Mesh back and forth seems to break connection
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in the app level, where the sensor discovers the network IP of the host in pairing host. All the devices have the same PANID and network key.
Recently we have seen a scenario where some sensors seemingly stopped communication with the paired host. By looking at the RSSI graphs, we thought is this caused by a sensor constantly swinging back and forth between two hosts (one host acting as a router). We dont have access to the CLI interface of the hosts as this is a remote site. We see the Sensor RSSI reported back. This is its RSSI with the router/leader immediately connected to at the time.
Any ideas?
Cheers,
Kaushalya
  • Hi Edvin,
    Unfortunately this log was captured after we saw the sensors are no longer sending data. The sensors used to work fine for about 3-4 months. So this is an extreme random and rare case. Now we have set up the debug console to the host radio and the wireshark sniffer permanently in the same place to see if we can capture when it happens.
    Under what conditions the Leader/Router drop a child from its child table?
    Kaushalya
    It should only be if it stops responding, or if either the child or the parent issues a leave command for the child. I guess you are not intentionally requesting the child to leave, so my guess is that the child becomes unresponsive. Perhaps the application crashes. The logs will probably say something when it happens. You can also test this by simulating this scenario, e.g. by powering off the parent, and monitor the child node's log.
    BR,
    Edvin
  • Hi Edvin,
    I am trying to implement Child supervision in hope that will help. Unfortunately the documentation is not very clear to me. It is mentioned to enable 'OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE', which is defined in child_supervision.h in SDK. I dont think changing SDK content is a good idea as if the SDK is updated, we will loose all that.
    1. Is there a way to implement child supervision from application side?
    2. What is to be done from FTD side?
    3. What is to be done from SED side?
    Kaushalya
  • Hi Edvin,
    We have WDT implemented in the client, so unlikely the sensor crashes. The sensors as they are battery powered devices, have the console disabled. I think we can have special build with consoles enabled just for this.
    Kaushalya
    Most of these are only defined if they are not defined elsewhere:
     * @def OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE
     * Define to 1 to enable Child Supervision support.
    #ifndef OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE
    #define OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE 0
    So if you define it somewhere in your project, outside the SDK, that should take precedence.
    Do you have logging enabled on any of them?
    I think so. We need to investigate what's going on. The logs could reveal something.At this point, all we know is that the devices "disappear". Perhaps they are stuck in some weird state / state machine?
    Edvin
