nrf5340 build fail
I have an nRF5340 and am trying to build the ZSWatch-Zephyr Smartwatch sample for it in VS Code with the nRF Connect extension pack. I've created a new application from the sample and have added a build configuration that looks like so:
I've selected the right target, optimized for debugging, and enabled sysbuild. I have not changed any of the sample files. When I try to build this, I get:
Building app
west build --build-dir f:/ZSwatch/ZSWatch-main/app/build f:/ZSwatch/ZSWatch-main/app --pristine --board nrf5340dk_nrf5340_cpuapp --sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=f:/ZSwatch/ZSWatch-main/app/prj.conf -DEXTRA_CONF_FILE=boards/nrf5340dk_nrf5340_cpuapp.conf -DEXTRA_DTC_OVERLAY_FILE=boards/nrf5340dk_nrf5340_cpuapp.overlay -DBOARD_ROOT=f:/zswatch/zswatch-main/app
Loading Zephyr module(s) (Zephyr base): extensions sysbuild_extensions python west root zephyr_module boards shields sysbuild_kconfig
-- Found Python3: C:/ncs/V2.5.0/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/V2.5.0/v2.5.0/zephyr/.cache
-- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
-- Board: nrf5340dk_nrf5340_cpuapp
Parsing C:/ncs/V2.5.0/v2.5.0/zephyr/share/sysbuild/Kconfig
Loaded configuration 'F:/ZSwatch/ZSWatch-main/app/build/empty.conf'
Merged configuration 'F:/ZSwatch/ZSWatch-main/app/build/empty.conf'
Configuration saved to 'F:/ZSwatch/ZSWatch-main/app/build/zephyr/.config'
Kconfig header saved to 'F:/ZSwatch/ZSWatch-main/app/build/autoconf.h'
* Running CMake for app *
-- Application: F:/ZSwatch/ZSWatch-main/app
-- CMake version: 3.20.5
-- Using NCS Toolchain 2.5.20231017.848171396279 for building. (C:/ncs/V2.5.0/toolchains/c57af46cb7/cmake)
CMake Deprecation Warning at C:/ncs/V2.5.0/v2.5.0/zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
'PYTHON_PREFER' variable is deprecated. Please use Python3_EXECUTABLE
instead.
C:/ncs/V2.5.0/v2.5.0/zephyr/cmake/modules/python.cmake:16 (find_package)
C:/ncs/V2.5.0/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
C:/ncs/V2.5.0/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/V2.5.0/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:30 (find_package)
-- Zephyr version: 3.4.99 (C:/ncs/V2.5.0/v2.5.0/zephyr)
-- Found host-tools: zephyr 0.16.1 (C:/ncs/V2.5.0/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.1 (C:/ncs/V2.5.0/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/V2.5.0/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/V2.5.0/v2.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: F:/ZSwatch/ZSWatch-main/app/boards/nrf5340dk_nrf5340_cpuapp.overlay
-- Found devicetree overlay: boards/nrf5340dk_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: F:/ZSwatch/ZSWatch-main/app/build/app/zephyr/zephyr.dts
-- Generated devicetree_generated.h: F:/ZSwatch/ZSWatch-main/app/build/app/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: F:/ZSwatch/ZSWatch-main/app/build/app/zephyr/dts.cmake
Parsing F:/ZSwatch/ZSWatch-main/app/Kconfig
Loaded configuration 'C:/ncs/V2.5.0/v2.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'f:/ZSwatch/ZSWatch-main/app/prj.conf'
Merged configuration 'F:/ZSwatch/ZSWatch-main/app/boards/nrf5340dk_nrf5340_cpuapp.conf'
Merged configuration 'F:/ZSwatch/ZSWatch-main/app/build/app/zephyr/.config.sysbuild'
warning: LV_Z_POINTER_INPUT (defined at modules/lvgl\Kconfig.input:45,
modules\lvgl\Kconfig.input:45) was assigned the value 'y' but got the value 'n'. Check these
unsatisfied dependencies: ((INPUT && DT_HAS_ZEPHYR_LVGL_POINTER_INPUT_ENABLED && LVGL) || (INPUT &&
DT_HAS_ZEPHYR_LVGL_POINTER_INPUT_ENABLED && LVGL && 0)) (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up
LV_Z_POINTER_INPUT in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: LV_Z_POINTER_INPUT_MSGQ_COUNT (defined at modules/lvgl\Kconfig.input:51,
modules\lvgl\Kconfig.input:51) was assigned the value '200' but got the value ''. Check these
unsatisfied dependencies: ((LV_Z_POINTER_INPUT && LVGL) || (LV_Z_POINTER_INPUT && LVGL && 0)) (=n).
