External SPI Flash Memory + File System + NRF 52832
I am trying to implement a lightweight file system in my external flash memory (ISSI). After the implementation of file system, I want to store a .bin file and later access the file through c program. I am a beginner in nrf52 board and need some assistance in understanding the implementation method for the above.
  1. I need some direction for implementing file system in nrf52832. I am using the following Software/Hardware tools:
  • nRF52832
  • NRF CONNECT SDK 2.5.1
  • SPI FLash Memory: IS25LP128-JBLE
  • vscode
  • Windows 11 64 bits
       2. I would also like to if I can implement FATFS on the SPI flash memory using the nrf 52832. Is there a link for the lastest version of FAT FS code.
       3. I need some help in understanding if I can use supported files from nrf SDK v 2.5.1 for nrf52832 board? IS there some alteration needed before I upload them to my nrf 52832 board.
Best,
AP
  • Hi Dejan,
    This is my logic trace for the pins SCK=P0.22=Channel7, SO=P0.23=Channel3, SI=P0.24=channel5 and CE=P0.25=channel1
    My prj.conf :
    # Optionally force the file system to be recreated
    CONFIG_APP_WIPE_STORAGE=y
    # fs_dirent structures are big.
    CONFIG_MAIN_STACK_SIZE=4096
    # Let __ASSERT do its job
    CONFIG_DEBUG=y
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=y
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    # CONFIG_SETTINGS=y
    # CONFIG_SETTINGS_FILE=y
    # CONFIG_SETTINGS_FILE_PATH="/lfs/settings/run"
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
    CONFIG_PARTITION_MANAGER_ENABLED=y
    # CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_FS=y
    # CONFIG_SETTINGS_FS_DIR="/lfs/settings"
    #CONFIG_SETTINGS_FS_FILE="/lfs/settings/run"
    #CONFIG_SETTINGS_FILE_PATH="/lfs/settings/run"
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
    CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL=y
    #CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_SETTINGS_NVS=y
    CONFIG_NVS=y
    My overlay file:
    /delete-node/ &storage_partition;
        chosen {
            nordic,pm-ext-flash = &IS25LP128;
    	fstab {
    		compatible = "zephyr,fstab";
    		lfs1: lfs1 {
    			compatible = "zephyr,fstab,littlefs";
    			mount-point = "/lfs1";
    			partition = <&lfs1_part>;
    			automount;
    			read-size = <16>;
    			prog-size = <16>;
    			cache-size = <64>;
    			lookahead-size = <32>;
    			block-cycles = <512>;
    &spi2 {
        compatible = "nordic,nrf-spi";
        status = "okay";
        pinctrl-0 = <&spi2_default>;
        pinctrl-1 = <&spi2_sleep>;
        cs-gpios = <&gpio0 22 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
        IS25LP128: IS25LP128@0 {
            compatible = "jedec,spi-nor";
            status = "okay";
            label = "25LP128";
            reg = <0>;
            spi-max-frequency = <8000000>; /* Adjust based on your flash specifications */
            size = <0x8000000>; /* Adjust based on your flash size */
            has-dpd;
            t-enter-dpd = <3000>;
            t-exit-dpd = <30000>;
            jedec-id = [ 9D 60 18 ]; /* Adjust based on your flash JEDEC ID */
            //page_size = <2048>;
            //block_size = <131072>;
    &pinctrl {
        spi2_default: spi2_default {
            group1 {
                psels = <NRF_PSEL(SPIM_SCK, 0, 25)>, /* gpio 0 pin P0.25 */
                        <NRF_PSEL(SPIM_MISO, 0, 24)>, /* gpio 0 pin P0.24 */
                        <NRF_PSEL(SPIM_MOSI, 0, 23)>; /* gpio 0 pin P0.23 */
        spi2_sleep: spi2_sleep {
            group1 {
    &IS25LP128 {
        partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		lfs1_part: partition@0 {
    			label = "storage";
    			reg = <0x00000000 0x00200000>;
    &i2c0 {
    	status = "disabled";
    &i2c1 {
    &spi1 {
    &spi0 {
    &uart0 {
    &flash0{
    &led0 {
    &led1 {
    &led2 {
    &led3 {
    &pwm_led0 {
    &button0 {
    &button1 {
    &button2 {
    &button3 {
    &arduino_header {
    My dts file:
     * Copyright (c) 2017 Shawn Nock <[email protected]>
