Hi Everyone,
I'm trying to switch from Segger studio where we develop in Bare metal to Visual Studio with Zephyr.
I try to follow this tutorial, I succeed to install latest version of VS nRF connect extension.
Now arrived in part 3 I can't go further, when I click on install toolchain I got:
nrfutil-toolchain-manager: Error: Failed to retrieve toolchain-index
Caused by:
0: Failed to download index
1: Get request failed
2: https://developer.nordicsemi.com/.pc-tools/toolchain-v3/index-windows-x86_64.json: Connection Failed: tls connection init failed: invalid peer certificate: UnknownIssuer
3: invalid peer certificate: UnknownIssuer
If I click on the URL with the json file, I'm able to download the JSON file BTW.
In existing toolchaine I have :
Already tried solution : Delete proxy settings, Use Other wifi, use Command line : same results
If I try to continue using V1.9.1 and follow step 4, I try to install 2.5.0 SDK and get :
Command failed: west init -m https://github.com/nrfconnect/sdk-nrf --mr v2.5.0
Cloning into 'c:\users\MYNAME\ncs\v2.5.0\.west\manifest-tmp'...
Note: switching to '1fae141fc6713dd331b797fc96c90dc84552242d'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by switching back to a branch.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -c with the switch command. Example:
git switch -c <new-branch-name>
Or undo this operation with:
git switch -
Turn off this advice by setting config variable advice.detachedHead to false
Updating files: 3% (244/8085)
Updating files: 4% (324/8085)
Updating files: 5% (405/8085)
Updating files: 5% (484/8085)
Updating files: 6% (486/8085)
Updating files: 7% (566/8085)
Updating files: 8% (647/8085)
Updating files: 9% (728/8085)
Updating files: 9% (742/8085)
Updating files: 10% (809/8085)
Updating files: 11% (890/8085)
Updating files: 12% (971/8085)
Updating files: 12% (987/8085)
Updating files: 13% (1052/8085)
Updating files: 14% (1132/8085)
Updating files: 15% (1213/8085)
Updating files: 15% (1231/8085)
Updating files: 16% (1294/8085)
Updating files: 17% (1375/8085)
Updating files: 17% (1440/8085)
Updating files: 18% (1456/8085)
Updating files: 19% (1537/8085)
Updating files: 19% (1606/8085)
Updating files: 20% (1617/8085)
Updating files: 21% (1698/8085)
Updating files: 22% (1779/8085)
Updating files: 22% (1844/8085)
Updating files: 23% (1860/8085)
Updating files: 24% (1941/8085)
Updating files: 25% (2022/8085)
Updating files: 25% (2074/8085)
Updating files: 26% (2103/8085)
Updating files: 27% (2183/8085)
Updating files: 27% (2191/8085)
Updating files: 28% (2264/8085)
Updating files: 29% (2345/8085)
Updating files: 29% (2416/8085)
Updating files: 30% (2426/8085)
Updating files: 31% (2507/8085)
Updating files: 32% (2588/8085)
Updating files: 32% (2641/8085)
Updating files: 33% (2669/8085)
Updating files: 34% (2749/8085)
Updating files: 35% (2830/8085)
Updating files: 35% (2853/8085)
Updating files: 36% (2911/8085)
Updating files: 37% (2992/8085)
Updating files: 37% (3064/8085)
Updating files: 38% (3073/8085)
Updating files: 39% (3154/8085)
Updating files: 40% (3234/8085)
Updating files: 40% (3280/8085)
Updating files: 41% (3315/8085)
Updating files: 41% (3383/8085)
Updating files: 42% (3396/8085)
Updating files: 43% (3477/8085)
Updating files: 44% (3558/8085)
Updating files: 44% (3596/8085)
Updating files: 45% (3639/8085)
Updating files: 46% (3720/8085)
Updating files: 47% (3800/8085)
Updating files: 47% (3849/8085)
Updating files: 48% (3881/8085)
Updating files: 49% (3962/8085)
Updating files: 50% (4043/8085)
Updating files: 50% (4123/8085)
Updating files: 51% (4124/8085)
Updating files: 52% (4205/8085)
Updating files: 53% (4286/8085)
Updating files: 54% (4366/8085)
Updating files: 54% (4377/8085)
Updating files: 55% (4447/8085)
