I'm going through the nRF Connect SDK Fundamentals [1], and am stuck at installing the SDK. Regardless of what I try, it seems to fail right after getting the zscilib repo. And unfortunately the terminal output is not helpful in this case either.
I'm following the steps as described in the training, but maybe I'm missing a step. The vscode terminal output is attached at the bottom of this post.
Can I get some support on this?
Relevant info:
- OS: Windows 10
- Fresh installation of nrf toolkit
- Toolchain: 2.5.1 (same error with 2.5.0)
- SDK: 2.5.1 (same error with 2.5.0)
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
[12:05:46] nRF Command Line Tools 10.23.2 are up to date
[12:05:49] nrfutil-toolchain-manager install v2.5.1: Download toolchain
[12:05:51] nrfutil-toolchain-manager install v2.5.1: Finished, using previously downloaded file: success
[12:05:51] nrfutil-toolchain-manager install v2.5.1: Unpack toolchain
[12:07:00] nrfutil-toolchain-manager install v2.5.1: Toolchain unpacked to C:\ncs\tmp\.tmpytlytD: success
[12:07:00] nrfutil-toolchain-manager install v2.5.1: Install toolchain
[12:07:01] nrfutil-toolchain-manager install v2.5.1: Toolchain installed at C:\ncs\toolchains\c57af46cb7: success
[12:07:01] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.5.1 ===========
No issues were detected with the toolchain.
[west]: updating c:\ncs\v2.5.1...
[west]: === updating zephyr (zephyr):
[west]: --- zephyr: initializing
[west]: Initialized empty Git repository in C:/ncs/v2.5.1/zephyr/.git/
[west]: --- zephyr: fetching, need revision v3.4.99-ncs1-1
[west]: From https://github.com/nrfconnect/sdk-zephyr
[west]: * tag v3.4.99-ncs1-1 -> FETCH_HEAD
[west]: HEAD is now at 83980fe16 [nrf fromtree] boards: arm: nrf5340dk_nrf5340: Add SPI to supported peripherals
[west]: === updating bsim (tools/bsim):
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
[12:05:46] nRF Command Line Tools 10.23.2 are up to date [12:05:49] nrfutil-toolchain-manager install v2.5.1: Download toolchain [12:05:51] nrfutil-toolchain-manager install v2.5.1: Finished, using previously downloaded file: success [12:05:51] nrfutil-toolchain-manager install v2.5.1: Unpack toolchain [12:07:00] nrfutil-toolchain-manager install v2.5.1: Toolchain unpacked to C:\ncs\tmp\.tmpytlytD: success [12:07:00] nrfutil-toolchain-manager install v2.5.1: Install toolchain [12:07:01] nrfutil-toolchain-manager install v2.5.1: Toolchain installed at C:\ncs\toolchains\c57af46cb7: success [12:07:01] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.5.1 =========== No issues were detected with the toolchain. [west]: updating c:\ncs\v2.5.1... [west]: === updating zephyr (zephyr): [west]: --- zephyr: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/zephyr/.git/ [west]: --- zephyr: fetching, need revision v3.4.99-ncs1-1 [west]: From https://github.com/nrfconnect/sdk-zephyr [west]: * tag v3.4.99-ncs1-1 -> FETCH_HEAD [west]: HEAD is now at 83980fe16 [nrf fromtree] boards: arm: nrf5340dk_nrf5340: Add SPI to supported peripherals [west]: HEAD is now at 83980fe16 [nrf fromtree] boards: arm: nrf5340dk_nrf5340: Add SPI to supported peripherals [west]: === updating bsim (tools/bsim): [west]: --- bsim: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/tools/bsim/.git/ [west]: --- bsim: fetching, need revision 384a091445c57b44ac8cbd18ebd245b47c71db94 [west]: From https://github.com/BabbleSim/bsim_west [west]: * branch 384a091445c57b44ac8cbd18ebd245b47c71db94 -> FETCH_HEAD [west]: HEAD is now at 384a091 west.yaml Update to 2.1.1 [west]: HEAD is now at 384a091 west.yaml Update to 2.1.1 [west]: === updating hostap (modules/lib/hostap): [west]: --- hostap: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/hostap/.git/ [west]: --- hostap: fetching, need revision eb6119524273f65f64a7710fbd876c829094a216 [west]: From https://github.com/nrfconnect/sdk-hostap [west]: * branch eb6119524273f65f64a7710fbd876c829094a216 -> FETCH_HEAD [west]: HEAD is now at eb611952 [nrf fromlist] zephyr: Fix MBO build with GAS dependency [west]: HEAD is now at eb611952 [nrf fromlist] zephyr: Fix MBO build with GAS dependency [west]: === updating wfa-qt-control-app (modules/lib/wfa-qt-control-app): [west]: --- wfa-qt-control-app: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/wfa-qt-control-app/.git/ [west]: --- wfa-qt-control-app: fetching, need revision 0e213ab6a421298484a81a9d18f5c31c4b8084a8 [west]: From https://github.com/nrfconnect/sdk-wi-fiquicktrack-controlappc [west]: * branch 0e213ab6a421298484a81a9d18f5c31c4b8084a8 -> FETCH_HEAD [west]: HEAD is now at 0e213ab [nrf noup]: zephyr: qt: Disconnect STA before reset [west]: HEAD is now at 0e213ab [nrf noup]: zephyr: qt: Disconnect STA before reset [west]: === updating mcuboot (bootloader/mcuboot): [west]: --- mcuboot: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/bootloader/mcuboot/.git/ [west]: --- mcuboot: fetching, need revision v1.10.99-ncs1-1 [west]: From https://github.com/nrfconnect/sdk-mcuboot [west]: * tag v1.10.99-ncs1-1 -> FETCH_HEAD [west]: HEAD is now at edfe1e1 [nrf noup] boards: thingy53: disable GPIO ISR support [west]: HEAD is now at edfe1e1 [nrf noup] boards: thingy53: disable GPIO ISR support [west]: === updating qcbor (modules/tee/tf-m/qcbor): [west]: --- qcbor: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/tee/tf-m/qcbor/.git/ [west]: --- qcbor: fetching, need revision 751d36583a9ce1a640900c57e13c9b6b8f3a2ba2 [west]: From https://github.com/laurencelundblade/QCBOR [west]: * branch 751d36583a9ce1a640900c57e13c9b6b8f3a2ba2 -> FETCH_HEAD [west]: HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181) [west]: HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181) [west]: === updating mbedtls (modules/crypto/mbedtls): [west]: --- mbedtls: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/crypto/mbedtls/.git/ [west]: --- mbedtls: fetching, need revision v3.3.0-ncs2-1 [west]: From https://github.com/nrfconnect/sdk-mbedtls [west]: * tag v3.3.0-ncs2-1 -> FETCH_HEAD [west]: HEAD is now at acea48fc [nrf noup] Fix buffer overread with stream cipher [west]: HEAD is now at acea48fc [nrf noup] Fix buffer overread with stream cipher [west]: === updating nrfxlib (nrfxlib): [west]: --- nrfxlib: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/nrfxlib/.git/ [west]: --- nrfxlib: fetching, need revision v2.5.1 [west]: From https://github.com/nrfconnect/sdk-nrfxlib [west]: * tag v2.5.1 -> FETCH_HEAD [west]: HEAD is now at ab72f33 crypto: Ensure correct CryptoCell libs for bootloaders [west]: HEAD is now at ab72f33 crypto: Ensure correct CryptoCell libs for bootloaders [west]: === updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m): [west]: --- trusted-firmware-m: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/tee/tf-m/trusted-firmware-m/.git/ [west]: --- trusted-firmware-m: fetching, need revision v1.8.0-ncs1-1 [west]: From https://github.com/nrfconnect/sdk-trusted-firmware-m [west]: * tag v1.8.0-ncs1-1 -> FETCH_HEAD [west]: HEAD is now at 1ceee76 [nrf fromtree] platform: nordic_nrf: Fix nrf9160 non-secure peripheral regression [west]: HEAD is now at 1ceee76 [nrf fromtree] platform: nordic_nrf: Fix nrf9160 non-secure peripheral regression [west]: === updating matter (modules/lib/matter): [west]: --- matter: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/matter/.git/ [west]: --- matter: fetching, need revision v2.5.1 [west]: From https://github.com/nrfconnect/sdk-connectedhomeip [west]: * tag v2.5.1 -> FETCH_HEAD [west]: HEAD is now at 899d2109 [nrf noup] wifi: avoid unwanted connect request [west]: HEAD is now at 899d2109 [nrf noup] wifi: avoid unwanted connect request [west]: /mingw64/libexec/git-core/git-sh-setup: line 46: /git-sh-i18n: No such file or directory [west]: === updating cjson (modules/lib/cjson): [west]: --- cjson: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/cjson/.git/ [west]: --- cjson: fetching, need revision c6af068b7f05207b28d68880740e4b9ec1e4b50a [west]: From https://github.com/nrfconnect/sdk-cjson [west]: * branch c6af068b7f05207b28d68880740e4b9ec1e4b50a -> FETCH_HEAD [west]: HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611) [west]: HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611) [west]: === updating azure-sdk-for-c (modules/lib/azure-sdk-for-c): [west]: --- azure-sdk-for-c: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/azure-sdk-for-c/.git/ [west]: --- azure-sdk-for-c: fetching, need revision 308c171cb4b5eed266649012a68406487ec81fb2 [west]: From https://github.com/nrfconnect/azure-sdk-for-c [west]: * branch 308c171cb4b5eed266649012a68406487ec81fb2 -> FETCH_HEAD [west]: HEAD is now at 308c171 [nrf fromlist] Make repository a Zephyr module [west]: HEAD is now at 308c171 [nrf fromlist] Make repository a Zephyr module [west]: === updating cirrus (modules/hal/cirrus-logic): [west]: --- cirrus: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/hal/cirrus-logic/.git/ [west]: --- cirrus: fetching, need revision 9f6b3812237fbb0d4157ba3584c13f1644fcbe3a [west]: From https://github.com/nrfconnect/sdk-mcu-drivers [west]: * branch 9f6b3812237fbb0d4157ba3584c13f1644fcbe3a -> FETCH_HEAD [west]: HEAD is now at 9f6b381 sdk-mcu-drivers: Added build system configs and generated files [west]: HEAD is now at 9f6b381 sdk-mcu-drivers: Added build system configs and generated files [west]: === updating openthread (modules/lib/openthread): [west]: --- openthread: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/openthread/.git/ [west]: --- openthread: fetching, need revision 57ef721eeed2550835c528ab7b8e77671f7039d6 [west]: From https://github.com/nrfconnect/sdk-openthread [west]: * branch 57ef721eeed2550835c528ab7b8e77671f7039d6 -> FETCH_HEAD [west]: HEAD is now at 57ef721 [ip6] fix constant name style and simplify filtering of ICMP types (#9512) [west]: HEAD is now at 57ef721 [ip6] fix constant name style and simplify filtering of ICMP types (#9512) [west]: === updating cmock (test/cmock): [west]: --- cmock: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/test/cmock/.git/ [west]: --- cmock: fetching, need revision f65066f15d8248e6dcb778efb8739904a4512087 [west]: From https://github.com/ThrowTheSwitch/cmock [west]: * branch f65066f15d8248e6dcb778efb8739904a4512087 -> FETCH_HEAD [west]: HEAD is now at f65066f Merge pull request #404 from tz18/patch-1 [west]: HEAD is now at f65066f Merge pull request #404 from tz18/patch-1 [west]: Submodule 'vendor/c_exception' (https://github.com/throwtheswitch/cexception.git) registered for path 'vendor/c_exception' [west]: Submodule 'vendor/unity' (https://github.com/throwtheswitch/unity.git) registered for path 'vendor/unity' [west]: Cloning into 'C:/ncs/v2.5.1/test/cmock/vendor/c_exception'... [west]: Cloning into 'C:/ncs/v2.5.1/test/cmock/vendor/unity'... [west]: Submodule path 'vendor/c_exception': checked out '71b47be7c950f1bf5f7e5303779fa99a16224bb6' [west]: Submodule path 'vendor/unity': checked out '4389bab82ee8a4b4631a03be2e07dd5c67dab2d4' [west]: === updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk): [west]: --- memfault-firmware-sdk: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/memfault-firmware-sdk/.git/ [west]: --- memfault-firmware-sdk: fetching, need revision 1.3.3 [west]: From https://github.com/memfault/memfault-firmware-sdk [west]: * tag 1.3.3 -> FETCH_HEAD [west]: HEAD is now at c374e92 Memfault Firmware SDK 1.3.3 (Build 3838) [west]: HEAD is now at c374e92 Memfault Firmware SDK 1.3.3 (Build 3838) [west]: === updating canopennode (modules/lib/canopennode): [west]: --- canopennode: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/canopennode/.git/ [west]: --- canopennode: fetching, need revision dec12fa3f0d790cafa8414a4c2930ea71ab72ffd [west]: From https://github.com/zephyrproject-rtos/canopennode [west]: * branch dec12fa3f0d790cafa8414a4c2930ea71ab72ffd -> FETCH_HEAD [west]: HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t() [west]: HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t() [west]: === updating chre (modules/lib/chre): [west]: --- chre: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/chre/.git/ [west]: --- chre: fetching, need revision b7955c27e50485b7dafdc3888d7d6afdc2ac6d96 [west]: From https://github.com/zephyrproject-rtos/chre [west]: * branch b7955c27e50485b7dafdc3888d7d6afdc2ac6d96 -> FETCH_HEAD [west]: HEAD is now at b7955c2 Merge pull request #7 from stephanosio/require_full_libcpp [west]: HEAD is now at b7955c2 Merge pull request #7 from stephanosio/require_full_libcpp [west]: === updating cmsis (modules/hal/cmsis): [west]: --- cmsis: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/hal/cmsis/.git/ [west]: --- cmsis: fetching, need revision 1abf29132e608826752e2edd1f4799a065db4031 [west]: From https://github.com/zephyrproject-rtos/cmsis [west]: * branch 1abf29132e608826752e2edd1f4799a065db4031 -> FETCH_HEAD [west]: HEAD is now at 1abf291 zephyr: cmake/kconfig are external [west]: HEAD is now at 1abf291 zephyr: cmake/kconfig are external [west]: === updating edtt (tools/edtt): [west]: --- edtt: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/tools/edtt/.git/ [west]: --- edtt: fetching, need revision 64e5105ad82390164fb73fc654be3f73a608209a [west]: From https://github.com/zephyrproject-rtos/edtt [west]: * branch 64e5105ad82390164fb73fc654be3f73a608209a -> FETCH_HEAD [west]: HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop [west]: HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop [west]: === updating fatfs (modules/fs/fatfs): [west]: --- fatfs: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/fs/fatfs/.git/ [west]: --- fatfs: fetching, need revision 427159bf95ea49b7680facffaa29ad506b42709b [west]: From https://github.com/zephyrproject-rtos/fatfs [west]: * branch 427159bf95ea49b7680facffaa29ad506b42709b -> FETCH_HEAD [west]: HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE [west]: HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE [west]: === updating hal_nordic (modules/hal/nordic): [west]: --- hal_nordic: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/hal/nordic/.git/ [west]: --- hal_nordic: fetching, need revision 9784731461018d3e983604698fbbed6af2bea801 [west]: From https://github.com/nrfconnect/sdk-hal_nordic [west]: * branch 9784731461018d3e983604698fbbed6af2bea801 -> FETCH_HEAD [west]: HEAD is now at 9784731 nrfx_qspi: Correct use of workaround for anomaly 215 and 43 in nrfx_qspi [west]: HEAD is now at 9784731 nrfx_qspi: Correct use of workaround for anomaly 215 and 43 in nrfx_qspi [west]: === updating hal_st (modules/hal/st): [west]: --- hal_st: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/hal/st/.git/ [west]: --- hal_st: fetching, need revision 9b128caf3e7b2e750169b880e83f210ea2213473 [west]: From https://github.com/zephyrproject-rtos/hal_st [west]: * branch 9b128caf3e7b2e750169b880e83f210ea2213473 -> FETCH_HEAD [west]: HEAD is now at 9b128ca sensor/stmemsc: Align