Simple question:
Is possible a central to evaluate RSSI before connecting to a peripheral?
The idea is to make central device connect and bond to a peripheral only if a determined RSSI is achieved.
Cheers
Fávero
Simple question:
Cheers
Fávero
Every time you get a new BLE_GAP_EVT_ADV_REPORT event
What are the units of p_adv_report->rssi? is it in dbm?
Yes, it is in dbm.
Complementing Anders Strand answer, when using SDK 15, things are a little different.
You can use examples\ble_central\ble_app_multilink_central as an starting point.
First you need to disable auto connect in scan_init() function:
static void scan_init(void)
ret_code_t err_code;
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = false; // I CHANGED
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
//continues...
Then on scan_evt_handler(scan_evt_t const * p_scan_evt) function you need to add a "case" on the "switch case" to look for
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_FILTER_MATCH: //CASE ADDED
int read_rssi = p_scan_evt->params.filter_match.p_adv_report->rssi;
//PRINTS PEER ID OF THE CURRENT SCAN
NRF_LOG_RAW_INFO("PEER ID = ")
for (int i = 0; i < BLE_GAP_ADDR_LEN; i++){
NRF_LOG_RAW_INFO("%02x", p_scan_evt->params.connected.p_connected->peer_addr.addr[i]);
NRF_LOG_RAW_INFO("\r\n");
//PRINTS RSSI VALUE
NRF_LOG_RAW_INFO("RSSI = %d", read_rssi);
//NRF_LOG_INFO("RSSI = %d", read_rssi);