     * Copyright (c) 2017 Linaro Limited
    /dts-v1/;
    #include <nordic/nrf52832_qfaa.dtsi>
    #include "nrf52dk_nrf52832-pinctrl.dtsi"
    #include <zephyr/dt-bindings/input/input-event-codes.h>
    	model = "Nordic nRF52 DK NRF52832";
    	compatible = "nrf52-dk-nrf5283nordic,2";
    	chosen {
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,sram = &sram0;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
    			label = "Green LED 0";
    		led1: led_1 {
    			gpios = <&gpio0 18 GPIO_ACTIVE_LOW>;
    			label = "Green LED 1";
    		led2: led_2 {
    			gpios = <&gpio0 19 GPIO_ACTIVE_LOW>;
    			label = "Green LED 2";
    		led3: led_3 {
    			gpios = <&gpio0 20 GPIO_ACTIVE_LOW>;
    			label = "Green LED 3";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = <&gpio0 13 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 0";
    			zephyr,code = <INPUT_KEY_0>;
    		button1: button_1 {
    			gpios = <&gpio0 14 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 1";
    			zephyr,code = <INPUT_KEY_1>;
    		button2: button_2 {
    			gpios = <&gpio0 15 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 2";
    			zephyr,code = <INPUT_KEY_2>;
    		button3: button_3 {
    			gpios = <&gpio0 16 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 3";
    			zephyr,code = <INPUT_KEY_3>;
    	arduino_header: connector {
    		compatible = "arduino-header-r3";
    		#gpio-cells = <2>;
    		gpio-map-mask = <0xffffffff 0xffffffc0>;
    		gpio-map-pass-thru = <0 0x3f>;
    		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
    			   <1 0 &gpio0 4 0>,	/* A1 */
    			   <2 0 &gpio0 28 0>,	/* A2 */
    			   <3 0 &gpio0 29 0>,	/* A3 */
    			   <4 0 &gpio0 30 0>,	/* A4 */
    			   <5 0 &gpio0 31 0>,	/* A5 */
    			   <6 0 &gpio0 11 0>,	/* D0 */
    			   <7 0 &gpio0 12 0>,	/* D1 */
    			   <8 0 &gpio0 13 0>,	/* D2 */
    			   <9 0 &gpio0 14 0>,	/* D3 */
    			   <10 0 &gpio0 15 0>,	/* D4 */
    			   <11 0 &gpio0 16 0>,	/* D5 */
    			   <12 0 &gpio0 17 0>,	/* D6 */
    			   <13 0 &gpio0 18 0>,	/* D7 */
    			   <14 0 &gpio0 19 0>,	/* D8 */
    			   <15 0 &gpio0 20 0>,	/* D9 */
    			   <16 0 &gpio0 22 0>,	/* D10 */
    			   <17 0 &gpio0 23 0>,	/* D11 */
    			   <18 0 &gpio0 24 0>,	/* D12 */
    			   <19 0 &gpio0 25 0>,	/* D13 */
    			   <20 0 &gpio0 26 0>,	/* D14 */
    			   <21 0 &gpio0 27 0>;	/* D15 */
    	arduino_adc: analog-connector {
    		compatible = "arduino,uno-adc";
    		#io-channel-cells = <1>;
    		io-channel-map = <0 &adc 1>,	/* A0 = P0.3 = AIN1 */
    				 <1 &adc 2>,	/* A1 = P0.4 = AIN2 */
    				 <2 &adc 4>,	/* A2 = P0.28 = AIN4 */
    				 <3 &adc 5>,	/* A3 = P0.29 = AIN5 */
    				 <4 &adc 6>,	/* A4 = P0.30 = AIN6 */
    				 <5 &adc 7>;	/* A5 = P0.31 = AIN7 */
    	/* These aliases are provided for compatibility with samples */
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		pwm-led0 = &pwm_led0;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		bootloader-led0 = &led0;
    		mcuboot-button0 = &button0;
    		mcuboot-led0 = &led0;
    		watchdog0 = &wdt0;
    &adc {
    	status = "okay";
    &uicr {
    	gpio-as-nreset;
    &gpiote {
    	status = "okay";
    &gpio0 {
    	status = "okay";
    arduino_serial: &uart0 {
    	status = "okay";
    	current-speed = <115200>;
    	pinctrl-0 = <&uart0_default>;
    	pinctrl-1 = <&uart0_sleep>;
    arduino_i2c: &i2c0 {
    	compatible = "nordic,nrf-twi";
    	status = "okay";
    	pinctrl-0 = <&i2c0_default>;
    	pinctrl-1 = <&i2c0_sleep>;
    &i2c1 {
    	/* Cannot be used together with spi1. */
    	/* status = "okay"; */
    	pinctrl-0 = <&i2c1_default>;
    	pinctrl-1 = <&i2c1_sleep>;
    &pwm0 {
    	status = "okay";
    	pinctrl-0 = <&pwm0_default>;
    	pinctrl-1 = <&pwm0_sleep>;
    &spi0 {
    	/* Cannot be used together with i2c0. */
    	pinctrl-0 = <&spi0_default>;
    	pinctrl-1 = <&spi0_sleep>;
    &spi1 {
    	status = "okay";
    	pinctrl-0 = <&spi1_default>;
    	pinctrl-1 = <&spi1_sleep>;
    arduino_spi: &spi2 {
    	status = "okay";
    	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>, /* D10 */
    				<&gpio0 25 GPIO_ACTIVE_LOW>; /* D10 */