stmemsc i/f to v2.3 [west]: HEAD is now at 9b128ca sensor/stmemsc: Align stmemsc i/f to v2.3 [west]: === updating hal_wurthelektronik (modules/hal/wurthelektronik): [west]: --- hal_wurthelektronik: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/hal/wurthelektronik/.git/ [west]: --- hal_wurthelektronik: fetching, need revision 24ca9873c3d608fad1fea0431836bc8f144c132e [west]: From https://github.com/zephyrproject-rtos/hal_wurthelektronik [west]: * branch 24ca9873c3d608fad1fea0431836bc8f144c132e -> FETCH_HEAD [west]: HEAD is now at 24ca987 Initialized WE HAL module repository. [west]: HEAD is now at 24ca987 Initialized WE HAL module repository. [west]: === updating libmetal (modules/hal/libmetal): [west]: --- libmetal: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/hal/libmetal/.git/ [west]: --- libmetal: fetching, need revision b91611a6f47dd29fb24c46e5621e797557f80ec6 [west]: From https://github.com/zephyrproject-rtos/libmetal [west]: * branch b91611a6f47dd29fb24c46e5621e797557f80ec6 -> FETCH_HEAD [west]: HEAD is now at b91611a lib: update libmetal to release v2023.04.0 [west]: HEAD is now at b91611a lib: update libmetal to release v2023.04.0 [west]: === updating liblc3 (modules/lib/liblc3): [west]: --- liblc3: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/liblc3/.git/ [west]: --- liblc3: fetching, need revision 448f3de31f49a838988a162ef1e23a89ddf2d2ed [west]: From https://github.com/zephyrproject-rtos/liblc3 [west]: * branch 448f3de31f49a838988a162ef1e23a89ddf2d2ed -> FETCH_HEAD [west]: HEAD is now at 448f3de Merge pull request #8 from carlescufi/rename [west]: HEAD is now at 448f3de Merge pull request #8 from carlescufi/rename [west]: === updating littlefs (modules/fs/littlefs): [west]: --- littlefs: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/fs/littlefs/.git/ [west]: --- littlefs: fetching, need revision ca583fd297ceb48bced3c2548600dc615d67af24 [west]: From https://github.com/zephyrproject-rtos/littlefs [west]: * branch ca583fd297ceb48bced3c2548600dc615d67af24 -> FETCH_HEAD [west]: HEAD is now at ca583fd Merge tag 'v2.5.0' of https://github.com/littlefs-project/littlefs into zephyr [west]: HEAD is now at ca583fd Merge tag 'v2.5.0' of https://github.com/littlefs-project/littlefs into zephyr [west]: === updating loramac-node (modules/lib/loramac-node): [west]: --- loramac-node: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/loramac-node/.git/ [west]: --- loramac-node: fetching, need revision 3029c9f304bf46a6e5205f3c8455dbc23108efec [west]: From https://github.com/zephyrproject-rtos/loramac-node [west]: * branch 3029c9f304bf46a6e5205f3c8455dbc23108efec -> FETCH_HEAD [west]: HEAD is now at 3029c9f utilities: fix few shadowed variables [west]: HEAD is now at 3029c9f utilities: fix few shadowed variables [west]: === updating lvgl (modules/lib/gui/lvgl): [west]: --- lvgl: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/gui/lvgl/.git/ [west]: --- lvgl: fetching, need revision 8a6a2d1d29d17d1e4bdc94c243c146a39d635fdd [west]: From https://github.com/zephyrproject-rtos/lvgl [west]: * branch 8a6a2d1d29d17d1e4bdc94c243c146a39d635fdd -> FETCH_HEAD [west]: HEAD is now at 8a6a2d1 zephyr: Move gluecode back to zephyr main repository [west]: HEAD is now at 8a6a2d1 zephyr: Move gluecode back to zephyr main repository [west]: === updating lz4 (modules/lib/lz4): [west]: --- lz4: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/lz4/.git/ [west]: --- lz4: fetching, need revision 8e303c264fc21c2116dc612658003a22e933124d [west]: From https://github.com/zephyrproject-rtos/lz4 [west]: * branch 8e303c264fc21c2116dc612658003a22e933124d -> FETCH_HEAD [west]: HEAD is now at 8e303c2 zephyr: make this repo a zephyr module [west]: HEAD is now