VS Code can't clone nrf connect SDK
I am learning development with nrf connect sdk. I installed vs code and in vs code downloaded the nrf connect for vs code extension pack, everything downloads well. On the nrf connect extension menu I go to download toolchain and the toolchain installs okay. but then downloading SDK always throws this error.
The error codes are as follows
[00:39:13] Command failed: west init -m https://github.com/nrfconnect/sdk-nrf --mr v2.4.2
Cloning into 'c:\ncs\v2.4.2\.west\manifest-tmp'...
error: RPC failed; curl 92 HTTP/2 stream 0 was not closed cleanly: CANCEL (err 8)
error: 4674 bytes of body are still expected
fetch-pack: unexpected disconnect while reading sideband packet
fatal: early EOF
fatal: fetch-pack: invalid index-pack output
FATAL ERROR: command exited with status 128: git clone --branch v2.4.2 https://github.com/nrfconnect/sdk-nrf 'c:\ncs\v2.4.2\.west\manifest-tmp'
Please help I am stuck on this for 2 days now.
Thanks in advance.
  • Hi Syed,
    We don't provide the .zip file for NCS and most likely you will need to install other dependencies to be able to use it.
    I have forwarded the issue to our team, I will let you know if we find anything.
    Could you please send us the full log on the step by step manual installation that you have done until you see the error.
    Have you tried to do installing from another network ?
  • I followed the same method as shown in https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.3.0/nrf/getting_started/installing.html link. I have and the error occurs at the line
    west init -m https://github.com/nrfconnect/sdk-nrf --mr v2.3.0
    before this all the steps went smooth with no errors at all. When this command is executed it starts and reaches to the line Receiving objects and then after downloading something like 30 MBs ends with the error that I initially posted.
    I borrowed another friend PC remotely for sometime and downloaded SDK with VS code and it worked without errors, the network is different and also it has windows 11 while on my pc I have windows 10.
    Hope that helps in finding the cause of the problem.
  • here is the full log
    Microsoft Windows [Version 10.0.19045.3803]
    (c) Microsoft Corporation. All rights reserved.
    C:\Windows\system32>choco feature enable -n allowGlobalConfirmation
    Chocolatey v2.2.2
    Nothing to change. Config already set.
    C:\Windows\system32>choco install cmake --installargs 'ADD_CMAKE_TO_PATH=System'
    Chocolatey v2.2.2
    Installing the following packages:
    cmake
    By installing, you accept licenses for the packages.
    cmake v3.27.9 already installed.
     Use --force to reinstall, specify a version to install, or try upgrade.
    Chocolatey installed 0/1 packages.
     See the log for details (C:\ProgramData\chocolatey\logs\chocolatey.log).
    Warnings:
     - cmake - cmake v3.27.9 already installed.
    C:\Windows\system32>choco install ninja gperf python git dtc-msys2 wget unzip
    Chocolatey v2.2.2
    ninja;gperf;python;git;dtc-msys2;wget;unzip
    ninja v1.11.1 already installed.
    gperf v3.1.0 already installed.
    python v3.12.1 already installed.
    git v2.43.0 already installed.
    dtc-msys2 v1.5.1 already installed.
    Wget v1.21.4 already installed.
    unzip v6.0.0 already installed.
    Chocolatey installed 0/7 packages.
    Warnings:
     - dtc-msys2 - dtc-msys2 v1.5.1 already installed.
     - git - git v2.43.0 already installed.
     - gperf - gperf v3.1.0 already installed.
     - ninja - ninja v1.11.1 already installed.
     - python - python v3.12.1 already installed.
     - unzip - unzip v6.0.0 already installed.
     - Wget - Wget v1.21.4 already installed.
    C:\Windows\system32>choco list -lo
    Chocolatey v2.2.2
    Invalid argument -lo. This argument has been removed from the list command and cannot be used.
    C:\Windows\system32>choco list all
    Chocolatey v2.2.2
    chocolatey 2.2.2
    chocolatey-compatibility.extension 1.0.0
    chocolatey-core.extension 1.4.0
    cmake 3.27.9
    cmake.install 3.27.9
    git 2.43.0
    git.install 2.43.0
    KB2919355 1.0.20160915
    KB2919442 1.0.20160915
    KB2999226 1.0.20181019
    KB3033929 1.0.5
    KB3035131 1.0.3
    ninja 1.11.1
    python 3.12.1
    python3 3.12.1
    python312 3.12.1
    vcredist140 14.38.33130
    vcredist2015 14.0.24215.20170201
    Wget 1.21.4
    19 packages installed.