    &flash0 {
    	partitions {
    		#size-cells = <1>;
    		boot_partition: partition@0 {
    			label = "mcuboot";
    			reg = <0x00000000 0xc000>;
    		slot0_partition: partition@c000 {
    			label = "image-0";
    			reg = <0x0000C000 0x37000>;
    		slot1_partition: partition@43000 {
    			label = "image-1";
    			reg = <0x00043000 0x37000>;
    		storage_partition: partition@7a000 {
    			label = "storage";
    			reg = <0x0007a000 0x00006000>;
    My build log:
     *  Executing task: nRF Connect: Build [pristine]: little_fs/build (active)
    Building little_fs
    west build --build-dir c:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build c:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs --pristine --board nrf52dk_nrf52832 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/users/prasa/desktop/nrf52dk/v2.5.0/little_fs;c:/users/prasa/desktop/nrf52dk/littlefs -DCONF_FILE=c:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/prj.conf -DDTC_OVERLAY_FILE=c:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/nrf52dk_nrf52832.overlay
    -- Application: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs
    -- CMake version: 3.20.5
    -- Found Python3: C:/Users/prasa/Desktop/nrf52dk/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/zephyr/.cache
    -- Zephyr version: 3.4.99 (C:/Users/prasa/Desktop/nrf52dk/v2.5.0/zephyr)
     *  Executing task: nRF Connect: Generate config nrf52dk_nrf52832 for c:\Users\prasa\Desktop\nrf52dk\v2.5.0\little_fs
    Building little_fs
    west build --build-dir c:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build_1 c:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs --pristine --board nrf52dk_nrf52832 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/users/prasa/desktop/nrf52dk/v2.5.0/little_fs
    -- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
    -- Board: nrf52dk_nrf52832
    -- Found host-tools: zephyr 0.16.1 (C:/Users/prasa/Desktop/nrf52dk/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.1 (C:/Users/prasa/Desktop/nrf52dk/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found Dtc: C:/Users/prasa/Desktop/nrf52dk/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832.dts
    -- Found devicetree overlay: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/nrf52dk_nrf52832.overlay
    'label' is marked as deprecated in 'properties:' in C:/Users/prasa/Desktop/nrf52dk/v2.5.0/zephyr/dts/bindings\mtd\jedec,spi-nor.yaml for node /soc/spi@40023000/IS25LP128@0.
    -- Generated zephyr.dts: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build_1/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build_1/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build_1/zephyr/dts.cmake
    warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: SERIAL_HAS_DRIVER (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up UART_CONSOLE in
    the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
    Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    Parsing C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/Kconfig
    Loaded configuration 'C:/Users/prasa/Desktop/nrf52dk/v2.5.0/zephyr/boards/arm/nrf52dk_nrf52832/nrf52dk_nrf52832_defconfig'
    Merged configuration 'C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/prj.conf'
    Configuration saved to 'C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build_1/zephyr/.config'
    Kconfig header saved to 'C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build_1/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: c:/users/prasa/desktop/nrf52dk/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/Users/prasa/Desktop/nrf52dk/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    CMake Warning at C:/Users/prasa/Desktop/nrf52dk/v2.5.0/zephyr/CMakeLists.txt:893 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
      No SOURCES given to Zephyr library: drivers__serial
    -- Found partition manager static configuration: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/pm_static.yml
    Partition 'littlefs_storage' is not included in the dynamic resolving since it is statically defined.