Updating files: 56% (4528/8085)
Updating files: 56% (4568/8085)
Updating files: 57% (4609/8085)
Updating files: 58% (4690/8085)
Updating files: 58% (4762/8085)
Updating files: 59% (4771/8085)
Updating files: 60% (4851/8085)
Updating files: 61% (4932/8085)
Updating files: 62% (5013/8085)
Updating files: 62% (5030/8085)
Updating files: 63% (5094/8085)
Updating files: 63% (5147/8085)
Updating files: 64% (5175/8085)
Updating files: 65% (5256/8085)
Updating files: 66% (5337/8085)
Updating files: 66% (5400/8085)
Updating files: 67% (5417/8085)
Updating files: 68% (5498/8085)
Updating files: 69% (5579/8085)
Updating files: 69% (5627/8085)
Updating files: 70% (5660/8085)
Updating files: 71% (5741/8085)
Updating files: 72% (5822/8085)
Updating files: 72% (5865/8085)
Updating files: 73% (5903/8085)
Updating files: 74% (5983/8085)
Updating files: 75% (6064/8085)
Updating files: 75% (6128/8085)
Updating files: 76% (6145/8085)
Updating files: 77% (6226/8085)
Updating files: 78% (6307/8085)
Updating files: 78% (6384/8085)
Updating files: 79% (6388/8085)
Updating files: 80% (6468/8085)
Updating files: 81% (6549/8085)
Updating files: 81% (6607/8085)
Updating files: 82% (6630/8085)
Updating files: 83% (6711/8085)
Updating files: 84% (6792/8085)
Updating files: 84% (6857/8085)
Updating files: 85% (6873/8085)
Updating files: 86% (6954/8085)
Updating files: 87% (7034/8085)
Updating files: 87% (7092/8085)
Updating files: 88% (7115/8085)
Updating files: 89% (7196/8085)
Updating files: 90% (7277/8085)
Updating files: 90% (7331/8085)
Updating files: 91% (7358/8085)
Updating files: 92% (7439/8085)
Updating files: 93% (7520/8085)
Updating files: 93% (7576/8085)
Updating files: 94% (7600/8085)
Updating files: 95% (7681/8085)
Updating files: 96% (7762/8085)
Updating files: 96% (7837/8085)
Updating files: 97% (7843/8085)
Updating files: 98% (7924/8085)
Updating files: 99% (8005/8085)
Updating files: 100% (8085/8085)
Updating files: 100% (8085/8085), done.
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\manifest.py", line 1296, in __init__
validate(source_data)
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\manifest.py", line 474, in validate
raise ManifestVersionError(min_version_str)
west.manifest.ManifestVersionError: ('0.13', None)
The above exception was the direct cause of the following exception:
File "runpy.py", line 193, in _run_module_as_main
File "runpy.py", line 86, in _run_code
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Scripts\west.exe\__main__.py", line 7, in <module>
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\app\main.py", line 781, in main
app.run(argv or sys.argv[1:])
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\app\main.py", line 106, in run
self.run_command(argv)
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\app\main.py", line 336, in run_command
cmd.run(args, unknown, self.topdir, manifest=self.manifest)
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\commands.py", line 140, in run
self.do_run(args, unknown)
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\app\project.py", line 198, in do_run
topdir = self.bootstrap(args)
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\app\project.py", line 286, in bootstrap
projects = Manifest.from_file(temp_manifest,
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\manifest.py", line 1153, in from_file
return Manifest(**kwargs)
File "c:\Users\MYNAME\ncs\v1.9.1\toolchain\opt\bin\Lib\site-packages\west\manifest.py", line 1298, in __init__
raise ManifestVersionError(mv.version, file=source_file) from mv
west.manifest.ManifestVersionError: ('0.13', WindowsPath('c:/users/MYNAME/ncs/v2.5.0/.west/manifest-tmp/west.yml'))
Then if I try to reinstall it it say :
Do I make something wrong ?
Thanks for your help.
Florent
