I am trying to setup NRF toolchain using nrfutil in ubuntu 22.04 WSL inside windows but receiving error "Failed to retrieve toolchain-index" while running below command:
- sudo nrfutil toolchain-manager search
Prateek
Prateek
It might be possible that you have a wrong nrfutil on your system. Did you install it from here? for the Linux(x64) version?
I am able to run it properly
Hi!
I think, I found a solution. I am using virtual machine Xubuntu 22.04 (on VirtualBox 7.0) and in the virtual machine settings I need to do this: Network->Adapter1->Attached to = NAT, only after that everything worked! In my settings it was: Network->Adapter1->Attached to = Bridged Adapter. I don’t know why this is so, maybe someone can explain.)
BR,
Valeriy
Good to know. Thanks for writing the solution here.