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/prasa/Desktop/nrf52dk/v2.5.0/little_fs/build_1
    [2/161] Generating include/generated/version.h
    -- Zephyr version: 3.4.99 (C:/Users/prasa/Desktop/nrf52dk/v2.5.0/zephyr), build: v3.4.99-ncs1
    [160/161] Linking C executable zephyr\zephyr.elf
               FLASH:       59984 B       512 KB     11.44%
                 RAM:       11180 B        64 KB     17.06%
            IDT_LIST:          0 GB         2 KB      0.00%
    [161/161] Generating zephyr/merged.hex
    I am no longer getting a flash result in my com4 port.
    Aditi Prasad
    MOSI signal on channel 3 does not look correct. In addition, you specify that your MISO is on pin P0.23 but you have configured it in the overlay to be on P0.24. Similarly, for MOSI you say that it is on P0.24 but it is configured in your overlay on P0.23. You could check if your MISO and MOSI pins are correctly connected and configured.
    Dejan
  • Hi Dejan,
    I made some changes to my connections on my NRF52k:
    CLK: P0.25
    MISO: P0.24 (connected to SO on Flash)
    MOSI: P0.23 (connected to SI on Flash)
    CE: P0.22
    My overlay:
        chosen {
    	fstab {
    		lfs1: lfs1 {
    			automount;
    			read-size = <16>;
    			prog-size = <16>;
    			cache-size = <64>;
    &spi2 {
        status = "okay";
        cs-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
            status = "okay";
            label = "25LP128";
            reg = <0>;
            spi-max-frequency = <133000000>; /* Adjust based on your flash specifications */
            has-dpd;
            //wp-gpios = < &gpio0 12 GPIO_ACTIVE_LOW>;
            //hold-gpios = < &gpio0 11 GPIO_ACTIVE_LOW>;
    &pinctrl {
            group1 {
            group1 {
    &IS25LP128 {
        partitions {
    		#size-cells = <1>;
    			label = "storage";
                reg = <0x00000000 0x02000000>;
    Prj.conf:
    # Copyright (c) 2019 Peter Bigot Consulting, LLC
    # CONFIG_APP_WIPE_STORAGE=y
    CONFIG_DEBUG=y
    CONFIG_LOG=y
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    The trace:
    Flash log:
     *  Executing task: nRF Connect: Build [pristine]: littlefs/build (active)
    Building littlefs
    west build --build-dir c:/Users/prasa/Desktop/nrf52dk_backup/littlefs/build c:/Users/prasa/Desktop/nrf52dk_backup/littlefs --pristine --board nrf52dk_nrf52832 --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=c:/Users/prasa/Desktop/nrf52dk_backup/littlefs/prj.conf -DDTC_OVERLAY_FILE=c:/Users/prasa/Desktop/nrf52dk_backup/littlefs/nrf52dk_nrf52832.overlay
    -- Application: C:/Users/prasa/Desktop/nrf52dk_backup/littlefs
    -- Found devicetree overlay: c:/Users/prasa/Desktop/nrf52dk_backup/littlefs/nrf52dk_nrf52832.overlay
    -- Generated zephyr.dts: C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/build/zephyr/dts.cmake
    warning: PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL (defined at C:/Users/prasa/Desktop/nrf52dk/v2
    .5.0/nrf\subsys\partition_manager\Kconfig.template.partition_region:2) was assigned the value 'y'
    but got the value 'n'. Check these unsatisfied dependencies: (SETTINGS_FCB || SETTINGS_NVS) (=n).
