Mesh back and forth seems to break connection
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in the app level, where the sensor discovers the network IP of the host in pairing host. All the devices have the same PANID and network key.
Recently we have seen a scenario where some sensors seemingly stopped communication with the paired host. By looking at the RSSI graphs, we thought is this caused by a sensor constantly swinging back and forth between two hosts (one host acting as a router). We dont have access to the CLI interface of the hosts as this is a remote site. We see the Sensor RSSI reported back. This is its RSSI with the router/leader immediately connected to at the time.
Any ideas?
Cheers,
Kaushalya
  • Hi Edvin,
    Now it seems correctly working based on console messages and their timing.
    On SED console
    [00:00:36.580,535] <inf> [N] ChildSupervsn-: restart timer
    [00:01:06.582,611] <inf> [N] ChildSupervsn-: restart timer
    [00:01:36.582,122] <inf> [N] ChildSupervsn-: restart timer
    On FTD console
    [01:11:59.735,687] <inf> [I] ChildSupervsn-: sec sinse ast sup 28
    [01:12:00.731,903] <inf> [I] ChildSupervsn-: sec sinse ast sup 29
    [01:12:01.736,145] <inf> [I] ChildSupervsn-: Sending supervision message to child 0xcc01
    [01:12:02.740,173] <inf> [I] ChildSupervsn-: sec sinse ast sup 1
    [01:12:03.738,311] <inf> [I] ChildSupervsn-: sec sinse ast sup 2
    This seems FTD counts supervision interval every 1Sec and every 30 sec it sends supervision packet t to the child? (I have set the interval to 30 sec in FTD and timeout to 60 in SED.) I think in this instance the child supervision is functioning.
    "Now the only thing is I still cant see the full effect of child supervision" What I meant was I cant see the child supervision bringing back a SED from this 'fallen off' state. For me to verify the effect of child supervision, I have to see a child which has dropped off the child table, rejoining the network.
    What I have seen when this drop off issue comes up in the field, is that the child has dropped from the Leaders child table. I don't think the child stopped sending the poll packet for longer than 240 sec. There were no other routers for the child to jump to as well. So I have the feeling this may be some Thread related issue.
    Cheers,
    Kaushalya
  • Even without child supervision, the SEDs reattach to the network and starts sending data to the paired FTD. Like if I take the SED out of reach and back I can see the disconnection reconnection. So it doesn't seem in this rare problem, the SEDs actually disconnect from the network from FTD's side but seemingly connected from SEDs side.
    Child supervision isn't used to determine whether a child is allowed to re-join the network or not. It is just a way of keeping track of the current status of the child, whether it is still alive or not. If the child supervision times out, then the child is considered disconnected from the network (but still allowed to rejoin).
    I think we are a bit off track. At least I am. We are trying to figure out why some devices are suddenly not reachable from the network, right? Or, you said that some devices that are initially routers suddenly become leaders? This would suggest that they have determined that they can't reach the rest of the network, forming a new network with itself as the leader.
    It is a common mechanism in openthread to partition into two separate networks, each maintaining the operational status as best as it can. These networks will have the same name and the same PANID. If the two networks are brought back together, they will merge into a single partition. These nodes typically don't move around, but they may not be able to reach eachother if a particular node (router) that is a single device within range of both partitions (but the rest of the partitions are not able to reach the other partition) goes offline/runs out of battery.
    Since you mentioned that the device is suddenly a leader, it suggests that something like this has happened. Then we were trying to investigate whether something particular happened right before these nodes fall out, right? Were you able to catch some logs during this events from the devices that fall out?
    On FTD console
    This is during normal operation, right? It is not from an instance when the child falls out of the child table?
    Edvin
  • Hi Edvin,
    I dont intend to use child supervision as a mechanism to determine weather a child node can rejoin or not. I intend it to rejoin, if for some reason it falls off from the leader.
    Yes, more precisely, why all of a sudden some SEDs fall off from the child table of the leader.
    Not really. Normally we have only one Leader and many child devices. When I first started this thread, we saw this happening in a customer who had two FTDs. Since we havent see this behavior until then we thought this could be SEDs connecting back and forth with each FTD. But since then we have see this drop off happening in places with one FTD.
    For this to happen, I guess there should be more than one FTD? So this cant explain the issue happening in systems with one leader.
    When we look at RSSI data, we cant see any RSSI drops on the SEDs before they go disconnect either.
    Now I dont think this is the case anymore. We have seen this in multiple cases where there is only one leader.
    Unfortunately no. Since this is a very rare occurrence.  Only ones we have captured are once this happens. That's how we know the that the leader has dropped the child from child table while the child seemingly still in the network. The console is disabled in the child, so we cannot inquire or see anything. Unfortunately we forgot about the RTT. We could have used the RTT viewer at least to see some log from a child in this state.
    Assuming that the child actually stopped sending the poll for 240sec, what could trigger such a behavior? The SED's UI was functioning. The only thing I can think is some openthread threads stopped working.
    Now I have added thread analyzer to the SEDs to detect if all the openthread threads are active. We have deployed about 20 SEDs now with child supervision to see if we get this again. I couldnt find a way to forcefully drop a child off the child table to verify the reattach mechanism in action.
    Cheers,
    Kaushalya
  • Hi Edvin,
    Unfortunately I have seen some sensors falling off over the weekend with child supervision enabled.
    This is a capture of the app level.
    I will gather more details on them this evening.
    First thing is that the fall off in 23rd around 2.15pm, is actually we loosing wifi connection, as we get these graphs over our dashboard, which needs system to connect to WiFi to send all these data to cloud. Wifi was back in 25th 8.30am like. But the thing is S2, S5 and S7 seems not connected.
    The S7 sensor has a low battery around 2.4V. We have seen sensors not working in this level. So S7 falling off may have been a power issue.
    Cheers,
    Kaushalya
