all I did was replace printk statements with LOG_DBG statements.  I have even put both of my source codes back to back in diffchecker to check whether I have accidentally changed something else:
www.diffchecker.com/.../
I would really appreciate if someone could help me understand this. Thanks!
  • It does not matter if you use LOG or printk
    It does though because it works with printk and does not with LOG.
    So can we consider that this is a bug in the sensor_trigger_set function?
    No, it worked by chance with printk. Once the variables are declared static, it also works with log.
    The issue is as described above. You must have the variables in question in global RAM, and not in the stack.
    Håkon
  • Apologize for asking many silly questions, bare with me a few more moments!
    If the variables are stored in stack and I am trying to print them in the scope of the variable it should work without any issues since the variables are not cleared out of stack.
    Are you suggesting that whenever I use LOG, I should only use them with GLOBAL scope variables and never variables that are placed in stack? For example, if I do the following:
    void my_function(){
    	int a; //this is a variable that is created on the stack
    	a = 5;
    	LOG_DBG("Printing variable a = %i",a);
    Are you suggesting that the above is not correct since the variable is placed on the stack?
    Consider this pseudo code:
    int *ptr;
    void pin_interrupt_function()
        printk("%d", *ptr);
    int some_function()
        int a = 5;
        ptr = &a;
        return 0;
    int main()
        some_function();
        rest_of_setup();
    "a" is out of scope once the pin_interrupt_function is called, thus the variable ptr is pointing to is no longer valid.
    What I stated previously, is that in some cases, you will still see "5" being printed, as no other function has exceeded the previous stack usage, ie. the value is not yet overwritten in RAM.
    But, the above scenario is still undefined behavior.
    Håkon