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EX
    TERNAL and/or look up PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL in the menuconfig/guiconfig
    interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and
    warning: PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL (defined at C:/Users/prasa/Desktop/nrf52dk/v2.5.0/
    nrf\subsys\partition_manager\Kconfig.template.partition_region:2) was assigned the value 'y' but got
    the value 'n'. Check these unsatisfied dependencies: NVS (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL
    and/or look up PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL in the menuconfig/guiconfig interface. The
    Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices
    Parsing C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/Kconfig
    Merged configuration 'c:/Users/prasa/Desktop/nrf52dk_backup/littlefs/prj.conf'
    Configuration saved to 'C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/build/zephyr/.config'
    Kconfig header saved to 'C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/build/zephyr/include/generated/autoconf.h'
    -- Found partition manager static configuration: C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/pm_static.yml
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/prasa/Desktop/nrf52dk_backup/littlefs/build
    [1/156] Generating ../../zephyr/include/generated/ncs_version.h
    [2/156] Generating include/generated/version.h
    [3/156] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [4/156] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [5/156] Generating include/generated/driver-validation.h
    [6/156] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [7/156] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [8/156] Generating include/generated/offsets.h
    [9/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [10/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [11/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/__/common/tls.c.obj
    [12/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [13/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [14/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [15/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [16/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [17/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [18/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [19/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [20/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [21/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [22/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [23/156] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [24/156] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [25/156] Linking C static library zephyr\arch\common\libisr_tables.a
    [26/156] Linking C static library zephyr\arch\common\libarch__common.a
    [27/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [28/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [29/156] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [30/156] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [31/156] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [32/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/__aeabi_read_tp.S.obj
    [33/156] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [34/156] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [35/156] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/libc-hooks.c.obj
    [36/156] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
    [37/156] Linking C static library zephyr\lib\libc\picolibc\liblib__libc__picolibc.a
    [38/156] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
    [39/156] Linking C static library zephyr\lib\libc\common\liblib__libc__common.a
    [40/156] Building C object zephyr/soc/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [41/156] Building C object zephyr/soc/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
    [42/156] Linking C static library zephyr\soc\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [43/156] Linking C static library zephyr\soc\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
    [44/156] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs.c.obj
    [45/156] Building C object CMakeFiles/app.dir/src/main.c.obj
    [46/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [47/156] Linking C static library app\libapp.a
    [48/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [49/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [50/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [51/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [52/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [53/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [54/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [55/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [56/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [57/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [58/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [59/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [60/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [61/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [62/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [63/156] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [64/156] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [65/156] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [66/156] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [67/156] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [68/156] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [69/156] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [70/156] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
    [71/156] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
    [72/156] Building C object zephyr/CMakeFiles/zephyr.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [73/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [74/156] Linking C static library zephyr\libzephyr.a
    [75/156] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [76/156] Generating linker_zephyr_pre0.cmd
    [77/156] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [78/156] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [79/156] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [80/156] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs_impl.c.obj
    [81/156] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [82/156] Building C object zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/littlefs_fs.c.obj
    [83/156] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [84/156] Linking C static library zephyr\subsys\fs\libsubsys__fs.a
    [85/156] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [86/156] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [87/156] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [88/156] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
    [89/156] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
    [90/156] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
    [91/156] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [92/156] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [93/156] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [94/156] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [95/156] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [96/156] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [97/156] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [98/156] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [99/156] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [100/156] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spi.c.obj
    [101/156] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj
    [102/156] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
    [103/156] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [104/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/mdk/system_nrf52.c.obj
    [105/156] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [106/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [107/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj
    [108/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [109/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [110/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [111/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [112/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spi.c.obj
    [113/156] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
    [114/156] Building C object modules/littlefs/CMakeFiles/modules__littlefs.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/fs/littlefs/lfs_util.c.obj
    [115/156] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [116/156] Building C object modules/littlefs/CMakeFiles/modules__littlefs.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/fs/littlefs/lfs.c.obj
    [117/156] Building C object modules/littlefs/CMakeFiles/modules__littlefs.dir/zephyr_lfs_crc.c.obj
    [118/156] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/Users/prasa/Desktop/nrf52dk/v2.5.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
    [119/156] Linking C static library modules\littlefs\libmodules__littlefs.a
    [120/156] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
    [121/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [122/156] Linking C static library modules\segger\libmodules__segger.a
    [123/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [124/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [125/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
    [126/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [127/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [128/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [129/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [130/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [131/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [132/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [133/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [134/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [135/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [136/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [137/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [138/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [139/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [140/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [141/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [142/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [143/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [144/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [145/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj
    [146/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [147/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [148/156] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [149/156] Linking C static library zephyr\kernel\libkernel.a
    [150/156] Linking C executable zephyr\zephyr_pre0.elf
    [154/156] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [155/156] Linking C executable zephyr\zephyr.elf
               FLASH:       62040 B       512 KB     11.83%
                 RAM:       11372 B        64 KB     17.35%
    [156/156] Generating zephyr/merged.hex
     *  Executing task: nRF Connect: Build: littlefs/build (active)
    Building littlefs
    ninja: no work to do.