at 8e303c2 zephyr: make this repo a zephyr module [west]: === updating mipi-sys-t (modules/debug/mipi-sys-t): [west]: --- mipi-sys-t: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/debug/mipi-sys-t/.git/ [west]: --- mipi-sys-t: fetching, need revision a819419603a2dfcb47f7f39092e1bc112e45d1ef [west]: From https://github.com/zephyrproject-rtos/mipi-sys-t [west]: * branch a819419603a2dfcb47f7f39092e1bc112e45d1ef -> FETCH_HEAD [west]: HEAD is now at a819419 library: allow building without wchar support [west]: HEAD is now at a819419 library: allow building without wchar support [west]: === updating nanopb (modules/lib/nanopb): [west]: --- nanopb: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/nanopb/.git/ [west]: --- nanopb: fetching, need revision 42fa8b211e946b90b9d968523fce7b1cfe27617e [west]: From https://github.com/zephyrproject-rtos/nanopb [west]: * branch 42fa8b211e946b90b9d968523fce7b1cfe27617e -> FETCH_HEAD [west]: HEAD is now at 42fa8b2 Merge pull request #2 from pdgendt/zephyr [west]: HEAD is now at 42fa8b2 Merge pull request #2 from pdgendt/zephyr [west]: === updating net-tools (tools/net-tools): [west]: --- net-tools: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/tools/net-tools/.git/ [west]: --- net-tools: fetching, need revision e0828aa9629b533644dc96ff6d1295c939bd713c [west]: From https://github.com/zephyrproject-rtos/net-tools [west]: * branch e0828aa9629b533644dc96ff6d1295c939bd713c -> FETCH_HEAD [west]: HEAD is now at e0828aa net-setup: Add instructions for NAT and routing [west]: HEAD is now at e0828aa net-setup: Add instructions for NAT and routing [west]: === updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models): [west]: --- nrf_hw_models: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/bsim_hw_models/nrf_hw_models/.git/ [west]: --- nrf_hw_models: fetching, need revision 57b61a9a2da75c860f15ca79522b24d57992df2c [west]: From https://github.com/zephyrproject-rtos/nrf_hw_models [west]: * branch 57b61a9a2da75c860f15ca79522b24d57992df2c -> FETCH_HEAD [west]: HEAD is now at 57b61a9 INT CNTRL: Generalize to N controllers [west]: HEAD is now at 57b61a9 INT CNTRL: Generalize to N controllers [west]: === updating open-amp (modules/lib/open-amp): [west]: --- open-amp: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/open-amp/.git/ [west]: --- open-amp: fetching, need revision 42b7c577714b8f22ce82a901e19c1814af4609a8 [west]: From https://github.com/zephyrproject-rtos/open-amp [west]: * branch 42b7c577714b8f22ce82a901e19c1814af4609a8 -> FETCH_HEAD [west]: HEAD is now at 42b7c57 cmake: Compile with WITH_DCACHE_RSC_TABLE [west]: HEAD is now at 42b7c57 cmake: Compile with WITH_DCACHE_RSC_TABLE [west]: === updating picolibc (modules/lib/picolibc): [west]: --- picolibc: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/picolibc/.git/ [west]: --- picolibc: fetching, need revision d07c38ff051386f8e09a143ea0a6c1d6d66dd1d8 [west]: From https://github.com/zephyrproject-rtos/picolibc [west]: * branch d07c38ff051386f8e09a143ea0a6c1d6d66dd1d8 -> FETCH_HEAD [west]: HEAD is now at d07c38ff Version 1.8.2 [west]: HEAD is now at d07c38ff Version 1.8.2 [west]: === updating segger (modules/debug/segger): [west]: --- segger: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/debug/segger/.git/ [west]: --- segger: fetching, need revision 9d0191285956cef43daf411edc2f1a7788346def [west]: From https://github.com/zephyrproject-rtos/segger [west]: * branch 9d0191285956cef43daf411edc2f1a7788346def -> FETCH_HEAD [west]: HEAD is now at 9d01912 segger: config: RTT spinlock implementation [west]: HEAD is now at 9d01912 segger: config: RTT spinlock implementation [west]: === updating tinycrypt (modules/crypto/tinycrypt): [west]: --- tinycrypt: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/crypto/tinycrypt/.git/ [west]: --- tinycrypt: fetching, need revision 3e9a49d2672ec01435ffbf0d788db6d95ef28de0 [west]: From https://github.com/zephyrproject-rtos/tinycrypt [west]: * branch 3e9a49d2672ec01435ffbf0d788db6d95ef28de0 -> FETCH_HEAD [west]: HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt [west]: HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt [west]: === updating TraceRecorderSource (modules/debug/TraceRecorder): [west]: --- TraceRecorderSource: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/debug/TraceRecorder/.git/ [west]: --- TraceRecorderSource: fetching, need revision 1ede7ce8e7ab226e9a84d95266241ba3f38d91d2 [west]: From https://github.com/zephyrproject-rtos/TraceRecorderSource [west]: * branch 1ede7ce8e7ab226e9a84d95266241ba3f38d91d2 -> FETCH_HEAD [west]: HEAD is now at 1ede7ce Merge pull request #16 from aronlander-pe/zephyr [west]: HEAD is now at 1ede7ce Merge pull request #16 from aronlander-pe/zephyr [west]: === updating tf-m-tests (modules/tee/tf-m/tf-m-tests): [west]: --- tf-m-tests: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/tee/tf-m/tf-m-tests/.git/ [west]: --- tf-m-tests: fetching, need revision a878426da78fbd1486dfc29d6c6b82be4ee79e72 [west]: From https://github.com/zephyrproject-rtos/tf-m-tests [west]: * branch a878426da78fbd1486dfc29d6c6b82be4ee79e72 -> FETCH_HEAD [west]: HEAD is now at a878426 Merge pull request #7 from d3zd3z/zephyr-1.8.0 [west]: HEAD is now at a878426 Merge pull request #7 from d3zd3z/zephyr-1.8.0 [west]: === updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests): [west]: --- psa-arch-tests: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/tee/tf-m/psa-arch-tests/.git/ [west]: --- psa-arch-tests: fetching, need revision 6a17330e0dfb5f319730f974d5b05f7b7f04757b [west]: From https://github.com/zephyrproject-rtos/psa-arch-tests [west]: * branch 6a17330e0dfb5f319730f974d5b05f7b7f04757b -> FETCH_HEAD [west]: HEAD is now at 6a17330 dev-apis: platform: Increase timeout for nRF devs [west]: HEAD is now at 6a17330 dev-apis: platform: Increase timeout for nRF devs [west]: === updating uoscore-uedhoc (modules/lib/uoscore-uedhoc): [west]: --- uoscore-uedhoc: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/uoscore-uedhoc/.git/ [west]: --- uoscore-uedhoc: fetching, need revision 5fe2cb613bd7e4590bd1b00c2adf181ac0229379 [west]: From https://github.com/zephyrproject-rtos/uoscore-uedhoc [west]: * branch 5fe2cb613bd7e4590bd1b00c2adf181ac0229379 -> FETCH_HEAD [west]: HEAD is now at 5fe2cb6 2.2.1 [west]: HEAD is now at 5fe2cb6 2.2.1 [west]: === updating zcbor (modules/lib/zcbor): [west]: --- zcbor: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/zcbor/.git/ [west]: --- zcbor: fetching, need revision 67fd8bb88d3136738661fa8bb5f9989103f4599e [west]: From https://github.com/zephyrproject-rtos/zcbor [west]: * branch 67fd8bb88d3136738661fa8bb5f9989103f4599e -> FETCH_HEAD [west]: HEAD is now at 67fd8bb Update version from 0.6.99 to 0.7.0 [west]: HEAD is now at 67fd8bb Update version from 0.6.99 to 0.7.0 [west]: === updating zscilib (modules/lib/zscilib): [west]: --- zscilib: initializing [west]: Initialized empty Git repository in C:/ncs/v2.5.1/modules/lib/zscilib/.git/ [west]: --- zscilib: fetching, need revision 34c3432e81085bb717e4871d21ca419ae0058ec5 [west]: From https://github.com/zephyrproject-rtos/zscilib [west]: * branch 34c3432e81085bb717e4871d21ca419ae0058ec5 -> FETCH_HEAD [west]: HEAD is now at 34c3432 Merge pull request #50 from microbuilder/ztest_fixes [west]: HEAD is now at 34c3432 Merge pull request #50 from microbuilder/ztest_fixes [west]: ERROR: update failed for project matter [west]: exited with code 1.