    C:\Windows\system32>pip3 install west
    Requirement already satisfied: west in c:\python312\lib\site-packages (1.2.0)
    Requirement already satisfied: colorama in c:\users\hamza\appdata\roaming\python\python312\site-packages (from west) (0.4.6)
    Requirement already satisfied: PyYAML>=5.1 in c:\users\hamza\appdata\roaming\python\python312\site-packages (from west) (6.0.1)
    Requirement already satisfied: pykwalify in c:\users\hamza\appdata\roaming\python\python312\site-packages (from west) (1.8.0)
    Requirement already satisfied: setuptools in c:\users\hamza\appdata\roaming\python\python312\site-packages (from west) (69.0.3)
    Requirement already satisfied: packaging in c:\users\hamza\appdata\roaming\python\python312\site-packages (from west) (23.2)
    Requirement already satisfied: docopt>=0.6.2 in c:\users\hamza\appdata\roaming\python\python312\site-packages (from pykwalify->west) (0.6.2)
    Requirement already satisfied: python-dateutil>=2.8.0 in c:\users\hamza\appdata\roaming\python\python312\site-packages (from pykwalify->west) (2.8.2)
    Requirement already satisfied: ruamel.yaml>=0.16.0 in c:\users\hamza\appdata\roaming\python\python312\site-packages (from pykwalify->west) (0.18.5)
    Requirement already satisfied: six>=1.5 in c:\users\hamza\appdata\roaming\python\python312\site-packages (from python-dateutil>=2.8.0->pykwalify->west) (1.16.0)
    Requirement already satisfied: ruamel.yaml.clib>=0.2.7 in c:\users\hamza\appdata\roaming\python\python312\site-packages (from ruamel.yaml>=0.16.0->pykwalify->west) (0.2.8)
    [notice] A new release of pip is available: 23.2.1 -> 23.3.2
    [notice] To update, run: python.exe -m pip install --upgrade pip
    C:\Windows\system32>cd c:/
    c:\>cd ncs
    c:\ncs>dir
     Volume in drive C has no label.
     Volume Serial Number is 8063-56D3
     Directory of c:\ncs
    01/03/2024  06:27 PM    <DIR>          .
    01/03/2024  06:27 PM    <DIR>          ..
    01/03/2024  10:06 AM    <DIR>          downloads
    01/03/2024  10:13 AM    <DIR>          tmp
    01/03/2024  10:13 AM    <DIR>          toolchains
                   0 File(s)              0 bytes
                   5 Dir(s)  20,783,288,320 bytes free
    c:\ncs>dir
     Directory of c:\ncs
    01/03/2024  06:37 PM    <DIR>          .
    01/03/2024  06:37 PM    <DIR>          ..
                   0 File(s)              0 bytes
                   2 Dir(s)  20,783,157,248 bytes free
    c:\ncs>west init -m https://github.com/nrfconnect/sdk-nrf --mr v2.3.0
    === Initializing in c:\ncs
    --- Cloning manifest repository from https://github.com/nrfconnect/sdk-nrf, rev. v2.3.0
    Cloning into 'c:\ncs\.west\manifest-tmp'...
    remote: Enumerating objects: 200532, done.
    remote: Counting objects: 100% (139/139), done.
    remote: Compressing objects: 100% (81/81), done.
    error: RPC failed; curl 18 transfer closed with outstanding read data remaining
    error: 10595 bytes of body are still expected
    fatal: early EOF
    FATAL ERROR: command exited with status 128: git clone --branch v2.3.0 https://github.com/nrfconnect/sdk-nrf 'c:\ncs\.west\manifest-tmp'
  • well this time it passed the west init line but now it gives error on west update.
    c:\ncs>west init -m https://github.com/nrfconnect/sdk-nrf --mr v2.5.0
    --- Cloning manifest repository from https://github.com/nrfconnect/sdk-nrf, rev. v2.5.0
    remote: Counting objects: 100% (140/140), done.
    remote: Compressing objects: 100% (82/82), done.
    remote: Total 200532 (delta 61), reused 116 (delta 58), pack-reused 200392
    Receiving objects: 100% (200532/200532), 133.38 MiB | 450.00 KiB/s, done.
    Resolving deltas: 100% (150050/150050), done.
    Note: switching to '1fae141fc6713dd331b797fc96c90dc84552242d'.
    You are in 'detached HEAD' state. You can look around, make experimental
    changes and commit them, and you can discard any commits you make in this
    state without impacting any branches by switching back to a branch.
    If you want to create a new branch to retain commits you create, you may
    do so (now or later) by using -c with the switch command. Example:
      git switch -c <new-branch-name>
    Or undo this operation with:
      git switch -
    Turn off this advice by setting config variable advice.detachedHead to false
    Updating files: 100% (8085/8085), done.
    --- setting manifest.path to nrf
    === Initialized. Now run "west update" inside c:\ncs.
    c:\ncs>west update
    === updating zephyr (zephyr):
    --- zephyr: initializing
    Initialized empty Git repository in C:/ncs/zephyr/.git/
    --- zephyr: fetching, need revision v3.4.99-ncs1
    remote: Enumerating objects: 927552, done.
    remote: Counting objects: 100% (92/92), done.
    remote: Compressing objects: 100% (58/58), done.
    error: RPC failed; curl 92 HTTP/2 stream 5 was not closed cleanly: CANCEL (err 8)
    error: 3336 bytes of body are still expected
    fatal: early EOF
    FATAL ERROR: command exited with status 128: fetch -f --tags -- https://github.com/nrfconnect/sdk-zephyr v3.4.99-ncs1