     *  Executing task: nRF Connect: Flash: littlefs/build (active)
    Flashing build to 1050370044
    west flash -d c:\Users\prasa\Desktop\nrf52dk_backup\littlefs\build --skip-rebuild --dev-id 1050370044 --erase
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: mass erase requested
    -- runners.nrfjprog: Flashing file: c:\Users\prasa\Desktop\nrf52dk_backup\littlefs\build\zephyr\merged.hex
    [ ######               ]   0.000s | Erase file - Check image                                                      [ #################### ]   0.062s | Erase file - Done erasing
    [ ######               ]   0.000s | Program file - Checking image                                                 [ #####                ]   0.000s | Check image validity - Initialize device info                                 [ ##########           ]   0.000s | Check image validity - Check region 0 settings                                [ ###############      ]   0.000s | Check image validity - block 1 of 2                                           [ #################### ]   0.016s | Check image validity - Finished                                               [ #############        ]   0.000s | Program file - Programming                                                    [ ##########           ]   0.000s | Programming image - block 1 of 1                                              [ #################### ]   0.000s | Programming image - Write successful                                          [ #################### ]   1.120s | Program file - Done programming
    [ ######               ]   0.000s | Verify file - Check image                                                     [ #####                ]   0.000s | Check image validity - Initialize device info                                 [ ##########           ]   0.000s | Check image validity - Check region 0 settings                                [ ###############      ]   0.411s | Check image validity - block 1 of 2                                           [ #################### ]   0.017s | Check image validity - Finished                                               [ #############        ]   0.000s | Verify file - Verifying                                                       [ ##########           ]   0.000s | Verifying image - block 1 of 1                                                [ #################### ]   0.000s | Verifying image - Verify successful                                           [ #################### ]   0.415s | Verify file - Done verifying
    Enabling pin reset.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 1050370044 flashed successfully.
    Building littlefs
    [ ######               ]   0.000s | Program file - Checking image                                                 [ #####                ]   0.000s | Check image validity - Initialize device info                                 [ ##########           ]   0.000s | Check image validity - Check region 0 settings                                [ ###############      ]   0.000s | Check image validity - block 1 of 2                                           [ #################### ]   0.017s | Check image validity - Finished                                               [ #############        ]   0.000s | Program file - Programming                                                    [ ##########           ]   0.000s | Programming image - block 1 of 1                                              [ #################### ]   0.000s | Programming image - Write successful                                          [ #################### ]   1.123s | Program file - Done programming
    [ ######               ]   0.000s | Verify file - Check image                                                     [ #####                ]   0.000s | Check image validity - Initialize device info                                 [ ##########           ]   0.000s | Check image validity - Check region 0 settings                                [ ###############      ]   0.411s | Check image validity - block 1 of 2                                           [ #################### ]   0.017s | Check image validity - Finished                                               [ #############        ]   0.000s | Verify file - Verifying                                                       [ ##########           ]   0.000s | Verifying image - block 1 of 1                                                [ #################### ]   0.000s | Verifying image - Verify successful                                           [ #################### ]   0.416s | Verify file - Done verifying
    Enabling pin reset.
    Applying pin reset.
    I am getting a different device id read after flashing:
    E: Device id 32 01 06 does not match config 9d 60 18
    I: littlefs partition at /lfs1
    I: LittleFS version 2.5, disk version 2.0
    E: can't open flash area 3
    E: fs mount error (-19)
    E: Automount /lfs1 failed: -19
    *** Booting nRF Connect SDK v2.5.0 ***
    Sample program to r/w files on littlefs
    E: FAIL: unable to find flash area 3: -19
    BR,
    AP
    For SPI support, you could try to add CONFIG_SPI_NOR=y to your configuration file.
    You could also verify that your jedec-id is correct.
    Regarding your trace, could you zoom in, and provide it again?
    Dejan
  • Hi Dejan,
    CONFIG_SPI_NOR doesnot resolve the error.
    Jedec-id is correct : [9D 60 18]
    Trace:
    The single trigger after the sck goes low should be correct. Can I put a delay before receiving this input (miso)? If so, where should I place this code?
    COM 4:
    E: Device id 99 00 83 does not match config 9d 60 18
    E: can't open flash area 1
    E: FAIL: unable to find flash area 1: -19
    FAIL: statvfs: -19
    Br,
    AP
