How to use spi_write_dt
I am attempting to use the function spi_write_dt to write data (configuration files and lots of data) to a specific register. is there a better function for SPI that would do what I need it to?
This is my read function and I think it is working...
BMA4_INTF_RET_TYPE bma4_spi_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, void *intf_ptr)
    tx.buf = &reg_addr;
    tx.len = sizeof(reg_addr);
    printf("tx.buf read = %x\n", tx.buf);
    rx.buf = (uint8_t *)reg_data;
    rx.len = len;
    rslt= spi_transceive_dt(&dev_spi, &tx_bufs, &rx_bufs);
    reg_data = rx.buf; //<-Does this do what I think?
    return rslt;
I want the read to something similar to the I2C. the reg_data needs to hold the read info from the register for the program to work properly.
BMA4_INTF_RET_TYPE bma4_i2c_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t len, void *intf_ptr)
    uint8_t buffer[] = {reg_addr, *reg_data};
    rslt = i2c_write_read_dt(&dev_i2c, &buffer[0], 1, reg_data, len);
    return rslt;
Here is my attempted write function but I am stuck on how to put the register address in front of the data being sent.
The device tree:
&spi1 {
    // compatible = "nordic,nrf-spim";
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
	// pinctrl-names = "default", "sleep";
    cs-gpios = <&gpio0 28 GPIO_ACTIVE_LOW>;
    a: bma456-a@0 {
        compatible = "revel,spi-device";
        status = "okay";
        reg = <0>;
        spi-max-frequency = <7000000>;
        //spi-max-frequency = <900000>;
Here are some of the definitions:
#define SPI1_NODE DT_NODELABEL(a)
#define SPI_OP  SPI_OP_MODE_MASTER | SPI_WORD_SET(8) | SPI_TRANSFER_MSB
static const struct spi_dt_spec dev_spi = SPI_DT_SPEC_GET(SPI1_NODE, SPI_OP, 0);
static struct spi_buf rx;
const static struct spi_buf_set rx_bufs = {
	.buffers = &rx,
	.count = 1,
static struct spi_buf tx;
const static struct spi_buf_set tx_bufs = {
	.buffers = &tx,
	.count = 1,
BMA4_INTF_RET_TYPE bma4_spi_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t len, void *intf_ptr)
    tx.buf = &reg_addr;
    printf("tx.buf = %x\n", tx.buf);
    rslt= spi_write_dt(&dev_spi, &tx_bufs);
    tx.buf = (uint8_t *)reg_data;
    printf("tx.buf 2= %x\n", tx.buf);
    tx.len = len;
    return rslt;
The biggest problem is trying to figure out how to write data to a specific register address. I want it to do what the I2c version does.
BMA4_INTF_RET_TYPE bma4_i2c_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t len, void *intf_ptr)
    rslt= i2c_burst_write_dt(&dev_i2c, buffer[0], (uint8_t *)reg_data, len);
    return rslt;
and another write version...
    uint8_t txbuffer[2] = {reg_addr, *reg_data};
    struct spi_buf tx = {
        .buf = txbuffer,  .len = sizeof(txbuffer),};
        .buffers = &tx, .count = 1,};
    return rslt;
Any help would be much appreciated!!
Jared
    Yes, this is more or less what I was thinking. With one important exception that your declare a buffer of variable length, and it is also on the stack. So the first line here should probably be something like this instead:
    static uint8_t buffer[BMA4_MAX_LEN]; // BMA4_MAX_LEN should have a value that is larger than you will ever need
    Does this not work? If not, why? How does the Tx (MOSI) signal look and how is it compared to what you would expect?
    This was very helpful! I have been trying to wrap my head around buffers and you have help me understand them better! The SPI MOSI on this custom board is impossible to access as there were no connections made to access the pins (sorry, I know you asked about it twice and I forgot to mention it).
    Here is the updated code:
    static uint8_t buffer[5025]; //declared globaly
        buffer[0] = reg_addr;
        memcpy(&buffer[1], &reg_data, len);
        /*This SPI attempts to put the register address in front of the data buffer */
        .buf = buffer,.len = len+1
        const struct spi_buf_set tx_bufs = {
        .buffers = &tx,.count = 1
        return rslt;
    On a side note, I was hoping to review a custom board design with Nordic. We are using the NPM1100 and the nRF52832-CIAA. Do I just ask about it on a private chat over the DevZone?
    This looks sensible to me. If it does not wok, I would consider modifying your custom board to get the signals out so that you can look at them (or use a DK and connect the sensor to it and test your code there if that is easier).
    Regarding reviewing hardware, you can make a private ticket here (select "PRICATE Tech Support") and upload your schematic and layout files (in gerber format) for review.
  • Thank you for all the help!! I think I understand this function well enough to use it for our needs!
