nRF5340 function bt_nus_send() taking 40ms to execute, how to speed up?
I am looking to modify the sample code for peripheral UART and central UART, so that the central one takes data received from peripheral via BLE, and transmits said data out to some external processor via UART. External component must receive 10-byte packets with at most 1ms delay between end of one packet and start of another packet.
I am currently using 2 nRF5340-DKs to accomplish this. One of them is flashed with firmware from a direct copy of the central sample code (see nrf\samples\bluetooth\central_uart). The other has modified peripheral code (see nrf\samples\bluetooth\peripheral_uart), with the following changes:
  • main.c, defined array of hardcoded data - const uint8_t data[] (with size of roughly 16,000)
  • main.c, modified function ble_write_thread() to look like:
void ble_write_thread(void)
	/* Don't go any further until BLE is initialized */
	k_sem_take(&ble_init_ok, K_FOREVER);
	const uint16_t len2 = 10;
	uint16_t ndx = 0;
    int send_err;
	for (;;) {
		// send 1 packet
        dk_set_led(DK_LED3, 0);
		if ( (send_err = bt_nus_send(NULL, data + ndx, len2)) ) {
			LOG_WRN("Failed to send data over BLE connection");
            printk("BLE, FAILED TO SEND (ERROR=%d)\n", send_err);
		// prepare for next time
		else {
            dk_set_led(DK_LED3, 1);
			if (ndx % (len2 * 100) == 0) {
				printk("BLE, DATA PROGRESS (LASTBYTE=0x%02x)\n", data[ndx + len2 - 1]);
			ndx += len2;
			if (ndx >= sizeof(data)) {
				printk("\n\nBLE, ALL DATA SENT; RESTARTING\n\n");
				ndx = 0;
		// wait 1ms before sending next pkt
		k_sleep(K_MSEC(1));
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
I set up a logic analyzer to read the data on the central device's UART lines, and am getting the data with no loss. But there is a 45ms delay between the end of one packet and the start of another. I noticed a similar delay on the peripheral device (used the logic analyzer on the GPIO pin for LED3, and added dk_set_led() calls to use LED's off-time to measure it).
Any ideas, thoughts, suggestions on what I can do to reduce the delay (down to at most 1ms) and speed up the BLE communication? Thanks in advance.
Development Setup (for both peripheral and central devices):
  • Board: nRF5340-DK
  • Development Environment: VS Code
  • SDK: nRF Connect 2.5.0
  • OS: Windows 10
  • Thank you for the ESB info and suggestions! I will look into those some more to better evaluate ESB for our purposes.
    Given my team's timeline, we are also considering using the nRF54. Do you have any updates on when and/or how we could get our hands on nRF54 eval. boards (at least 2 of them)?
    EDIT1: I also went ahead with just trying the ESB demo code (nRF Connect 2.5.0, path nrf\samples\esb). This time I tried nRF52 DK's instead of nRF53's, since that's what I had on hand at the time. But I tried manipulating the TX code's k_sleep() call to lower the delay, and the lowest I could get it without significant "failed events" is around 10ms. I'll keep investigating the code to see how I can optimize it more, but what would you recommend I do to lower that more?
  • Hi Afok,
    Please contact our local Sales representative for the request. If you are located in California please contact Mr. Mike Obot at: mike.obot [at] nordicsemi.no
    Regarding the question with lower than 10ms interval. I would need to check with our expert in ESB. Please give us more detail on what's the error you see.
  • I'll get in touch w/ Mr. Obot; thanks for the contact info!
    Sure. So if I changed the TX's k_sleep() call to delay 1ms, then connect the nRF Serial Terminal to the nRF52 w/ TX code, I'm seeing the terminal output usually alternate between "TX SUCCESS EVENT" and "TX FAILED EVENT" (seeing failed message roughly 50% of the time). I hooked up a logic analyzer to the LED GPIO pins of the nRF52 w/ RX code, and notice the LEDs not toggling at a regular interval (most of the time there's no activity, then some randomly-spaced toggling every couple seconds or so). Let me know if you need more details.
  • Hi Afok,
    Could you try disable logging ?
    CONFIG_LOG=n
    It could be that the PRX was too slow printing log on the content of the packet it receives that it couldn't serve the radio quickly enough.
    I did a test here with k_sleep(K_MSEC(1)); and don't see any failed packet. You should turn off TX_SUCCESS printing out on PTX as well.
    I assume you are testing using 2 nRF52840 DK ?
  • Yes, I believe you're correct. Disabling PRX logging (w/ CONFIG_LOG=n) and turning off PTX success messages helped with that. I still saw PTX outputting "TX FAILED EVENT" but based on the logic analyzer, I believe it corresponds to longer time between packets that is needed when PTX retransmits the packet (since the LED sequence continues as normal i.e., the packet was not "lost"). I did also notice disabling PTX logging also helped a little more in allowing me to shorten the delay.
    But at least for my project's purposes, and because I'm just quickly testing the fastest speed I can send packets/events, the "failed events" are fine for now. As an FYI, I was able to bring down the time between packets to as low as roughly 0.5ms, by primarily using k_sleep(K_USEC()) for that PTX delay. I also played around with ESB configuration options that may have helped, such as:
    • config.retransmit_count = 0; (in PTX, esb_initialize())
    • config.selective_auto_ack = false; (in PTX and PRX, esb_initialize())
    • config.retransmit_delay = 400; (in PTX, esb_initialize())
    • CONFIG_ESB_NEVER_DISABLE_TX=y (in prj.conf)
    The above was indeed from using 2 nRF52840 DKs. Also happy to report that the code ran just as well on 2 nRF5340 DKs (build configuration set to use network core).
    I'll need to investigate some of the more intricate details for ESB in the following days. I'll circle back to this post again if/once I have more questions or have come to a resolution.