See docs.zephyrproject.org/.../kconfig.html and/or
Configuration saved to 'F:/ZSwatch/ZSWatch-main/app/build/app/zephyr/.config'
Kconfig header saved to 'F:/ZSwatch/ZSWatch-main/app/build/app/zephyr/include/generated/autoconf.h'
look up LV_Z_POINTER_INPUT_MSGQ_COUNT in the menuconfig/guiconfig interface. The Application
Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
the manual might be helpful too.
warning: REGULATOR_FIXED (defined at drivers/regulator/Kconfig.fixed:4) was assigned the value 'y'
but got the value 'n'. Check these unsatisfied dependencies: DT_HAS_REGULATOR_FIXED_ENABLED (=n).
See docs.zephyrproject.org/.../kconfig.html and/or look up
REGULATOR_FIXED in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: Experimental symbol BT_DF is enabled.
-- Found GnuLd: c:/ncs/v2.5.0/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/V2.5.0/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- libmetal version: 1.4.0 (F:/ZSwatch/ZSWatch-main/app)
-- Build type:
-- Host: Windows/AMD64
-- Target: Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- Machine: arm
-- open-amp version: 1.4.0 (C:/ncs/V2.5.0/v2.5.0/modules/lib/open-amp/open-amp)
-- C_FLAGS : -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
CMake Warning at C:/ncs/V2.5.0/v2.5.0/zephyr/CMakeLists.txt:893 (message):
No SOURCES given to Zephyr library: drivers__display
Excluding target from build.
CMake Warning at C:/ncs/V2.5.0/v2.5.0/zephyr/CMakeLists.txt:1958 (message):
-- 2048
-- about
-- accelerometer
-- battery
-- compass
-- iaq
-- info
-- music_control
-- notification
-- ppt_remote
-- qr_code
-- sensors_summary
-- settings
-- template
-- trivia
-- watchface
-- x_ray
-- zds
-- Configuring done
CMake Error at C:/ncs/V2.5.0/v2.5.0/zephyr/cmake/modules/extensions.cmake:424 (add_library):
Cannot find source file:
F:/ZSwatch/ZSWatch-main/app/src/ext_drivers/BMI270-Sensor-API/bmi2.c
C:/ncs/V2.5.0/v2.5.0/zephyr/CMakeLists.txt:110 (zephyr_library_named)
-- Generating done
CMake Generate step failed. Build files cannot be regenerated correctly.
CMake Error at cmake/modules/sysbuild_extensions.cmake:455 (message):
CMake configure failed for Zephyr project: app
CMakeLists.txt:38 (ExternalZephyrProject_Cmake)
See also "F:/ZSwatch/ZSWatch-main/app/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\V2.5.0\toolchains\c57af46cb7\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/V2.5.0/toolchains/c57af46cb7/opt/bin/python.exe '-Bf:\ZSwatch\ZSWatch-main\app\build' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=f:/ZSwatch/ZSWatch-main/app/prj.conf -DEXTRA_CONF_FILE=boards/nrf5340dk_nrf5340_cpuapp.conf -DEXTRA_DTC_OVERLAY_FILE=boards/nrf5340dk_nrf5340_cpuapp.overlay -DBOARD_ROOT=f:/zswatch/zswatch-main/app '-SC:\ncs\V2.5.0\v2.5.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=f:\ZSwatch\ZSWatch-main\app'
Any thoughts on why the unmodified sample won't build?
